samung c3322 dead i have c3322 Connect Cable to Switched Off Mobile (with battery) Software: C3322XXKE1 Hardware: MP 0.302 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2011 May Rev: 1 CSC Vers: C3322OJVKE2 TMC Customer: Algeria MSL Active S/N : RPNB949864 IMEI: 356431-04-542427-9 IME2: 356432-04-542427-7 BTID: 9451:03:514F59 MSL Active SIMLOCK STATUS: 0000 MCC-MNC: MASTER KEY: 52049310 NET 00000000, 00000000 SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK 00000000, 00000000 when i flash with firmware C3322JPKE3_OJPKE3 it dead,it not turned on, give me solution please |
Hwk not support yet, try another tools |
Show full flashing log. Also check with another version. |
i flash it again with C3322XXKE3_OXEKE3 but not turned on, please help |
check the firmware first |
V 2.2.0.1 ------ SWIFT Some DUOS models Slave Boot bug Fixed. SWIFT-AEROFONE E1050,E1055T,E1080W,E1170i E2P Size Fixed. Max Section Size Increased. E1182 added (DUNL,PUNL,PIM,FL) C3303i,C3322,C3500 added (CUNL,DUNL,IM,SECT,E2P) Note: C3322,C3500 TFS and CSC Flashing not Supported yet, use Original Flasher. |
i need firmware C3322XXKE1_OJVKE2 |
the phone is stoped in c3322 |
help me please to power on this phone |
Flash loader 7.4.7_SSG_v0.3_Lite download look hwk support same sulutions c3322 step by step sulutions options ok How To Update Firmware Of Samsung C3222W / Ch@t 322 WIFI Firmware Update Steps: - Run Samsung C3222W / Ch@t 322 WIFI Download Program. - Press OK . - Remove and reinsert battery from the Phone and Press Volume Down + SIM Cards key then Connect it to USB cable. - When PC ask you for Drivers install it ( Drivers are located inside Flasher Folder ). - After all Drivers are installed disconnect the phone. - Click on SET MODEL Button and select : C3222W_PUNCH_WIFI_Setting_v00.mdl file. - At the field Application binary file click on Browse and select : C3222WOPEN.ptt file. - At the field TFS file click on Browse and select C3222Wxxxxx.tfs file. - At the field CSC file click on Browse and select C3222WOxxxxx.csc file. - Click on START button. - Remove and reinsert battery from the Phone and Press Volume Down + SIM Cards key then Connect it to USB cable. - Wait till the process finished. - When all is done the program give you this : Slot freed for new download. - Disconnect the phone and turn it on. |
i have samsung 3322 dead load varied when switched on pls tell any hardware solution |
