SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems @ UFSx+HWK User Post all your Upgrade/Installation/Support Server Problem Here.!! HWK Upgrade Server Status:- Online HWK Support Server Status:- Online - Maint. Note:-
Why product supporter not answering as seen this thread yesterdays problems were not answered yet, I am facing the similar problems as described in this thread so I don't want to write them again and again. ONE THING I MUST WRITE HERE THAT MANY RURAL AREA CUSTOMERS ARE USING HWK BOX , THEY DON'T HAVE THE INTERNET CONNECTIONS ( TALKING ABOUT iNDIA ) AND THEY ARE HAPPY AND SATISFOIED CUSTOMERS OF HWK BOX AND THIS UPDATE REQUIRES UPDATE IN SYSTEM. PLS DO SOMETHING FOR RURAL CUSTOMERS |
problem install hwk suite 2.009 ( install cannot continue aborting ) what problem with my installer , when try to install hwk suite support 2.0.0.9 no problem but when install hwk suite 2.0.0.9 show error " install cannot continue abortin " i used avg 8.5 antivirus and my os " window xp home edition sp 3 "i have already disable antivirus but still cannot install , thanks for help me |
Munna. |
Munna. |
HWK not update I don't update my hwk adjunt log...I try several times and not update. Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:11/09/2009 17:30:08 ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 84939 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID :xxxxxxxxxxxxxxxxxx -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... Error upgrading HWK: HWK UPDATE ERROR: 80 |
[QUOTE=elektra1980;4838958] Quote:
Bcoz I have seen this kind of issue with many HWKBox. If so, ask your reseller for replacement. Br, Shadab Ahmad |
ATRz asking for activation string! I had my HWK Box working fine with other softwares but when I try to run ATRz, it asked me for activation string. Quote:
Now I don't have no more Upgrade log. If one provided, I will check it out. Regards, Shadab Ahmad |
HWK not update Thank for you reply, i used HWKufs Micro i had no problems with version 2.0.8.0 only after install 2.0.9.0 |
Before that if you had tried to Upgrade and your box had the same problem, you would face the same. Br, Shadab Ahmad |
HWK not update Before that the box worked perfectly, updated several times with the 2.0.8.0 version and never had a problem, just try to update with 2.0.9.0 the problems started. |
Check for drivers, cable or try different port. If nothing helps you out, just contact your reseller. Br, Shadab Ahmad |
Munna. |
Upgrade problem plz help Upgrade log: ---------- HWK Update Client v 2.0.8.0 ---------- ---------- HWK upgrade started:9/13/2009 6:45:29 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 41881 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO - HWK ID : ....... -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply |
must use 2.0.9.0 http://forum.gsmhosting.com/vbb/show...49&postcount=1 |
