07-20-2008, 09:15 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 650752 Status: Offline Thanks Meter: 1 | Sir how to do ini file auto in HWK? i'm new in here ,so i have some blam want all user that know above tell me.with my blam.. i use hwk last version , when i'm chose BB5 and check modul phone like RM-1(6630) i want in COR,PPM..its auto to open file.what can i do sir? i'm check in Use ini file setting yet,but still can't . thank you |
The Following User Says Thank You to morokat For This Useful Post: |
07-20-2008, 09:32 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | If the software does not pick up the files automatically just manually pick up the file and press "Create Ini file". You must have the flash files in Products. Also you can use this latest Ini file for DCTxBB5, just replace this with original one- |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
07-20-2008, 10:00 | #5 (permalink) | |
Member: 650752 Status: Offline Thanks Meter: 1 | Quote:
i'm back up my flash befor problam | |
07-20-2008, 10:16 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | You would be having some flash files in your Phoenix/Products folder, and they cab be picked up automatically. The problem is with new files. When you install new files you have to manually select them. So when you manually select them just create Ini file for that model and next time software will itself pick up the file. It's better to have MCU,PPM and CNT file only instad of downloading big set up files. Look here for files- http:///vbb/showthread.php?t=541464 You need to copy flash files to Products folder first and then you can make Ini. |
07-20-2008, 10:37 | #7 (permalink) | |
07-20-2008, 13:09 | #9 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
"Phoenix" folder with the original one. | |
how to use ini files phoenix? | jackyivan | Cyclonebox | 3 | 05-11-2009 10:51 |
How to recuperate INI Files and TIA files, after formated the PC ?¿ | Grupo MovilFree | HWK | 7 | 06-28-2008 07:01 |
How to do it flash 6630 in hwk | riyadhkhalid | HWK | 3 | 02-26-2006 19:27 |
How to use ini files ? | glfrank | Twisterflasher | 0 | 08-02-2005 16:05 |
