App: UFSx (HWK) Control Panel v 2.3.0.8 by SarasSoft CPU: GenuineIntel Platform: Windows NT 6.1 (Build 7601 Service Pack 1) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files (x86) C:\Program Files (x86)\Common Files C:\Program Files (x86)\Nokia\Phoenix\ Can't open internet URL. InternetOpenURL failed! App: UFSx (HWK) Control Panel v 2.3.0.8 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 8497 Serial: xxxxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Something Wrong, Try to Use [Update Box] App: UFSx (HWK) Control Panel v 2.3.0.8 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 8497 Serial: xxxxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Something Wrong, Try to Use [Update Box] Box: 1 Location: 8497 Serial: xxxxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx LIC: True REST: Ok UFSx: UFS3 SarasSoft, USB S/N: xxxxx NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: xxxxx LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx LIC: True Authentication successfull. Upgrade client is up-to-date. Upgrade process completed. App: UFSx (HWK) Control Panel v 2.3.0.8 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 8497 Serial: xxxxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Something Wrong, Try to Use [Update Box] |
my box show HWK not connect i use ufs panel 2307 but not check box so i download the 2708, after check box i can connect dctxbb5 but error after few mins then i cant connect again, try update box success but show failed102 now show my hwk is not genuine |
On the 12% "-16 Please Reinstall Support Suite"... :( :( |
1 Attachment(s) Quote:
run panel and after box upgrade go software an click "Instal/auth" should appear Paths Updated Software Authorised *** luck |
mee too bro ..... i Use UFS Tornado original and have the same problem .... -16 Please Reinstall Support suite |
Is there any solution to fix Control Panel v2.3.0.8 -16 Please Reinstall Support Suite ERROR ??? |
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxx HID: 51, HWK: A LIC: True REST: Ok UFSx: UFS3 SarasSoft, USB S/N: xxxxx NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 9xxxx LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx HID: 5xxxxxxxxxx, HWK: Axxxxx LIC: True Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller! |
Can't open internet URL. InternetOpenURL failed! v-2.3.7 wht, s The solution |
Can't open internet URL. InternetOpenURL failed! Can't open internet URL. InternetOpenURL failed! Can't open internet URL. InternetOpenURL failed! ??? |
good day the problem with the last update of module 2.7.0.8 is that it does NOT enable the option to repair imei. Any option to enable? I leave the image https://www.4shared.com/photo/axunFMpWei/hwk_.html https://www.4shared.com/rar/ak2iByopei/hwk_.html version 2.3.0.7 no longer lets update to activate option imei repair, of course |
server status unknown |
Any solutions? |
hi all server is down? i install fresh windows cant conect to server to download ??? |
i think serer not working App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft CPU: AuthenticAMD Platform: Windows NT 6.1 (Build 7600 ) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Users\boluticgsm\Desktop C:\Users\boluticgsm\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs Can't open internet URL. InternetOpenURL failed! Can't open internet URL. InternetOpenURL failed! Can't open internet URL. InternetOpenURL failed! |
