Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 08-09-2013, 16:41   #871 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
Originally Posted by AgicAga View Post
how soloved this eror
Next to Boot Loop is combo box with CHS, change to EN.
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 08-10-2013, 12:16   #872 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
Originally Posted by Odia The Ultimate View Post
Your UFSx box is not original or has somehow been modified by none official software.
Hello sir i m using my (own)HWK from (2009) last 4 years , i m not face single problen in 4years now suddnely got error with New updated version now ur saying that box is not original or none official , how it is possible sir , if possible how could it's run fine in those year without problem, how could you Update my Box in those year..i m realy realy Happy with HWK now i m not ready to loss my box on this way , this is not fair sir.. If you need money from us then u have lots of way to collect it , not on this way sir.. we realy not happy with your Action/Answer....... Old HWK user:confu sed::confu sed:
The Following 5 Users Say Thank You to asmanju08 For This Useful Post:
Old 08-10-2013, 12:56   #873 (permalink)
Member: 4042
http://forum.gsmhosting.com/vbb/9630571-post854.html
... and you should thank yourself lucky you have gotten away with it for so long.
The Following 4 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 10-05-2013, 14:59   #874 (permalink)
Member: 656076
Thanks Meter: 5
my hwk in samsung android section can't opening,when i try to click on android section qualcomm near to android section is open,how to i fix it?
Old 10-06-2013, 13:23   #875 (permalink)
Member: 4042
Did you read the first post in this thread? Does it mention that Android is available for UFSxHWK?
Old 10-12-2013, 15:36   #876 (permalink)
Member: 274436
Thanks Meter: 26
why ufs2 with 4 digit serial number have this error, and two ufs3 with 5 digit serial numbers work ok? previous suite work perfect on this ufs2.
Old 10-16-2013, 13:49   #877 (permalink)
Member: 4042
Is not to do with 4 digit serial, I have tested with 4 digit and its ok, contact me via PM so that we can look into your problem.
Old 10-27-2013, 00:24   #878 (permalink)
Crazy Poster
Member: 687988
Thanks Meter: 11
Question Installation/Support Server Problems
Hello everybody, i tried to do "install" after succesful "update box". start well until item number 351 which is SAM.exe, a window a appears " Can't open internet URL. InternetOpenURL faild!" , same times an avertisment launched by my antivirus Avastt as "
Infection Blocked
URL:http://support.sarunasoftware.com/bybis/tatata.php?****
Infection:Win32:BogEnt [Susp]
So what is the solution please, to complete the installation of softwares.Thanx.
Old 10-28-2013, 11:45   #879 (permalink)
Member: 4042
Infection Blocked
Disable your paranoid AV sw.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 10-29-2013, 14:26   #880 (permalink)
Member: 4042
Originally Posted by szulik23 View Post
I found the information that is a clone HWK.
If this is true, then why in the earlier version of the client (HWK_Support_Suite_Setup_v02.20.000) I had no problem with the update?
Old 10-29-2013, 14:40   #881 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 92
@Odia The Ultimate
Why You deleted my post's about problems with upgrading HWK?
If You have solution for these STUPID solution with "new" drivers where dll is messup for MicroUFS, pl's share here like SUPPORTER shoode do!!!
Don't be @Zuleah pl's....
Take back my post's and You can see that ufs2x.dll which make possible update is not a same like in Your "updated" USB Driver!!!
Old 10-29-2013, 15:50   #882 (permalink)
Member: 4042
Originally Posted by hallo View Post
@Odia The Ultimate
The drivers have been tested with all Official versions of UFSx with all OS from XP 32 to Win 8.1 64 and work fine.
Old 10-29-2013, 16:56   #883 (permalink)
Member: 481710
So what is wrong with my Box?
Old 10-29-2013, 17:22   #884 (permalink)
Member: 4042
Nothing wrong with your box, the problem is with your HWK, this new panel release 2.3.0.3 tries to correct any problems with box or HWK which can be corrected by software, so if you still have problems, then it cannot be corrected.
Specific in your case, your HWK refuse to update, problem can be:-
1. Your HWK is not original or has been touched by none official software.
2. Your HWK flash ic has degraded and refuse to update, if under warrenty then speak with your reseller for exchange.
Old 10-29-2013, 19:08   #885 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 92
Well, these is NOT the right answer...I show You before that FACT is these driver not working with MicroUFS on Win XP SP3 and these MB of mine...WHY is not working, that was my question..
A few things comes on my mind.... one of them that You MAYBE decide to eliminate "few" old box's to make a room for a "new" one...maybe
One more time: Pl's check with programer how to solve problem I described...driver don't "wake" UFS in stage when Box try to update himself, and problem is with MicroUFS on win XP SP3 ...
App: UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft
CPU: GenuineIntel
Platform: Windows NT 5.1 (Build 2600 Service Pack 3)
Cheers.
The Following User Says Thank You to hallo For This Useful Post:
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.37722 seconds with 11 queries
