09-13-2009, 11:03 | #16 (permalink) | |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
http://sarunasoftware.com/supportlogin.html Here you get latest Update Client..! Munna. | |
The Following 2 Users Say Thank You to GsmMunna For This Useful Post: |
09-13-2009, 11:22 | #17 (permalink) | |
Freak Poster Join Date: May 2006 Location: KINONDONI DAR ES SALAAM TZ
Member: 277899 Status: Offline Thanks Meter: 35 | Quote:
The Following User Says Thank You to chronic For This Useful Post: |
09-13-2009, 11:46 | #18 (permalink) |
Insane Poster Join Date: Aug 2002 Location: essex Age: 59
Member: 14367 Status: Offline Thanks Meter: 3 | hwk istallation problem hi i have a tornado flasher with hwk installed tried to do the client update had the no more logs problem waited 24 hours then did the update then installed suite 2.0.9.0 got that installed now my problems start acer program connects atzr connects dct5bb5 error20 kzr connected lg error20 rtp connects then disconnects samsung error 20 se hwk not authorised use update tool can anyone help as i cannot contact reseller has this was bought on ebay never had any problems with any other updates |
The Following User Says Thank You to tim20k2002 For This Useful Post: |
09-13-2009, 15:58 | #19 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | Quote:
ok can u tell me what i do now ?? | |
The Following User Says Thank You to ali_imran For This Useful Post: |
09-13-2009, 17:06 | #20 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
For detailed instructions, follow sticky thread regarding this issue by Odia. Br, Shadab Ahmad | |
09-14-2009, 15:34 | #21 (permalink) | |
The Following User Says Thank You to [Shadab_M] For This Useful Post: |
09-14-2009, 16:01 | #23 (permalink) | |
> Try to replace USB Cable > Try to use different USB Port or remove any HUB. Better connect to Computers Back USB Port. > If it does not help, Just Update UFS Firmware with Req.fbi. For further instructions regarding Firmware Update, please follow this link. Br, Shadab Ahmad | |
The Following 5 Users Say Thank You to [Shadab_M] For This Useful Post: |
09-14-2009, 16:32 | #24 (permalink) | |
Insane Poster Join Date: Mar 2003 Location: Mombasa Kenya
Member: 25004 Status: Offline Thanks Meter: 10 | hwk error 00000000 Quote:
Ok followed your advice 1st Class now I am getting this error: "None authorised copy of software detected, please use original install pakage." how should I solve this. genius! | |
09-14-2009, 16:40 | #25 (permalink) | |
If you have successfully Upgraded your HWK, just uninstall old Setup and again install Fresh Setup. Also if you have downloaded if from somewhere else, I will recommend you to download it from Support Area. You may login to Support Area by Click Support Site Button in Update Client. Br, Shadab Ahmad | |
The Following 3 Users Say Thank You to [Shadab_M] For This Useful Post: |
09-14-2009, 21:17 | #26 (permalink) |
Junior Member Join Date: Sep 2007
Member: 591049 Status: Offline Thanks Meter: 3 | I bought two UFS MICRO box from nearest reseller MOBILE STAR (Ranjeet singh, Guwahati, Assam, India)which is 360km away from me. The box have ufs-kit.com sticker on it . On the first disk he provide HWK.reg file . using this file i solve the reset error(hwk login error -1). {{Is this a legal process??}}. But after that when i connect through ufsxdctxbb5 module BOX_AUTH_ERROR:-1 occured> when i told him about this problem, he said that he cann't provide me the update through REQ FBI system and told me to go to his shop with the box to update it(!!!!). My question is whenever the times come to update the boxes, I have to go his shop which is 360 km away from my place??why cannt he provide me the box update through REQ FBI process? I checked ufs-kit.com and found that he is the only reseller from assam.. Please ODIA THE ULTIMATE help me......................... waiting for your reply......... |
The Following User Says Thank You to Tapanhaz For This Useful Post: |
09-14-2009, 21:36 | #27 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
thanks in advance, gprsman. | |
The Following User Says Thank You to gprsman For This Useful Post: |
09-14-2009, 21:52 | #28 (permalink) | |
Note:- Official Reseller Site is http://www.ufsxhwk.com/dealers.php Munna. | |
09-14-2009, 21:59 | #29 (permalink) |
Member: 591049 Status: Offline Thanks Meter: 3 | He is the nearest reseller. Don't tell me again that THIS IS YOUR LOCATION PROBLEM!!! Can you help me in generate **.fbi files ??? Thanks in advance |
09-14-2009, 22:05 | #30 (permalink) | |
http://forum.gsmhosting.com/vbb/showthread.php?t=370992 8. When you receive xxxxxx.fbi from your UFS reseller, perform steps 1-4 above. Note: Do Not Spam Again in HWK Section..! Munna. | |
The Following User Says Thank You to GsmMunna For This Useful Post: |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
