04-27-2008, 21:53 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | very simple reinstall software with repair option and every thing will be ok --- for 2 hwk in same pc not run evertime when you change hwk..need to reinstall software again |
04-27-2008, 21:56 | #3 (permalink) | |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=518454 Munna. | |
04-28-2008, 07:13 | #4 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | Quote:
are you sure or you dont know how i've install on 3pc, you just need install the registry (sarassoft) from 1st pc you install, then you'll able use on other pc, not need update client again *run regedit find the "sarassoft" at My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Sarassoft extract and save it, install on other pc | |
04-28-2008, 10:49 | #8 (permalink) | |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
for 2 hwk in same pc not run evertime when you change hwk..need to reinstall software again it means normaly not run you have to do some thing easy way to reinstall software again with choosing repair option but if you want a fresh instalation and with already updated hwk you need to go for saved registry run | |
04-28-2008, 12:40 | #9 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Can have up to 16 UFS+HWK on same PC, even all working in same time, if you have enough USB ports, power supply is stable and your PC can cope. Odia. | |
04-28-2008, 14:28 | #10 (permalink) | |
but i really confused i have my own hwk updated latest version working ok but when i connected hwk of one of my friend its given me same error and i solve in that way and after i read your reply i collected my friend hwk to test in same pc(only hwk not registry,because he formated his pc and registry not saved) and here below i paste screen shot my ufs sirial-70071 connected ok my friend ufs sirial-74460 getting error help i need - (1) solution to connect this 2 hwk in my pc (2)my friends registry not save so when ever he format pc and for new instalation he need my hwk and registry for 1st instalation and after that he reinstall exe with repair option to use his own hwk in his pc so can you clear this????to solve this problem i can't find any official solution in forum and afraid to use un offical tricks here below screenshot is this a power supply problem? | |
04-29-2008, 07:34 | #11 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | @TURNING POINT See new process 3 added here:- http://forum.gsmhosting.com/vbb/showthread.php?t=518454 Odia. |
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
Infinity-Box update to 3.10 not working spt software can not start [SOLVED] | john423281 | SPT BOX | 5 | 04-19-2010 09:11 |
update to 3.10 not working spt software can not start | john423281 | Infinity-Box | 2 | 03-07-2010 09:54 |
Where do i find mobimb full copy not demo | gilbertjelly | Nokia Multimedia | 5 | 02-03-2004 17:18 |
SPUnlock's software does not work for new GD67 revisions! | BufferMess | Panasonic | 5 | 09-04-2003 11:51 |
"Illegal software loaded" - not solution yet? | Alligator | Motorola ODM | 6 | 11-08-2002 13:06 |
