Munna. |
hwk error solution CLEANUP SYSTEM... , yes Go to foder :C:\WINDOWS\system32 and delete 2 files :hwkkiller.dll và ufsloader.dll now ok ! |
probleme with hwk instalation whene i try to run hwkupdate upgrade client i get this eroor bad Environment:-1-bad library clean system from obsollete usb drivers plz help |
Solution:- If above not work Simple Search ufs, HWK & Saras name folder's and delete them (Make Sure Before Delete Check Folder & Files is Same Above) now Restart Pc
All Fix Now..! Munna. |
hwk setup suite cannot install. i trial to install my ufshwk, it keep say, install not authorised, you have not update with the latest update client.clientCompare. i need help. |
Munna. |
Its just a Norm for SARAS that everything cannot be rush. |
rush not means good result :) |
plez helppp......! .........http://dc176.4shared.com/img/1405545...a27/dfgdfg.bmp |
Munna. |
For a very long time I have not used this box (Its a HWK Micro) But now I want to start using it. The box updates ok, with v9 support software, BUT when I click to Go To support, I get error message. Also I cannot run the softwares. Here is Log: Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:10/13/2009 2:48:51 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 78137 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : deleted by me -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. Pls Its more than 2 years I have not been using SarasSoft, But I want to start again. I need all the help I can get |
Upgrade log: ---------- HWK Update Client v 2.0.9.0 ---------- ---------- HWK upgrade started:08/10/2009 01:43:30 ص ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : xxxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID : A1.04-PRO1-xxxxxxxxxxxxxxxxxxx -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:Account for this HWK module does not exist on server. Please contact your reseller! hi all firest that is my problem i trayed alot of times many many but still the same probleme please help me i hav good cable good pc good windows change it alot of times same probleme disable antivirus all the time same probleme i have ORIGINAL HWKufs Micro from fonec egypt (el sabahi) i didnot work with it befor 1 year ago same probleme only firest time with OLD version ufs thanks.... |
@ ashraf77160 Code: Authentication stage error: Server reported error: Code: Authentication stage error: Server reported error:No more upgrade logs. |
-- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use Update Firmware to authorise UFS. -- UFSx Device: UFS-NBOX SarasSoft, USB S/N: 106283 -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use Update Firmware to authorise UFS ! -- Target Id : 62 CF 0 0 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 106283 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: N-BOX can you help me... |
Simply Update You hwk all fix..! Munna. |
