Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 03-10-2014, 07:00   #946 (permalink)
Member: 904530
Thanks Meter: 517
is link for super-smarts
press it, press it, press it
do it with mouse !
do not press if hold not a mouse (rat for example)
http://support.sarunasoftware.com/he...PANEL_2305.exe
The Following 9 Users Say Thank You to Major-T For This Useful Post:
Old 03-10-2014, 12:02   #947 (permalink)
Member: 2082450
Thanks Meter: 1,454
Every body now don't ask for the old version, there is a new version 2.3.0.5 which have no updating problem.
Success fully installed hwk suite and update it.
The Following 2 Users Say Thank You to chandanps18 For This Useful Post:
Old 03-10-2014, 12:24   #948 (permalink)
Member: 85464
Sonork: 100.1620941
Thanks Meter: 5
Hi everyone
Still need help updating my box.
Using the new update tool but can't do
Freeze in checking server! And i can't update box.
Anyone can help me?
The Following 2 Users Say Thank You to elensolia For This Useful Post:
Old 03-10-2014, 13:48   #949 (permalink)
Member: 780195
Thanks Meter: 24
My os is windows 8 32bit first time it works but when I disconnect box and reconnect again it didn't work then I try to update with latest support suite it goes off mode both update button why help me
The Following 3 Users Say Thank You to sunil_karwi For This Useful Post:
Old 03-10-2014, 14:32   #950 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
Originally Posted by elensolia View Post
Hi everyone
Anyone can help me?
Read this post from top to bottom:-
http://forum.gsmhosting.com/vbb/f311.../#post10155009
The Following 4 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 03-10-2014, 14:33   #951 (permalink)
Member: 4042
Allow panel access through firewall.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 03-11-2014, 04:02   #952 (permalink)
Member: 893736
Thanks Meter: 7
Have planned not to sell our old ufs activation and to use the new android module. Should consider that possibility, many of us need it.
A thousand blessings.
The Following User Says Thank You to jairotapia56 For This Useful Post:
Old 03-11-2014, 09:57   #953 (permalink)
Member: 1286072
Thanks Meter: 50
hi sir
i install panel 2.3.0.5 and update box and software
all install ok but i open any software icon its show this
i press ok then its open
whats problem
Old 03-11-2014, 12:27   #954 (permalink)
Member: 4042
It's impossible since UFSx not have required hardware, you would just get flashing and for that you may as well use Odin.
Old 03-11-2014, 13:33   #955 (permalink)
Member: 829762
Sonork: rehan
Thanks Meter: 6
HID: 23930D2043600090, HWK: A1.04-PRO1
LIC: True
None Authorised Copy of Software Detected, Reinstall
Bad IX: AB1D
Failed: 100
The Following User Says Thank You to rehan25 For This Useful Post:
Old 03-11-2014, 13:40   #956 (permalink)
Member: 2082450
Thanks Meter: 1,454
LIC: True
Bad IX: AB1D
Failed: 100
Bro, tell me ur hwk suite version os and os bit for better solution.
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 03-11-2014, 14:37   #957 (permalink)
Member: 1021853
Thanks Meter: 27
always connect ufs stuck in blue screeen
The Following User Says Thank You to sunnyriaz For This Useful Post:
Old 03-11-2014, 14:55   #958 (permalink)
Member: 2082450
Thanks Meter: 1,454
Does ur pc hangs and goes to blue screen????
What is urpc configuration and what is the os do u use????
Old 03-11-2014, 21:01   #959 (permalink)
Member: 4042
Originally Posted by sha aslam View Post
hi sir
whats problem
It's because you not have the Nokia WinUSB drivers installed, this is only needed for Infineon phones.
Old 03-12-2014, 16:56   #960 (permalink)
Member: 518053
Thanks Meter: 18
for me the same, last update with no problems, whith this everytime server communication error
The Following User Says Thank You to i-punkt For This Useful Post:
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.25542 seconds with 10 queries
