Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 08-07-2013, 07:45   #856 (permalink)
Member: 1158830
Thanks Meter: 2
Box: 1 Location: 803 Serial: 76091
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 76091
HID: xxxx, HWK: A1.04-PRO1
BOX_AUTH_ERROR: 1111
BOX: CORRUPTED or MANIPULATED
Bad IX: ABCD
Failed: -5
Your IP: 1.22.233.26
Support: Account Ok
Something Wrong, Try to Use [Update Box]
HID: xxxxxxx, HWK: A1.04-PRO1
Bad IX: ABCD
Failed: -5
Support: Account Ok
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 76091
NVML: OK
plz help me with this
Old 08-07-2013, 07:58   #857 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
Bad IX: ABCD
Failed: -5
Support: Account Ok
Bad IX: ABCD
Failed: -5
Support: Account Ok
REST: Ok
NVML: OK
If you press "Check Box" does it show as ok now?
Old 08-07-2013, 10:53   #858 (permalink)
Member: 11819
Thanks Meter: 4
HWK Not Authorised
Hi,
I have a GENUINE box. it has not been updated for a while, in fact it was not updated on the last release. I have 2 boxes and did not need this at the time. Have now tried to update with latest release and get the following
App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft
Box: 1 Location: 545 Serial: 157**
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 15744
HID: 34286637002*****, HWK: A1.04-PRO1
BOX_AUTH_ERROR: 9990
HWK: NOT AUTHORISED, Update Box
Bad IX: ABCD
Failed: -6
Your IP: 94.192.170.168
Support: Account Ok
Support: Account Ok
REST: Ok
UFSx: UFS2 SarasSoft, USB S/N: 15744
NVML: OK
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 15744
LIC5: True
BOXK: 0
Authentication successfull.
Upgrade client is up-to-date.
Upgrade process completed.
Box: 1 Location: 545 Serial: 15744
Bad IX: ABCD
Failed: -6
Support: Account Ok
Can you help
Thanks
Old 08-07-2013, 10:54   #859 (permalink)
Member: 4042
Your HWK is clone.
Old 08-07-2013, 12:09   #860 (permalink)
javokhir's Avatar
Member: 1020688
Thanks Meter: 107
Can you write info or creat a new thread about new 2.3.0.1 update suite, how to tick all & untick all
Old 08-07-2013, 13:05   #861 (permalink)
Member: 4042
http://forum.gsmhosting.com/vbb/f311...rrors-1216246/
Old 08-07-2013, 13:43   #862 (permalink)
kaller1's Avatar
Member: 1761928
Sonork: 100.1626169
Thanks Meter: 804
Originally Posted by Odia The Ultimate View Post
Your HWK is clone.
It would be worth it in a change error codes, as most users are not aware of the error codes. (example BOX_AUTH_ERROR: 9990 = BOX_AUTH_ERROR: CLONED HWK - NOT UPDATABLE!)
I think this should be done as users unable to see clearly.
or
you make a table of error codes, and must be placed in the first post of the topic.
br.
The Following 3 Users Say Thank You to kaller1 For This Useful Post:
Old 08-07-2013, 20:19   #863 (permalink)
Member: 4042
or
br.
Is good idea, but since 99.9999% just post without reading first, it would not really make any difference.
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 08-07-2013, 20:42   #864 (permalink)
kaller1's Avatar
Member: 1761928
Sonork: 100.1626169
Thanks Meter: 804
I agree with you, but there is always the user's responsibility to properly check if support is given....and I think, sooner or later, posting useless logs also significantly fewer.
br.
The Following User Says Thank You to kaller1 For This Useful Post:
Old 08-08-2013, 10:19   #865 (permalink)
mayank.gupta's Avatar
Member: 966792
Sonork: 100.1602610
Thanks Meter: 199
Box: 1 Location: 65 Serial: 78036
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78036
HID: BB2932B-------, HWK: A1.04-PRO1
LIC: True
BoxStat : Ok
Your IP: 123.237.124.219
Support: Account Ok
problum
but softwear install error massage
can't read internet stream. internatreadfilestream failed
pl help
Old 08-08-2013, 10:29   #866 (permalink)
Member: 4042
http://forum.gsmhosting.com/vbb/9625060-post846.html
Old 08-08-2013, 16:17   #867 (permalink)
javokhir's Avatar
Member: 1020688
Thanks Meter: 107
I mean, when you go to software, after checking server, files come out & they are all ticked, how to uncheck all if I want to install one of them?
Old 08-09-2013, 14:22   #868 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
It means your UFS box is not as it should be, the new panel performs more checks than previous software.
means more clicks on " update box " option or what .. pls clarify sir.....
Old 08-09-2013, 15:37   #869 (permalink)
AgicAga's Avatar
Member: 866455
Sonork: SAMSUNG CPID ONLINE
Thanks Meter: 579
how soloved this eror
[IMG] Uploaded with ImageShack.us[/IMG]
The Following User Says Thank You to AgicAga For This Useful Post:
Old 08-09-2013, 16:37   #870 (permalink)
Member: 4042
Your UFSx box is not original or has somehow been modified by none official software.
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.26698 seconds with 11 queries
