09-10-2009, 18:42 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems Post all your Upgrade/Installation/Support Server Problem Here.!! HWK Upgrade Server Status:- Online HWK Support Server Status:- Online - Maint. Note:-
The Following 855 Users Say Thank You to GsmMunna For This Useful Post: |
09-12-2009, 12:13 | #2 (permalink) |
Major Poster Join Date: Oct 2006
Member: 372620 Status: Offline Thanks Meter: 38 | Why product supporter not answering as seen this thread yesterdays problems were not answered yet, I am facing the similar problems as described in this thread so I don't want to write them again and again. ONE THING I MUST WRITE HERE THAT MANY RURAL AREA CUSTOMERS ARE USING HWK BOX , THEY DON'T HAVE THE INTERNET CONNECTIONS ( TALKING ABOUT iNDIA ) AND THEY ARE HAPPY AND SATISFOIED CUSTOMERS OF HWK BOX AND THIS UPDATE REQUIRES UPDATE IN SYSTEM. PLS DO SOMETHING FOR RURAL CUSTOMERS |
The Following 36 Users Say Thank You to rry For This Useful Post: |
09-12-2009, 12:13 | #3 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 45
Member: 134761 Status: Offline Thanks Meter: 40 | problem install hwk suite 2.009 ( install cannot continue aborting ) what problem with my installer , when try to install hwk suite support 2.0.0.9 no problem but when install hwk suite 2.0.0.9 show error " install cannot continue abortin " i used avg 8.5 antivirus and my os " window xp home edition sp 3 "i have already disable antivirus but still cannot install , thanks for help me |
The Following 35 Users Say Thank You to CONG YANG For This Useful Post: |
09-12-2009, 13:03 | #4 (permalink) | |
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
Munna. | |
The Following 30 Users Say Thank You to GsmMunna For This Useful Post: |
09-12-2009, 13:06 | #5 (permalink) | |
Munna. | |
09-12-2009, 14:47 | #6 (permalink) |
Crazy Poster Join Date: Feb 2006
Member: 238064 Status: Offline Thanks Meter: 88 | HWK not update I don't update my hwk adjunt log...I try several times and not update. Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:11/09/2009 17:30:08 ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 84939 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID :xxxxxxxxxxxxxxxxxx -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... Error upgrading HWK: HWK UPDATE ERROR: 80 |
The Following 37 Users Say Thank You to elektra1980 For This Useful Post: |
09-12-2009, 15:53 | #7 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | [QUOTE=elektra1980;4838958] Quote:
Bcoz I have seen this kind of issue with many HWKBox. If so, ask your reseller for replacement. Br, Shadab Ahmad | |
The Following 27 Users Say Thank You to [Shadab_M] For This Useful Post: |
09-12-2009, 16:06 | #8 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | ATRz asking for activation string! I had my HWK Box working fine with other softwares but when I try to run ATRz, it asked me for activation string. Quote:
Now I don't have no more Upgrade log. If one provided, I will check it out. Regards, Shadab Ahmad | |
The Following 31 Users Say Thank You to [Shadab_M] For This Useful Post: |
09-12-2009, 17:04 | #9 (permalink) |
Member: 238064 Status: Offline Thanks Meter: 88 | HWK not update Thank for you reply, i used HWKufs Micro i had no problems with version 2.0.8.0 only after install 2.0.9.0 |
The Following 41 Users Say Thank You to elektra1980 For This Useful Post: |
09-12-2009, 17:21 | #10 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Before that if you had tried to Upgrade and your box had the same problem, you would face the same. Br, Shadab Ahmad | |
The Following 10 Users Say Thank You to [Shadab_M] For This Useful Post: |
09-12-2009, 17:39 | #11 (permalink) |
Member: 238064 Status: Offline Thanks Meter: 88 | HWK not update Before that the box worked perfectly, updated several times with the 2.0.8.0 version and never had a problem, just try to update with 2.0.9.0 the problems started. |
The Following 9 Users Say Thank You to elektra1980 For This Useful Post: |
09-12-2009, 19:41 | #12 (permalink) | |
Check for drivers, cable or try different port. If nothing helps you out, just contact your reseller. Br, Shadab Ahmad | |
The Following 9 Users Say Thank You to [Shadab_M] For This Useful Post: |
09-12-2009, 19:43 | #13 (permalink) | |
Munna. | |
The Following 9 Users Say Thank You to GsmMunna For This Useful Post: |
09-13-2009, 02:20 | #14 (permalink) |
Crazy Poster Join Date: Feb 2007
Member: 449622 Status: Offline Thanks Meter: 20 | Upgrade problem plz help Upgrade log: ---------- HWK Update Client v 2.0.8.0 ---------- ---------- HWK upgrade started:9/13/2009 6:45:29 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 41881 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO - HWK ID : ....... -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply |
The Following 16 Users Say Thank You to RAFIQMEER For This Useful Post: |
09-13-2009, 02:28 | #15 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hate stupidity
Member: 904530 Status: Offline Thanks Meter: 517 | must use 2.0.9.0 http://forum.gsmhosting.com/vbb/show...49&postcount=1 Last edited by Major-T; 09-13-2009 at 02:34. |
The Following 8 Users Say Thank You to Major-T For This Useful Post: |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
