Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 09-18-2009, 18:05   #46 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Originally Posted by damabib View Post
Pls is working on first pc i installed but i can not install the setup on second pc pls help fast.....
You have used Upgrade Log so either you have to wait for More Upgrade Logs or just Contact Your Reseller.
Br,
Shadab Ahmad
Old 09-19-2009, 15:02   #47 (permalink)
Member: 25004
Thanks Meter: 10
hwk upgrade
Mine worked fine after this.
1. connect hwk directly to the motherboard not through any usb hub
run the update and then after correct update.
2. install hwk suite
3. run.
if this fails the you have to update the firmware follow the sticky on box auth error.
thanks for support
Old 09-19-2009, 17:20   #48 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
Br,
Shadab Ahmad
i was told by a frieend to wait for 24hrs is almost now no show yeet..br
Old 09-19-2009, 20:17   #49 (permalink)
Member: 235759
Thanks Meter: 162
Hello again please help????
I'm not using now a proxy, in fact I'm using another PC, but now I got this, when soft is trying to get HWK information:
Error connecting UFS:
HWK LOGIN ERROR: -4
Please I try to update yesterday buy using a proxy, but I couldn't. Today I got this error. Why????
The Following User Says Thank You to rmenganag For This Useful Post:
Old 09-20-2009, 18:42   #50 (permalink)
rockgsm's Avatar
Member: 420862
Thanks Meter: 51
Question hwk update ok 2.0.9 but problem after system format
hello everyone ,
i update hwk 2.0.9 on my pc it was working fine but my system went down and i had to format my pc but now when i install setup it says
non authorised software use orignal package ?
pl help
Old 09-21-2009, 01:54   #51 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Here working OK, check your internet conection, firewall, antivirus, etc....
-- UFSx Device: UFS3 SarasSoft, USB S/N: xxxxxx
-- Target Id  : xxxxxxxx
-- UFSx Boot  : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N   : XXXXX
-- Features   : 00000001
-- Licence 5  : True
-- UFSx Vendor: N-BOX
-- HWK ID     : A1.04-PRO1-XXXXXXXXXXXXXXXX
-- HWK Status : 1, DL: 9
Old 09-21-2009, 12:45   #52 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
you have used upgrade log so either you have to wait for more upgrade logs or just contact your reseller.
Br,
shadab ahmad
i try today the server was ok and upgraded thanks...
Old 09-21-2009, 13:19   #53 (permalink)
Member: 235759
Thanks Meter: 162
@GsmMunna, shadab ahmad or anyother master, please help????
Hello again, please help????
HWK LOGIN ERROR: -4
If yesterday the soft get HWK information OK OK. Why I get this king of error now? I just try to use soft and box in another PC ??????
Old 09-21-2009, 14:03   #54 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,053
Arrow
HWK LOGIN ERROR: -4
Press OK & repeat Process to update hwk Will be fix Don't Close Client..!
Munna.
The Following User Says Thank You to GsmMunna For This Useful Post:
Old 09-21-2009, 16:47   #55 (permalink)
Member: 1124377
i was thinkin to find the solution for unistallation of 02.08 as mentioned in above thread, but since there is not a single suggestion, i am also :-(
Old 09-21-2009, 18:16   #56 (permalink)
Member: 235759
Thanks Meter: 162
@GsmMunna
Thanks for your rapid answer, but as you see in the image. After OK, Start HWK Update Button is disable, so I can not continue the process.
Even if I click back without close client it shows me again the error and the Start HWK Update button disable again.
I uninstall Client software and reinstall it but still:
HWK LOGIN ERROR: -4
Thanks but please help???????????? I'm new at using this box, in fact I can't use it yet.
Old 09-21-2009, 19:11   #57 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,053
Arrow
have you try to change USB Cable..! act in my Case i run client an next it shows me Same error now i press Back an again Press next All was Fixed..!
Can you Provide Reseller Details & Purchase Date in pm ?
Munna.
Old 09-22-2009, 20:25   #58 (permalink)
Registered User
Member: 7641
Thanks Meter: 26
JC !!!!!!!
THIS IS OUT OF MIND !
- How to use hwk box on another computer ?
- How to install HWK Setup on new formatted computer if I have already updated box ?
- Need to start update again on new computer, but no more logs ?
Where is support team to explain this and what to do ?
Please don't send me to reseller. His gone few years a go. Car accident!
Old 09-22-2009, 20:31   #59 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Originally Posted by djanib View Post
JC !!!!!!!
For first two questions, you need to upgrade your HWK even if UC told you no need to upgrade.
For the third question, you need to wait to get one more upgrade log on server.
I think there is nothing to go out of mind
Br,
Shadab Ahmad
Old 09-22-2009, 20:41   #60 (permalink)
Registered User
Member: 7641
Thanks Meter: 26
Ok!
I have Notebook here and big comp, where I have installed working HWK software. Urgently I have to go on another location to make lot of phones. It is not possible to disconnect all connected cables from my big computer.
Notebook is only options. HOW TO INSTAL HWK ON NOTEBOOK AT THIS MOMENT ????
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.27543 seconds with 11 queries
