Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 01-10-2014, 11:39   #931 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
her we go
http://forum.gsmhosting.com/vbb/7009460-post1.html
The Following 6 Users Say Thank You to lahdache For This Useful Post:
Old 01-11-2014, 02:33   #932 (permalink)
resident2011's Avatar
Member: 1530237
Sonork: 100.1614868
Thanks Meter: 5,598
error Update New HWK
Need to solve this error!!! always hangs at this point [Wait Getting Data]
The Following 4 Users Say Thank You to resident2011 For This Useful Post:
Old 01-11-2014, 23:26   #933 (permalink)
Member: 1344629
Thanks Meter: 24
same problem always stop on this getting data..
The Following 2 Users Say Thank You to john_cover For This Useful Post:
Old 01-15-2014, 12:44   #934 (permalink)
Member: 1032503
Thanks Meter: 16
Mr. Odia ,
actually as per my observation your installer is ok... please read following:-
1. i installed fresh winxp sp2 in my old celeron compaq laptop. Then ufs installer (latest)
i.e. 2.3.0.4 . then attached my hwkufs device , then updated d drivers in c:\progfiles\sarasoft\usf\ufs usb drivers.
2. then i updated my dongle using bsnl broadband...
3. My dongle was updated successfully n in working.
4. Then i attached a 2nd manipulated dongle and that too was repaired aautomatically and successfully upgraded in workng condition.
Now problem...
1. Now when i try 2 update my dongle in my official desktop ( AMD Phonom-II quadcore , 2gb ram) , it gets hang on " getting data ".
2. I am not using broadband here but mobile data connection which used to update earlier.
3. i was trying to update earlier using 2.3.0.1 \ 2.3.0.2\ 2.3.0.4
I think the whole prob lies with usb drivers... coz i hav tested it many times that once u
hav used an older usb driver, no matter from where or what method u use to delete\uninstall that driver, it wont work untill\unless u install a fresh copy of windows...
So plz 1st we need a universal usb driver \ an installer that may automatically erase all older drivers, make the system clean n then install a fresh usb driver (updated) so that none faces so many probs.
Also note that maximum users of hwk ( especially in India ) are not highly literate regarding computers ( softwares n all). All they need is easy hassle free installation.
Also half users use mobile internet to update\ upgrade, so if your servers could support
slow 2g connections, then it would b still be nothing better than hwk ufs... as for me it is still d most reliable...
The Following User Says Thank You to naughtybaba For This Useful Post:
Old 01-16-2014, 20:25   #935 (permalink)
mihaser's Avatar
Member: 112820
Thanks Meter: 75
Question
Originally Posted by akkueko View Post
it's always none authorised copy.......
tired bro.....does anyone solved this problem??????
I think its problem with direct access to windows registry. I`ve compared my reg.backup from winXP and win7 and its different. Thats why its always wrong software. So, dear mr.Odia, fix your problem, please! Hwk software was always the best for us!
The Following User Says Thank You to mihaser For This Useful Post:
Old 01-17-2014, 13:18   #936 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
We do not use direct access to registry, but via the windows API, registry data can be different between OS, even OSs on the same PC. As always we are looking into the issue and will fix ASAP.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 01-17-2014, 13:21   #937 (permalink)
Member: 4042
Anyone experiencing the panel hanging on getting data, should try to use a different USB port on a different USB HUB if possible, again we are working to resolve this issue, but none of our test PCs have this issue, so it's proving very difficult to track down.
The Following 4 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 02-10-2014, 06:32   #938 (permalink)
Member: 25327
Hi
All panels hang up after disconnect buton
Control Panel hang up on checking server
If manually disconnect usb cable, everithing is ok and I can close panels.
My PC:
Motherboard Name Gigabyte GA-MA790X-UD4
CPU QuadCore AMD Phenom II X4 Black Edition 940, 3000 MHz (15 x 200)
South Bridge: AMD SB750
OS Name Microsoft Windows 7 Professional
OS Kernel Type Multiprocessor Free (64-bit)
OS Version 6.1.7601
OS Service Pack Service Pack 1
OS Installation Date 2014-02-07
Prucho
Old 02-10-2014, 13:47   #939 (permalink)
Member: 4042
Almost complete info supplied to help, just missing which model of UFSx you have?
Old 02-11-2014, 16:59   #940 (permalink)
Member: 25327
Originally Posted by green bird View Post
UFS-3 TORNADO original saras soft
on the box motheborad: UFS3s (c)2004 SarasSoft
with HWK V1.0 SarasSoft 2004
prucho
The Following User Says Thank You to prucho For This Useful Post:
Old 02-13-2014, 15:09   #941 (permalink)
Member: 4042
Can you try attach a USB flash drive to box front USB port and see if the hang issue is gone.
The Following 3 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 02-13-2014, 23:35   #942 (permalink)
Member: 25327
yes. now , when the flashdisk is non stop connected to the front or rear usb port, box working correctly
sollution is surprising me
I think it is a half-measure, now everything works fine .I have one question, if will be carried out further work on the driver ,so box to work without pendrive ?
prucho
Old 02-14-2014, 06:00   #943 (permalink)
Member: 1849222
Thumbs up wow it works
I dont know how, but when i attach a flash drive in my tornado, the panel doesn't hang anymore and it works. This is surprising.
But the panel should be updated as fast as possible because lot of users are in problem due to this.
Old 02-15-2014, 15:36   #944 (permalink)
Member: 4042
prucho
Thank you for confirmation, was only a test we not expect this to be any type of resolution, at the moment we are unable to locate the issue, so we think is best to allow older drivers which do not give this hang issue, until we can find the problem and have the issue fixed, the drivers we use are from FTDI and out of our control.
Old 02-16-2014, 02:56   #945 (permalink)
mr. uem's Avatar
Member: 1035137
Thanks Meter: 72
Dear Evryone who had a problem with updating box's. To Day I solve my problem:
This is a report:
Box: 1 Location: 20 Serial: 74XXX
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 XX XX
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 74XXX
HID: AF2727XXXXXXXXXC, HWK: XX.XX-PRO1
HWK: AF2727XXXXXXXXXC NOT AUTHORISED: 17, 3E, Update Box
Your IP: 112.XXX.XX.XX
Support: Account Ok
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 74XXX
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 74XXX
LIC5: True
BOXK: 0
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 XX X 10
HID: AF2727XXXXXXXXXC, HWK: A1.04-PRO1
Authentication successfull.
Upgrade client is up-to-date.
Upgrade process completed.
Try this to updating your UFS Flash Box:
1. Do Check Box
2. Do Update Box
3. Every time UFS Panel Hang On Check Box Or Update Box, Try to Plug in and plug out FLASHDISK or Card reader or anythink you have to plug in to another unusable USB slot.
4. Hang isues will gone.
5. Makesure Server Online before updating your box
Mr. Uem
The Following 9 Users Say Thank You to mr. uem For This Useful Post:
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.30043 seconds with 10 queries
