Box Firmware needs to be upgraded only if you have some problem with UFS firmware. You may move on bt only upgrading HWK with Update Client. Br, Shadab Ahmad |
Brainworks Problem Solved... seek and you shall find.. Thanks ***.. |
Br, Shadab Ahmad |
2 Attachment(s) Sir, my customer have problem , he already update hwk into suite 2.0.9 and when try to connect in dctx bb5 then appear error " none outhorized copy of software detect please use original install package " then try to repair install software by repair option cannot help, then when try to update again with update client 2.09 then appear " all ok,not necessary to update hwk ! You will loser a server log , proceed anyway " then i ask him to klik no first, so i post his problem in here , hope can get solution from supporter .... Thanks |
Munna. |
sir , still none outhorized copy of software,please use original install package " thanks |
Please help with this error I can not update my hwk, I have tried everything, please help me... Adjunt log Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:16/09/2009 8:10:58 ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 8---- -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID : A1.04-PRO1-xxxxxxxxxxxxxxxxxxx -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... Error upgrading HWK: HWK UPDATE ERROR: 80 |
micro err 20 solution Quote:
Munna. |
There is no reseller in my area. So i am unable to contact him ,I want to re open my hwk account , Pls help me on line to fix this prob . I,ll pay for this . |
UFS Instalation problem BAD ENVIRONMENT: CLEAR SYSTEM OF OBSOLATTE DRIVERS Pls, i need the solution quick. THANKS |
Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:17/09/2009 19:33:54 ---------- -- Target Id : XXXXXXX -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : XXXXX -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : XXXXXXXXXXXXXXXXX -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Error preparing connection to server! Please check your internet connection and try again. Cannot get valid data from server! Please check your internet connection and try again! Please Help I received HWKuFs Micro today???????? I'm using a proxy server. Could I use it??? |
............. cannot use proxy |
Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:9/18/2009 12:21:26 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : xxxxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TWISTER -- HWK ID : A1.04-PRO1-xxxxxxxxxx -- HWK Status : 1, DL: 8 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... HWK upgrade process completed. ---------- HWK upgrade finished:12:21:49 PM ---------- |
Pls is working on first pc i installed but i can not install the setup on second pc pls help fast..... |
