Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 05-19-2017, 10:44   #1021 (permalink)
Member: 310418
Thanks Meter: 13
Box: 1 Location: 529 Serial: XXXX
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXX
HWK Preset 2 Error: 00, -4
HID: , HWK: NOT CONNECTED 45
Fatal: Bad HWK Module
BOX: CORRUPTED or MANIPULATED
Your IP: 89.XXX.0.6
Support: Bad HID, Cannot Access Support
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: XXXX
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: XXXX
LIC5: True
BOXK: 1
UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXXX
What can cause this problem ?
Old 05-19-2017, 11:18   #1022 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
Open the box, remove your HWK, clean the pins and socket and re-insert and try see if it works. If not then your HWK is dead and needs to be replaced.
The Following 3 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 05-20-2017, 17:32   #1023 (permalink)
Member: 2670269
no
solutions
just
posting
links
Old 05-20-2017, 22:26   #1024 (permalink)
zombie1982's Avatar
Member: 1131303
Thanks Meter: 328
App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft
Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Box: 1 Location: 8513 Serial: 135xxx
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 0 0
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 135xxx
HWK Preset 1 Error: 00, 0
BOX_AUTH_ERROR: 156
Bad IX: ABCD
Failed: -5
Your IP: 37.xxx.xxx.45
Something Wrong, Try to Use [Update Box]
BOX_AUTH_ERROR: 207
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 135xxx
NVML: Ok
INIT FBI Failed: 2
Whats wrong here ?
Old 05-21-2017, 16:26   #1025 (permalink)
marcin7904's Avatar
Member: 290272
Thanks Meter: 431
I did restore settings on windows and it does not work now.
Prior to restore everything worked.
Last Server Update: 2016/03/30
Active Panel Version: 2.3.0.7
Box: 1 Location: 4641 Serial: 77xxx
Boot Id: 62 CF
Box Login Failed
Bad IX: ABCD
Failed: -102
HID Number Corrupted, Try to Use [Update Box]
Boot Id: 62 CF
Box Login Failed
Fatal LOGIN Error, Need Repair Box, Contact Distributor
Old 05-21-2017, 21:41   #1026 (permalink)
Member: 2670269
this is the main .... problem >>>> Support: Bad HID,{{{ Cannot Access Support}}}
wait for server ... but why they said >> online!!!???
Old 05-22-2017, 19:20   #1027 (permalink)
ponix's Avatar
Member: 229016
Sonork: 100.1590620
Thanks Meter: 130
i can not access to ufs saftware ??????
Old 05-23-2017, 04:22   #1028 (permalink)
Member: 2670269
before ... every birth for new ufs interface ... many problems happen in many ways .. all fix with the new ufs ... we wait ....
Old 05-26-2017, 18:44   #1029 (permalink)
nomi_42us's Avatar
Member: 500844
Sonork: 100.1680109
Thanks Meter: 285
None of Boxes Detected, Use: [Scan Boxes]
Box: 1 Location: 4403 Serial: 91xxx
Boot Id: 62 CF
Box Login Failed
Bad IX: ABCD
Failed: -102
Old 05-27-2017, 10:00   #1030 (permalink)
nomi_42us's Avatar
Member: 500844
Sonork: 100.1680109
Thanks Meter: 285
Boot Id: 62 CF
Box Login Failed
Bad IX: ABCD
Failed: -102
Fixed by self. Thanks to me
The Following User Says Thank You to nomi_42us For This Useful Post:
Old 06-01-2017, 14:45   #1031 (permalink)
Crazy Poster
Member: 40299
Thanks Meter: 3
Could You write Your solution on this problem?
Old 06-02-2017, 05:09   #1032 (permalink)
Member: 2255200
Thanks Meter: 9
fake solution
my new box ufst box login failed
before ten days working fine but now a days problemyour solution is not good pls correct solution ufst team
Box: 1 Location: 1127010 Serial: TMA10xxxxxx
Boot Id: 54 4D
Box Login Failed
Bad IX: ABCD
Failed: -102
Old 06-02-2017, 11:21   #1033 (permalink)
Member: 4042
Sure the solution is not good for you, because your in the WRONG sub-forum for the product your using.
Old 06-03-2017, 06:22   #1034 (permalink)
Member: 1543115
Sonork: wawan gunawan
Please master his solution
Box: 1 Location: 135953 Serial: 10xxxx
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 10xxxx
LIC: True
Your IP: 101.255.86.42
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 10xxxx
NVML: Ok
SERN: 10xxxx
LIC5: True
BOXK: 0
LIC: True
-16please reinstall support suite
Old 06-06-2017, 20:18   #1035 (permalink)
Member: 2670269
i have my box ... ufs " orginal " for 8 years ... without any little dust ... but last month
i connect ... " best " infinity key ... and use my lovley box .. as com ... may be for that my hwk damage ... i wait new panel version ,,, or buy new hwk .. if it still exists .. in market .... and iwill use old " fake ufs " as a " com " for infinty key ... this is safe for me and all ... take it like advice ... thanks .
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.24497 seconds with 10 queries
