Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 09-10-2009, 18:42   #1 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Thanks Meter: 4,965
SERVER STATUS - USE Panel V 2.3.0.6 - Upgrade/Installation/Support Server Problems
@ UFSx+HWK User
Post all your Upgrade/Installation/Support Server Problem Here.!!
HWK Upgrade Server Status:- Online
HWK Support Server Status:- Online
Note:-
  • Posts which Contains HWK HID Number will be Deleted/Suspended/Blocked on Server without any Notice.
  • Do not post your HWK HID in any Forum.
  • Do not use any 3rd party tools to Fix UFS or HWK problems. ex. reg, ufstool etc etc
  • Unexpected exception:box_auth error 1- Change Cable Or Box Damage
  • Authentication stage error: Error: Server returned unrecognized reply Use Latest Update :- http://forum.gsmhosting.com/vbb/f311...rrors-1216246/
  • XXXXX ... Please contact your reseller! Contact YOUR Reseller
  • Bad environment clean system from obsollete usb driver - Install latest USB drivers.
Munna.
The Following 795 Users Say Thank You to GsmMunna For This Useful Post:
Old 09-12-2009, 12:13   #2 (permalink)
rry
Member: 372620
Thanks Meter: 28
Why product supporter not answering
as seen this thread yesterdays problems were not answered yet, I am facing the similar problems as described in this thread so I don't want to write them again and again.
ONE THING I MUST WRITE HERE THAT MANY RURAL AREA CUSTOMERS ARE USING HWK BOX , THEY DON'T HAVE THE INTERNET CONNECTIONS ( TALKING ABOUT iNDIA ) AND THEY ARE HAPPY AND SATISFOIED CUSTOMERS OF HWK BOX AND THIS UPDATE REQUIRES UPDATE IN SYSTEM. PLS DO SOMETHING FOR RURAL CUSTOMERS
The Following 26 Users Say Thank You to rry For This Useful Post:
Old 09-12-2009, 12:13   #3 (permalink)
Member: 134761
Thanks Meter: 33
problem install hwk suite 2.009 ( install cannot continue aborting )
what problem with my installer , when try to install hwk suite support 2.0.0.9 no problem but when install hwk suite 2.0.0.9 show error " install cannot continue abortin " i used avg 8.5 antivirus and my os " window xp home edition sp 3 "i have already disable antivirus but still cannot install , thanks for help me
The Following 28 Users Say Thank You to CONG YANG For This Useful Post:
Old 09-12-2009, 13:03   #4 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Thanks Meter: 4,965
Most Of Rural area in India now have BSNL Internet Broadband services. also if we explain them to Have Internet Will help them.. Since all New Release need internet to download update's/update Firmware of box..!
Munna.
The Following 23 Users Say Thank You to GsmMunna For This Useful Post:
Old 09-12-2009, 13:06   #5 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Thanks Meter: 4,965
Arrow
Run Update Client an update your box One More time then install hwk suite all will be ok.
Munna.
The Following 22 Users Say Thank You to GsmMunna For This Useful Post:
Old 09-12-2009, 14:47   #6 (permalink)
Crazy Poster
Member: 238064
Thanks Meter: 70
HWK not update
I don't update my hwk adjunt log...I try several times and not update.
Upgrade log:
---------- HWK Update Client v 2.0.9.0 ----------
---------- HWK upgrade started:11/09/2009 17:30:08 ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 84939
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: UFS3
-- HWK ID :xxxxxxxxxxxxxxxxxx
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication successfull.
Checking upgrade client version...
Your upgrade client is up-to-date.
Upgrading HWK...
Error upgrading HWK: HWK UPDATE ERROR: 80
The Following 29 Users Say Thank You to elektra1980 For This Useful Post:
Old 09-12-2009, 15:53   #7 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,423
[QUOTE=elektra1980;4838958]
Upgrade log:
-- UFSx S/N : 8xxxx
-- Licence 5 : True
Upgrading HWK...
Are you using HWKBox?
Bcoz I have seen this kind of issue with many HWKBox.
If so, ask your reseller for replacement.
Br,
Shadab Ahmad
The Following 21 Users Say Thank You to [Shadab_M] For This Useful Post:
Old 09-12-2009, 16:06   #8 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,423
Arrow ATRz asking for activation string!
I had my HWK Box working fine with other softwares but when I try to run ATRz, it asked me for activation string.
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0 0
UFS_USB V2.8 (c) SarasSoft 2007.S/n: XXXXXX
HID:
HWK:
Licence Update Failed
I tried to Upgrade but problem not solved. So, I updated Firmware.
Now I don't have no more Upgrade log. If one provided, I will check it out.
Regards,
Shadab Ahmad
The Following 26 Users Say Thank You to [Shadab_M] For This Useful Post:
Old 09-12-2009, 17:04   #9 (permalink)
Crazy Poster
Member: 238064
Thanks Meter: 70
HWK not update
Thank for you reply, i used HWKufs Micro i had no problems with version 2.0.8.0 only after install 2.0.9.0
The Following 36 Users Say Thank You to elektra1980 For This Useful Post:
Old 09-12-2009, 17:21   #10 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,423
It happened while Upgrading with 2.0.9.0 just bcoz you tried to upgrade it with this version.
Before that if you had tried to Upgrade and your box had the same problem, you would face the same.
Br,
Shadab Ahmad
The Following 5 Users Say Thank You to [Shadab_M] For This Useful Post:
Old 09-12-2009, 17:39   #11 (permalink)
Crazy Poster
Member: 238064
Thanks Meter: 70
HWK not update
Before that the box worked perfectly, updated several times with the 2.0.8.0 version and never had a problem, just try to update with 2.0.9.0 the problems started.
The Following 4 Users Say Thank You to elektra1980 For This Useful Post:
Old 09-12-2009, 19:41   #12 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,423
There are not any issue with latest release.
Check for drivers, cable or try different port.
If nothing helps you out, just contact your reseller.
Br,
Shadab Ahmad
The Following 4 Users Say Thank You to [Shadab_M] For This Useful Post:
Old 09-12-2009, 19:43   #13 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Thanks Meter: 4,965
Arrow
Regards,
Shadab Ahmad
you can update your HWK Now..!
Munna.
The Following 4 Users Say Thank You to GsmMunna For This Useful Post:
Old 09-13-2009, 02:20   #14 (permalink)
Crazy Poster
Member: 449622
Thanks Meter: 15
Upgrade problem plz help
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/13/2009 6:45:29 AM ----------
-- UFSx S/N : 41881
-- Licence 5 : True
-- UFSx Vendor: TORNADO
- HWK ID : .......
The Following 11 Users Say Thank You to RAFIQMEER For This Useful Post:
Old 09-13-2009, 02:28   #15 (permalink)
Member: 904530
Thanks Meter: 506
must use 2.0.9.0
HWK Release 18/08/2009 - Discussion
The Following 3 Users Say Thank You to Major-T For This Useful Post:
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-16-2011 09:59
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.47226 seconds with 9 queries
