11-07-2013, 04:21 | #901 (permalink) |
Freak Poster Join Date: Nov 2013 Location: India
Member: 2059486 Status: Offline Thanks Meter: 34 | panel hanging on check box or update box amd cpu 2.71 GHz, 1.87 of ram usb 2.0 Controller. hwk usf-3 not update or not work plesss help |
11-13-2013, 18:11 | #903 (permalink) |
Freak Poster Join Date: Apr 2008 Location: ÞÚÑJÁß Age: 34
Member: 741065 Status: Offline Thanks Meter: 139 | My box is working fine but hangs at last :( Hello Mr.Odia thx for this wonderful flasher and unlocker called HWK + UFS..... My problem is this that my hwk+ufs-5plus works connects and works perfect ....... but when i finished my work like flashing and unlocking and press disconnect Button on upper left corner then it hangs and when i remove cable (pc cable) from ufs then its fine again ........ well i was facing this problem from approx last year .....and according to my experience this issue is due to drivers ....... i solved this problem with old drivers (from 2.10) and it was working perfect wid that 2.10 drivers till 2.3.0.0..... and few days ago i installed 2.3.0.3 and now when i try to install that old drivers (2.10 which was working fine till 2.3.0.0) then control pannel says bad environment ...... plz solve my this problem ..... sorry for my bad English .. hope u understand my problem .... here is screenshot of hanged software ...... |
11-15-2013, 13:47 | #904 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1436004 Status: Offline Sonork: ednietoz Thanks Meter: 0 | dear sir...how i can get sams tool v2.3.0.1? i try to update with ufs panel 2.3.0.2 but server is unrecognized reply.....when i used ufs panel 2.3.0.3 i get sams 2.3.0.2.....is ufs panel 2.3.0.2 stil support? |
11-15-2013, 14:26 | #905 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Philippines
Member: 1344629 Status: Offline Thanks Meter: 24 | App: UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft CPU: AuthenticAMD Platform: Windows NT 6.1 (Build 7600 ) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix always hang while updating... please fix mr odia! |
The Following User Says Thank You to john_cover For This Useful Post: |
11-16-2013, 17:05 | #906 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Did you read this? http://forum.gsmhosting.com/vbb/9859557-post901.html or just walk around blind and open m outh with bla bla bla? |
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post: |
11-16-2013, 21:28 | #907 (permalink) |
Junior Member Join Date: Jul 2007
Member: 546871 Status: Offline Thanks Meter: 1 | please help my mother board is asus processor amd II x4 965 3.40 ram 4gb windows 7 32 bit when i update hwk it gets hang on check box or even update UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 54003 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Your IP: 117.195.110.173 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] (and gets hang) |
The Following User Says Thank You to ayaz_hasham For This Useful Post: |
11-18-2013, 14:16 | #908 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Krusevac, Serbia Age: 55
Member: 58263 Status: Offline Thanks Meter: 19 | PC nr 1: VIA USB ENHANCED Host controller AMD Athlon 64 processor 3000+ WinXP SP3 UFS-3 TORNADO PC nr 2: ALi PCI to USB Open Host controller mobile AMD Athlon processor XP2600+ WinXP SP3 UFS-3 TORNADO Scan and update problem! B.R. |
The Following User Says Thank You to neper For This Useful Post: |
11-24-2013, 15:04 | #910 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Lebanon Age: 45
Member: 53113 Status: Offline Thanks Meter: 16 | Please help. Its long time ago i have uset my box, and now i wont to use it, and i have to update it and i use UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft But i get this error. App: UFSx (HWK) Control Panel v 2.3.0.3 by SarasSoft Box: 1 Location: 273 Serial: XXXXXX UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXXXX HID: XXXXXXXXXXXXX, HWK: A1.04-PRO1 BOX_AUTH_ERROR: 9990 HWK: XXXXXXXXXXXXX NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: XXXXXXXXXXXXXX Support: Account Ok Something Wrong, Try to Use [Update Box] |
11-26-2013, 05:19 | #911 (permalink) | ||
No Life Poster Join Date: Dec 2007 Location: Where Dreams Become Realit Age: 28
Member: 645436 Status: Offline Thanks Meter: 1,501 | Quote:
The Following User Says Thank You to msattar123 For This Useful Post: |
11-26-2013, 08:03 | #912 (permalink) |
Member: 53113 Status: Offline Thanks Meter: 16 | But iam 100% sure that my HWK is not clone, i have never had problem whit Update my box before. And my HWK is one off the first ones I bay, win HWK comes out, and that time I bay it from a HWK reseller. |
The Following User Says Thank You to ChouChou For This Useful Post: |
11-26-2013, 14:52 | #913 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | |
11-27-2013, 10:32 | #914 (permalink) | |
Member: 53113 Status: Offline Thanks Meter: 16 | Quote: I did use the latest one V 2.3.0.3, and i have try many time to upgrade the box, and now the server write that there is no more logs Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller! As i sad before i have never had a problem before whit upgrade my box, but its long time ago i have uset my box. Can it be that the upgrade server have blocked my HWK Id number? | |
11-27-2013, 11:57 | #915 (permalink) | |
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
