Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 11-28-2011, 08:24   #1 (permalink)
Member: 112696
Sonork: 100.1608550
samung c3322 dead
i have c3322
Connect Cable to Switched Off Mobile (with battery)
Software: C3322XXKE1
Hardware: MP 0.302
Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK
Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr )
Release : 2011 May Rev: 1
CSC Vers: C3322OJVKE2 TMC
Customer: Algeria
MSL Active
S/N : RPNB949864
IMEI: 356431-04-542427-9
IME2: 356432-04-542427-7
BTID: 9451:03:514F59
MSL Active
SIMLOCK STATUS: 0000
MCC-MNC:
MASTER KEY: 52049310
NET 00000000, 00000000
SUB 00000000, 00000000
SP 00000000, 00000000
CP 00000000, 00000000
SIM 00000000, 00000000
ACT 00000000, 00000000
PLK 00000000, 00000000
when i flash with firmware C3322JPKE3_OJPKE3 it dead,it not turned on, give me solution please
Old 11-28-2011, 10:11   #2 (permalink)
Member: 839770
Hwk not support yet, try another tools
Old 11-28-2011, 11:00   #3 (permalink)
Member: 682736
Show full flashing log. Also check with another version.
Old 11-29-2011, 08:21   #4 (permalink)
Member: 112696
Sonork: 100.1608550
i flash it again with C3322XXKE3_OXEKE3 but not turned on, please help
Old 11-29-2011, 08:53   #5 (permalink)
Member: 1674143
check the firmware first
Old 11-29-2011, 15:56   #6 (permalink)
Member: 904530
V 2.2.0.1
SWIFT
Some DUOS models Slave Boot bug Fixed.
SWIFT-AEROFONE
E1050,E1055T,E1080W,E1170i E2P Size Fixed.
Max Section Size Increased.
E1182 added (DUNL,PUNL,PIM,FL)
C3303i,C3322,C3500 added (CUNL,DUNL,IM,SECT,E2P)
Note:
C3322,C3500 TFS and CSC Flashing not Supported yet,
use Original Flasher.
Old 11-30-2011, 14:55   #7 (permalink)
Member: 112696
Sonork: 100.1608550
i need firmware C3322XXKE1_OJVKE2
Old 11-30-2011, 15:23   #8 (permalink)
Member: 112696
Sonork: 100.1608550
the phone is stoped in c3322
Old 12-03-2011, 14:50   #9 (permalink)
Member: 112696
Sonork: 100.1608550
help me please to power on this phone
Old 12-03-2011, 15:50   #10 (permalink)
turkcellgsm's Avatar
Member: 395431
Flash loader 7.4.7_SSG_v0.3_Lite download look hwk support
same sulutions c3322 step by step sulutions options ok
How To Update Firmware Of Samsung C3222W / Ch@t 322 WIFI
Firmware Update Steps:
- Run Samsung C3222W / Ch@t 322 WIFI Download Program.
- Press OK .
- Remove and reinsert battery from the Phone and Press Volume Down + SIM Cards key then Connect it to USB cable.
- When PC ask you for Drivers install it ( Drivers are located inside Flasher Folder ).
- After all Drivers are installed disconnect the phone.
- Click on SET MODEL Button and select : C3222W_PUNCH_WIFI_Setting_v00.mdl file.
- At the field Application binary file click on Browse and select : C3222WOPEN.ptt file.
- At the field TFS file click on Browse and select C3222Wxxxxx.tfs file.
- At the field CSC file click on Browse and select C3222WOxxxxx.csc file.
- Click on START button.
- Wait till the process finished.
- When all is done the program give you this : Slot freed for new download.
- Disconnect the phone and turn it on.
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-29-2011 11:26
HELP Dead 5130 v5.00 N.Schmetz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 03-08-2011 03:51
help! Dead 5110 v5.30 aklishin Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 04-04-2001 11:56
nokia 5110 dead alpha Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 02-28-2001 10:59
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 12-19-1999 21:30
Page generated in 0.58109 seconds with 11 queries
