Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 09-13-2009, 11:03   #16 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,053
Arrow
Originally Posted by chronic View Post
please i need to know about my hwk.....
i try to upgrade my hwk for 5 days but still not update :so i need to know may be is dead or........................................a live
here is they logs:
pgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/13/2009 12:54:14 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : xxxxxxxxxx
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-A38A20B1xxxxxxxxxxx
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
i try it for 5days still i get this error
Why not you use Latest Ver..
http://sarunasoftware.com/supportlogin.html
Here you get latest Update Client..!
Munna.
The Following 2 Users Say Thank You to GsmMunna For This Useful Post:
Old 09-13-2009, 11:22   #17 (permalink)
Member: 277899
Thanks Meter: 35
Munna.
thanks broo i foget big up
The Following User Says Thank You to chronic For This Useful Post:
Old 09-13-2009, 11:46   #18 (permalink)
Member: 14367
Thanks Meter: 3
hwk istallation problem
hi i have a tornado flasher with hwk installed tried to do the client update had the no more logs problem waited 24 hours then did the update then installed suite 2.0.9.0 got that installed now my problems start acer program connects atzr connects dct5bb5 error20 kzr connected lg error20 rtp connects then disconnects samsung error 20 se hwk not authorised use update tool can anyone help as i cannot contact reseller has this was bought on ebay never had any problems with any other updates
The Following User Says Thank You to tim20k2002 For This Useful Post:
Old 09-13-2009, 15:58   #19 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
As Update Client says - Contact your reseller.
Also, try to find out if any of your mistake violate the rules. In future, follow the warnings by Supporters to avoid such inconvenience.
Br,
Shadab Ahmad
ok can u tell me what i do now ??
The Following User Says Thank You to ali_imran For This Useful Post:
Old 09-13-2009, 17:06   #20 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Just try to update UFS Firmware using Update Client and Upgrade.
For detailed instructions, follow sticky thread regarding this issue by Odia.
Br,
Shadab Ahmad
The Following 2 Users Say Thank You to [Shadab_M] For This Useful Post:
Old 09-14-2009, 15:34   #21 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Originally Posted by ogudageorge View Post
here is my major problem. got the hwk box new(2 weeks) not updated. v2.0.8.0 updated to 2.0.9.0 and was ok. now required update ufs firmware to 2.0.9.0 and there problem begins now "BOX ERROR...0000000". what can I do I cannot send to reseller coz he's too far. China and Kenya. cost too high. how do I update firmware, coz it refuses to req.fbi????? help ASAP!!!!
Try to run update client on that HWK and paste log here.
Br,
Shadab Ahmad
The Following User Says Thank You to [Shadab_M] For This Useful Post:
Old 09-14-2009, 15:44   #22 (permalink)
Member: 25004
Thanks Meter: 10
hwk error 00000000
Br,
Shadab Ahmad
just edited the post mate sorry check it up?
The Following User Says Thank You to ogudageorge For This Useful Post:
Old 09-14-2009, 16:01   #23 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Arrow
-- HWK ERROR : 0004
Authentication stage error: Access violation at address 00402D5D in module 'UpdateClient.exe'. Read of address 00000014
help!!!!!!!!!!
Please follow these one by one:
> Try to replace USB Cable
> Try to use different USB Port or remove any HUB. Better connect to Computers Back USB Port.
> If it does not help, Just Update UFS Firmware with Req.fbi. For further instructions regarding Firmware Update, please follow this link.
Br,
Shadab Ahmad
The Following 5 Users Say Thank You to [Shadab_M] For This Useful Post:
Old 09-14-2009, 16:32   #24 (permalink)
Member: 25004
Thanks Meter: 10
Cool hwk error 00000000
Br,
Shadab Ahmad
Ok followed your advice 1st Class now I am getting this error:
"None authorised copy of software detected, please use original install pakage."
how should I solve this. genius!
The Following 2 Users Say Thank You to ogudageorge For This Useful Post:
Old 09-14-2009, 16:40   #25 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
You might have used REG files.
If you have successfully Upgraded your HWK, just uninstall old Setup and again install Fresh Setup.
Also if you have downloaded if from somewhere else, I will recommend you to download it from Support Area.
You may login to Support Area by Click Support Site Button in Update Client.
Br,
Shadab Ahmad
The Following 3 Users Say Thank You to [Shadab_M] For This Useful Post:
Old 09-14-2009, 21:17   #26 (permalink)
Member: 591049
Thanks Meter: 3
I bought two UFS MICRO box from nearest reseller MOBILE STAR (Ranjeet singh, Guwahati, Assam, India)which is 360km away from me. The box have ufs-kit.com sticker on it . On the first disk he provide HWK.reg file . using this file i solve the reset error(hwk login error -1). {{Is this a legal process??}}. But after that when i connect through ufsxdctxbb5 module BOX_AUTH_ERROR:-1 occured> when i told him about this problem, he said that he cann't provide me the update through REQ FBI system and told me to go to his shop with the box to update it(!!!!).
My question is whenever the times come to update the boxes, I have to go his shop which is 360 km away from my place??why cannt he provide me the box update through REQ FBI process? I checked ufs-kit.com and found that he is the only reseller from assam..
Please ODIA THE ULTIMATE help me......................... waiting for your reply.........
The Following User Says Thank You to Tapanhaz For This Useful Post:
Old 09-14-2009, 21:36   #27 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
Br,
Shadab Ahmad
hello tomorrow I UFS3 + HWK arrive for installation is not good HWK_Support_Suite_Setup_v02.09.000? my reseller told me that I just have to update your HWK module and not the box is correct? if you have advice for me are welcome.
thanks in advance,
gprsman.
The Following User Says Thank You to gprsman For This Useful Post:
Old 09-14-2009, 21:52   #28 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,053
Arrow
this is your & reseller Problem...! if he is 360k or 2000km you must look b4 you buy..!!
Note:- Official Reseller Site is http://www.ufsxhwk.com/dealers.php
Munna.
Old 09-14-2009, 21:59   #29 (permalink)
Member: 591049
Thanks Meter: 3
He is the nearest reseller. Don't tell me again that THIS IS YOUR LOCATION PROBLEM!!! Can you help me in generate **.fbi files ??? Thanks in advance
Old 09-14-2009, 22:05   #30 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,053
Arrow
You deside not we advice you to buy from un-official reseller.. Next time b4 you make post see sticky thread Which indicate Clear for such Services Must contact your reseller More details read Link Carefully.
http://forum.gsmhosting.com/vbb/showthread.php?t=370992
8. When you receive xxxxxx.fbi from your UFS reseller, perform steps 1-4 above.
Note: Do Not Spam Again in HWK Section..!
Munna.
The Following User Says Thank You to GsmMunna For This Useful Post:
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.37847 seconds with 11 queries
