Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 06-22-2010, 10:48   #571 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Thanks Meter: 4,965
Originally Posted by EBENEDEE View Post
pls i need help to update my hwk with ufs .but it give me unexpected exception.box-auth-error..1111
Just run the update client again and do a full server update and all will be ok, if you have no more logs you will need to contact your reseller.
Munna.
Old 06-26-2010, 16:22   #572 (permalink)
jacob magembe's Avatar
Member: 184973
Thanks Meter: 27
hwk not authorised use update tool
hello mr Munna,my hwk box shows this error ,when i update it shows box auth error 20,when itry to update firmware with update client it shows box error 00000080.now im stacked i have updated it fourth times but ,its errors return .help
Old 06-26-2010, 18:19   #573 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Thanks Meter: 4,965
PM me req file..!
Munna.
Old 06-27-2010, 08:45   #574 (permalink)
Member: 184973
Thanks Meter: 27
Originally Posted by GsmMunna View Post
PM me req file..!
Munna.
the problem is "box-auth-error:20. and the update software[hwk client]doesnt make req fbi file always says "box error 00000080"
i have downloaded req file from support and i use hwk client v2.1.0.2.help
Old 06-27-2010, 13:12   #575 (permalink)
Member: 578236
Thanks Meter: 24
Hello Every body, Kindly help me this problem
My my friend have 1 box, he used it every day
but this few days he let his friend borrow the HWK Chip
and then he take it back to put in his box
so now can not be update, this is the log, what is the problem
is it HWK damage?
is it Box damage?
i try to wait 48 hours already but the problem stile persis
can i solve this problem my self or must send it to the reseller?
thanks in advance
The Following User Says Thank You to Liheng For This Useful Post:
Old 06-27-2010, 13:36   #576 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 23,703
Originally Posted by Liheng View Post
is it Box damage?
Yes
Odia.
Old 06-27-2010, 14:24   #577 (permalink)
Member: 578236
Thanks Meter: 24
Originally Posted by Odia The Ultimate View Post
Yes
Odia.
thanks you very much , Now is ok 100% work
after you told that i open the box , then have some thing at the box abnomally , I just solder it after that try again , so 100% work
thanks you big big
Old 06-28-2010, 09:59   #578 (permalink)
Member: 4042
thanks you big big
Out of interest to help other users what did you solder?
Odia.
Old 07-03-2010, 13:35   #579 (permalink)
Member: 543601
hi
i wanted to install the latest version of hwk suite
first i install the support suite but during installing i got the message 'Would you like install new usb drivers' i answered yes the i got the error 'the current language is not supportedby the device driver installation wizard. contact the vendorthat provided youthis package'.
after the installation i start support suite and i get the message: bad environ ment : -2 .library not found. clean system from obsellete usb drivers
in support suite i click then the update button and then i get the message reinstall hwk support suite . i have done this but nothing changed.
waht i have to do??
Old 07-03-2010, 19:00   #580 (permalink)
Member: 4042
Originally Posted by kletscher View Post
hi
waht i have to do??
Install driver manually from:-
x:\Program Files\SarasSoft\UFS\UFS_USB_Driver
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 07-09-2010, 09:27   #581 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Thanks Meter: 4,965
Originally Posted by enrikez View Post
Please fix the server asap...
Server is down for some Tech Reason. we working on it. Also when Server Online we info in very 1st post of this thread.!
Thanks for your Patience ..!!
Munna.
The Following 10 Users Say Thank You to GsmMunna For This Useful Post:
Old 07-09-2010, 09:37   #582 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,423
EEPROM is ok, its the MCU which is corrupted and if box is under warrenty, you DEMAND to your reseller to fix or exchange it.
Odia.
MCU = ATMEGA8/8L ????
I have a few boxes with same error.
Br,
Shadab Ahmad
Old 07-09-2010, 10:23   #583 (permalink)
Member: 4042
Yes.
Odia.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 07-12-2010, 19:01   #584 (permalink)
Crazy Poster
Member: 687988
Thanks Meter: 11
Red face
hi, i haver the same problem, and i tried to install the driver manually before, but it shows always the same message:
'the current language is not supportedby the device driver installation wizard. contact the vendorthat provided youthis package'..
Please help..
Old 07-13-2010, 10:03   #585 (permalink)
Member: 4042
Please help..
You are not installing manually, you are still executing DPInst.
Odia.
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-16-2011 09:59
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.17085 seconds with 9 queries
