10-11-2009, 18:02 | #121 (permalink) | |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
Munna. | |
The Following User Says Thank You to GsmMunna For This Useful Post: |
10-12-2009, 15:47 | #123 (permalink) |
No Life Poster Join Date: Jan 2009 Location: SPAIN
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | probleme with hwk instalation whene i try to run hwkupdate upgrade client i get this eroor bad Environment:-1-bad library clean system from obsollete usb drivers plz help |
10-12-2009, 17:48 | #124 (permalink) | |
Solution:- If above not work Simple Search ufs, HWK & Saras name folder's and delete them (Make Sure Before Delete Check Folder & Files is Same Above) now Restart Pc
All Fix Now..! Munna. Last edited by GsmMunna; 10-12-2009 at 17:59. | |
10-12-2009, 18:08 | #125 (permalink) |
Insane Poster Join Date: Apr 2008
Member: 757975 Status: Offline Thanks Meter: 7 | hwk setup suite cannot install. i trial to install my ufshwk, it keep say, install not authorised, you have not update with the latest update client.clientCompare. i need help. |
10-12-2009, 19:26 | #126 (permalink) | |
Munna. | |
10-13-2009, 23:29 | #131 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | For a very long time I have not used this box (Its a HWK Micro) But now I want to start using it. The box updates ok, with v9 support software, BUT when I click to Go To support, I get error message. Also I cannot run the softwares. Here is Log: Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:10/13/2009 2:48:51 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 78137 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : deleted by me -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. Pls Its more than 2 years I have not been using SarasSoft, But I want to start again. I need all the help I can get |
10-14-2009, 01:07 | #132 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 878230 Status: Offline Thanks Meter: 33 | Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:08/10/2009 01:43:30 ص ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : xxxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID : A1.04-PRO1-xxxxxxxxxxxxxxxxxxx -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:Account for this HWK module does not exist on server. Please contact your reseller! hi all firest that is my problem i trayed alot of times many many but still the same probleme please help me i hav good cable good pc good windows change it alot of times same probleme disable antivirus all the time same probleme i have ORIGINAL HWKufs Micro from fonec egypt (el sabahi) i didnot work with it befor 1 year ago same probleme only firest time with OLD version ufs thanks.... |
The Following User Says Thank You to ashraf77160 For This Useful Post: |
10-14-2009, 01:11 | #133 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ ashraf77160 Code: Authentication stage error: Server reported error: Account for this HWK module does not exist on server. Please contact your reseller! Code: Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. |
10-14-2009, 03:35 | #134 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1082148 Status: Offline Thanks Meter: 1 | -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use Update Firmware to authorise UFS. -- UFSx Device: UFS-NBOX SarasSoft, USB S/N: 106283 -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use Update Firmware to authorise UFS ! -- Target Id : 62 CF 0 0 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 106283 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: N-BOX can you help me... |
10-14-2009, 06:45 | #135 (permalink) | |
Simply Update You hwk all fix..! Munna. | |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
