Box: 1 Location: 529 Serial: XXXX UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXX HWK Preset 2 Error: 00, -4 HID: , HWK: NOT CONNECTED 45 Fatal: Bad HWK Module BOX: CORRUPTED or MANIPULATED Your IP: 89.XXX.0.6 Support: Bad HID, Cannot Access Support REST: Ok UFSx: UFS3 SarasSoft, USB S/N: XXXX NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: XXXX LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXXX HWK Preset 2 Error: 00, -4 HID: , HWK: NOT CONNECTED 45 Fatal: Bad HWK Module BOX: CORRUPTED or MANIPULATED What can cause this problem ? |
no solutions just posting links |
App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 8513 Serial: 135xxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 0 0 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 135xxx HWK Preset 1 Error: 00, 0 BOX_AUTH_ERROR: 156 BOX: CORRUPTED or MANIPULATED Bad IX: ABCD Failed: -5 Your IP: 37.xxx.xxx.45 Support: Bad HID, Cannot Access Support Something Wrong, Try to Use [Update Box] Box: 1 Location: 8513 Serial: 135xxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 0 0 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 135xxx HWK Preset 1 Error: 00, 0 BOX_AUTH_ERROR: 207 BOX: CORRUPTED or MANIPULATED Your IP: 37.xxx.xxx.45 Support: Bad HID, Cannot Access Support REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 135xxx NVML: Ok INIT FBI Failed: 2 Whats wrong here ? |
I did restore settings on windows and it does not work now. Prior to restore everything worked. Code: Last Server Update: 2016/03/30 |
this is the main .... problem >>>> Support: Bad HID,{{{ Cannot Access Support}}} wait for server ... but why they said >> online!!!??? |
before ... every birth for new ufs interface ... many problems happen in many ways .. all fix with the new ufs ... we wait .... |
App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 None of Boxes Detected, Use: [Scan Boxes] App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 4403 Serial: 91xxx Boot Id: 62 CF Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] |
Fixed by self. Thanks to me :D :p ;) |
Could You write Your solution on this problem? |
fake solution Quote:
my new box ufst box login failed before ten days working fine but now a days problemyour solution is not good pls correct solution ufst team App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 1127010 Serial: TMA10xxxxxx Boot Id: 54 4D Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] |
Please master his solution Box: 1 Location: 135953 Serial: 10xxxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 10xxxx LIC: True Your IP: 101.255.86.42 Support: Bad HID, Cannot Access Support REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 10xxxx NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 10xxxx LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 10xxxx LIC: True -16please reinstall support suite Please master his solution |
i have my box ... ufs " orginal " for 8 years ... without any little dust ... but last month i connect ... " best " infinity key ... and use my lovley box .. as com ... may be for that my hwk damage ... i wait new panel version ,,, or buy new hwk .. if it still exists .. in market .... and iwill use old " fake ufs " as a " com " for infinty key ... this is safe for me and all ... take it like advice ... thanks . |
