error Update New HWK http://imagizer.imageshack.us/v2/800...0/547/oqaa.jpg Need to solve this error!!! always hangs at this point [Wait Getting Data] |
Mr. Odia , actually as per my observation your installer is ok... please read following:- 1. i installed fresh winxp sp2 in my old celeron compaq laptop. Then ufs installer (latest) i.e. 2.3.0.4 . then attached my hwkufs device , then updated d drivers in c:\progfiles\sarasoft\usf\ufs usb drivers. 2. then i updated my dongle using bsnl broadband... 3. My dongle was updated successfully n in working. 4. Then i attached a 2nd manipulated dongle and that too was repaired aautomatically and successfully upgraded in workng condition. Now problem... 1. Now when i try 2 update my dongle in my official desktop ( AMD Phonom-II quadcore , 2gb ram) , it gets hang on " getting data ". 2. I am not using broadband here but mobile data connection which used to update earlier. 3. i was trying to update earlier using 2.3.0.1 \ 2.3.0.2\ 2.3.0.4 I think the whole prob lies with usb drivers... coz i hav tested it many times that once u hav used an older usb driver, no matter from where or what method u use to delete\uninstall that driver, it wont work untill\unless u install a fresh copy of windows... So plz 1st we need a universal usb driver \ an installer that may automatically erase all older drivers, make the system clean n then install a fresh usb driver (updated) so that none faces so many probs. Also note that maximum users of hwk ( especially in India ) are not highly literate regarding computers ( softwares n all). All they need is easy hassle free installation. Also half users use mobile internet to update\ upgrade, so if your servers could support slow 2g connections, then it would b still be nothing better than hwk ufs... as for me it is still d most reliable... |
Anyone experiencing the panel hanging on getting data, should try to use a different USB port on a different USB HUB if possible, again we are working to resolve this issue, but none of our test PCs have this issue, so it's proving very difficult to track down. |
2 Attachment(s) Hi All panels hang up after disconnect buton Control Panel hang up on checking server If manually disconnect usb cable, everithing is ok and I can close panels. My PC: Motherboard Name Gigabyte GA-MA790X-UD4 CPU QuadCore AMD Phenom II X4 Black Edition 940, 3000 MHz (15 x 200) South Bridge: AMD SB750 OS Name Microsoft Windows 7 Professional OS Kernel Type Multiprocessor Free (64-bit) OS Version 6.1.7601 OS Service Pack Service Pack 1 OS Installation Date 2014-02-07 BR Prucho |
5 Attachment(s) Quote:
on the box motheborad: UFS3s (c)2004 SarasSoft with HWK V1.0 SarasSoft 2004 BR prucho |
sollution is surprising me I think it is a half-measure, now everything works fine .I have one question, if will be carried out further work on the driver ,so box to work without pendrive ? BR prucho |
wow it works Quote:
But the panel should be updated as fast as possible because lot of users are in problem due to this. |
Dear Evryone who had a problem with updating box's. To Day I solve my problem: This is a report: Box: 1 Location: 20 Serial: 74XXX UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 XX XX UFS_USB V2.8 (c) SarasSoft 2007., Sn: 74XXX HID: AF2727XXXXXXXXXC, HWK: XX.XX-PRO1 HWK: AF2727XXXXXXXXXC NOT AUTHORISED: 17, 3E, Update Box Your IP: 112.XXX.XX.XX Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 74XXX NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 74XXX LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 XX X 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 74XXX HID: AF2727XXXXXXXXXC, HWK: A1.04-PRO1 HWK: AF2727XXXXXXXXXC NOT AUTHORISED: 17, 3E, Update Box Authentication successfull. Upgrade client is up-to-date. Upgrade process completed. Try this to updating your UFS Flash Box: 1. Do Check Box 2. Do Update Box 3. Every time UFS Panel Hang On Check Box Or Update Box, Try to Plug in and plug out FLASHDISK or Card reader or anythink you have to plug in to another unusable USB slot. 4. Hang isues will gone. 5. Makesure Server Online before updating your box BR Mr. Uem |
