10-16-2009, 11:02 | #166 (permalink) |
No Life Poster Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | Tell me Mr. supporter how I can........ |
10-16-2009, 11:26 | #167 (permalink) | ||
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
Munna. | ||
10-16-2009, 16:33 | #168 (permalink) |
Major Poster Join Date: Jan 2007
Member: 424909 Status: Offline Thanks Meter: 8 | Hi Sir. Sir i have problam with Ufs Hwk the problam is that when i install HWK Support Suite Setup v02.09.000 in last the show this error (The following error occurred on the file 'C:\Program File\Saras Soft\UFS\Update Client\Update Client.exe'. The system cannot find the file specfied. (0x2). the shows 3 Option Abort Retry Ignore when i press the button of Ignore the installed but it finish with this error Unable to lunch HWK Update Client. Pls slove my problam. Thanks in Advance |
10-17-2009, 04:48 | #169 (permalink) |
Junior Member Join Date: Apr 2007
Member: 483629 Status: Offline Thanks Meter: 0 | HWK install problem Dear Sirs I have just purchased a HWK micro from authorised reseller. I have followed the procedure to use the v 2.0.9.0 HWKupdate client, and successfully updated the HWK. I then proceeded to Support Site and downloaded the v 2.0.9.0 HWKsuite. I installed it OK and I can load all the different programs OK. Problem is, when for instance I load DCTxBB5 and hit CONNECT, it disconnects straight away. In SeDBx tools, I hit connect, and it disconnects straight away also but with a message HWK: NOT AUTHORISED, USE UPDATE TOOL. Well I already have used update tool. 3 times. Ive completely uninstalled and reinstalled twice already along with update client also. This was a clean machine, with never any UFS tools running previously so all the drivers should be up to date, and I am running windows XP. All seems OK except when I hit connect. Can somebody please help me solve this problem? With best regards |
10-17-2009, 15:21 | #170 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Better connect UFS directly to Back USB Port mounted directly on Motherboard. Try and post result. Br, Shadab Ahmad | |
10-17-2009, 15:43 | #171 (permalink) | |
If problem persist, disable you Antivirus Software and try again. If it fixes this issue, simply add Saras Modules in exclusion list. Br, Shadab Ahmad | |
10-19-2009, 06:48 | #174 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 543291 Status: Offline Thanks Meter: 15 | I have the same problem. Has more than 6 ratio but i was robbed by supporters and have to do it again. Also where is sedb 2020 files gone? More than 2 weeks for maintanace and very poor results... |
10-19-2009, 07:30 | #175 (permalink) | |
And about ratio, I had 5.x ratio but now I have 7.x ratio. Bcoz I had already downloaded files and now I am only seeding them. About DB2020 files, they are in support area but you need to wait sometime to let their Torrent building enabled. Br, Shadab Ahmad | |
10-19-2009, 08:53 | #177 (permalink) | ||
Member: 483629 Status: Offline Thanks Meter: 0 | HWKmicro first time install problems Quote:
I have changed USB port to rear USB port and front, same thing happens. I also tried 2 other USB cables, same results. I have since my last email also set up the HWK update client OK, upgraded once again the HWK to V2.0.9 on a different machine totally (laptop). Then I proceeded to install the HWKsuite no problems, just the problem it still it is disconnecting when I hit connect in DCTxBB5 tools etc. Its almost as if the HWK is not activated or something? Each program in the HWK suite produces the following Versions: Ufs2xx.dll 3.1.18, Ufs2xx.sys 2.4.16 then this result when I hit CONNECT in the program: DCTxBB5 tools: S/n xxxxx License True - Disconnects straight away, no message Motorola Acer UFS S/n xxxxx License True Connects OK ATRz: S/n xxxxx Hid xxxxxxxxxxxxxxxx HWK A1.04-PRO1 License True Connects OK KZF: S/n xxxxx Hid xxxxxxxxxxxxxxxx HWK A1.04-PRO1 License True Connects OK LG-SHARP GSM: S/n xxxxx License True, 00:02 HWK: NOT AUTHORISED, USE UPDATE TOOL, disconnects straight away RTP: UFS S/n xxxxx License True Connects OK SamS: S/n xxxxx License True, HWK: NOT AUTHORISED, USE UPDATE TOOL, disconnects straight away SeDBx: S/n xxxxx License True, 00:02 HWK: NOT AUTHORISED, USE UPDATE TOOL, disconnects straight away Thank you for any advice! Sorry for long post. BR Matt | ||
10-19-2009, 09:10 | #178 (permalink) | |
Try and check if problem is fixed. For help regarding UFS Firmware Update, please look http://forum.gsmhosting.com/vbb/showthread.php?t=370992 Also, if problem is not fixed after Firmware Upgrade, please post log shown by Update Client. Feel free to ask anything anytime. Br, Shadab Ahmad | |
10-19-2009, 20:34 | #179 (permalink) |
Freak Poster Join Date: Feb 2008 Location: SOUTH AFRICA
Member: 702077 Status: Offline Thanks Meter: 85 | help new hwk box from gpg UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0 10 ******* S/n: ***** HID: ************* HWK: ***** Fault in system or missing firmware Please report this error to dealer HWK: NOT AUTHORISED, USE UPDATE TOOL Selected Device, not Compatible with Software |
10-20-2009, 05:29 | #180 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1077162 Status: Offline Thanks Meter: 171 | Install problem of my hwkbox by gpg Need help Need help why this problem occur with my box what I did is 1. install Hwk update client and update my hwkbox [hwk update successfully done] 2. I install the main software of latest update [v02.09.000] 3. after successfull make it I test to run nokia tool and it shows [box auth error] I tried to trouble shoot first I uninstall and reinstall the box driver but still problem persist. so I decided to reinstall all software after I reinstall it It failed to install the main software it says " please update using update client" so I tried but this is shown in my logs in update client v02.09.000 screenshots ------------------------ when press ok this all shown no other update tab even box firmware update is not available I choose to click license but this was shown Your help is needed urgently, I am troubleshooting this problem for almost 2 days. all help is really appreciated. best regards |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
