Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 11-07-2013, 00:57   #901 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 23,367
Anyone experiencing the panel hanging on check box or update box, please post info on your UFSx type, PCs OS, CPU and USB Controller.
The Following 9 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 11-07-2013, 03:21   #902 (permalink)
Member: 2059486
Thanks Meter: 3
panel hanging on check box or update box amd cpu
my pc name is amd 140 sempron {tm} 140 processor
2.71 GHz, 1.87 of ram usb 2.0 Controller.
hwk usf-3 not update or not work plesss help
Old 11-07-2013, 10:45   #903 (permalink)
Member: 4042
Need actual USB controller make and model.
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 11-13-2013, 17:11   #904 (permalink)
KARNVIR's Avatar
Member: 741065
Thanks Meter: 118
My box is working fine but hangs at last :(
Hello Mr.Odia thx for this wonderful flasher and unlocker called HWK + UFS.....
My problem is this that my hwk+ufs-5plus works connects and works perfect ....... but when i finished my work like flashing and unlocking and press disconnect Button on upper left corner then it hangs and when i remove cable (pc cable) from ufs then its fine again ........
well i was facing this problem from approx last year .....and according to my experience this issue is due to drivers ....... i solved this problem with old drivers (from 2.10) and it was working perfect wid that 2.10 drivers till 2.3.0.0.....
and few days ago i installed 2.3.0.3 and now when i try to install that old drivers (2.10 which was working fine till 2.3.0.0) then control pannel says bad environment ......
plz solve my this problem .....
sorry for my bad English .. hope u understand my problem ....
here is screenshot of hanged software ......
Old 11-15-2013, 12:47   #905 (permalink)
Member: 1436004
Sonork: ednietoz
dear sir...how i can get sams tool v2.3.0.1? i try to update with ufs panel 2.3.0.2 but server is unrecognized reply.....when i used ufs panel 2.3.0.3 i get sams 2.3.0.2.....is ufs panel 2.3.0.2 stil support?
Old 11-15-2013, 13:26   #906 (permalink)
Member: 1344629
Thanks Meter: 20
App: UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft
CPU: AuthenticAMD
Platform: Windows NT 6.1 (Build 7600 )
Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
C:\Program Files
C:\Program Files\Common Files
Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix
always hang while updating...
please fix mr odia!
The Following User Says Thank You to john_cover For This Useful Post:
Old 11-16-2013, 16:05   #907 (permalink)
Member: 4042
please fix mr odia!
Did you read this?
SERVER STATUS - USE Panel V 2.3.0.5 - Upgrade/Installation/Support Server Problems
or just walk around blind and open m outh with bla bla bla?
Old 11-16-2013, 20:28   #908 (permalink)
Member: 546871
Thanks Meter: 2
please help
my mother board is asus
processor amd II x4 965 3.40
ram 4gb
windows 7 32 bit
when i update hwk it gets hang on check box or even update
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 54003
LIC: True
None Authorised Copy of Software Detected, Reinstall
HWK: NOT AUTHORISED, Update Box
Bad IX: 1111
Failed: 102
Your IP: 117.195.110.173
Support: Bad HID, Cannot Access Suport
Something Wrong, Try to Use [Update Box]
(and gets hang)
The Following User Says Thank You to ayaz_hasham For This Useful Post:
Old 11-18-2013, 13:16   #909 (permalink)
Member: 58263
Thanks Meter: 19
PC nr 1:
VIA USB ENHANCED Host controller
AMD Athlon 64 processor 3000+
WinXP SP3
UFS-3 TORNADO
PC nr 2:
ALi PCI to USB Open Host controller
mobile AMD Athlon processor XP2600+
WinXP SP3
UFS-3 TORNADO
Scan and update problem!
B.R.
The Following User Says Thank You to neper For This Useful Post:
Old 11-20-2013, 08:37   #910 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 891
my cpu amd athlon 64 x2 4200+
processor 2.20 1 gb ram
Old 11-24-2013, 14:04   #911 (permalink)
ChouChou's Avatar
Member: 53113
Thanks Meter: 16
Please help.
Its long time ago i have uset my box, and now i wont to use it, and i have to update it and i use UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft
But i get this error.
Box: 1 Location: 273 Serial: XXXXXX
UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXXXX
HID: XXXXXXXXXXXXX, HWK: A1.04-PRO1
BOX_AUTH_ERROR: 9990
HWK: XXXXXXXXXXXXX NOT AUTHORISED, Update Box
Bad IX: ABCD
Failed: -6
Your IP: XXXXXXXXXXXXXX
Support: Account Ok
Old 11-26-2013, 04:19   #912 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 149
Originally Posted by ChouChou View Post
Please help.
Bad IX: ABCD
Failed: -6
Support: Account Ok
this is your answer
Originally Posted by kaller1 View Post
It would be worth it in a change error codes, as most users are not aware of the error codes. (example BOX_AUTH_ERROR: 9990 = BOX_AUTH_ERROR: CLONED HWK - NOT UPDATABLE!)
I think this should be done as users unable to see clearly.
or
you make a table of error codes, and must be placed in the first post of the topic.
br.
Originally Posted by Odia The Ultimate View Post
Is good idea, but since 99.9999% just post without reading first, it would not really make any difference.
msattar123
The Following User Says Thank You to msattar123 For This Useful Post:
Old 11-26-2013, 07:03   #913 (permalink)
ChouChou's Avatar
Member: 53113
Thanks Meter: 16
But iam 100% sure that my HWK is not clone, i have never had problem whit Update my box before.
And my HWK is one off the first ones I bay, win HWK comes out, and that time I bay it from a HWK reseller.
The Following User Says Thank You to ChouChou For This Useful Post:
Old 11-26-2013, 13:52   #914 (permalink)
Member: 4042
Old 11-27-2013, 09:32   #915 (permalink)
ChouChou's Avatar
Member: 53113
Thanks Meter: 16
Hello sir,
I did use the latest one V 2.3.0.3, and i have try many time to upgrade the box, and now the server write that there is no more logs
Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller!
As i sad before i have never had a problem before whit upgrade my box, but its long time ago i have uset my box.
Can it be that the upgrade server have blocked my HWK Id number?
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-21-2014 04:52
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 26 09-25-2012 02:41
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-16-2011 09:59
Powered by Searchlight © 2014 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.38764 seconds with 9 queries
