12-21-2009, 09:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: bandung, indonesia
Member: 839770 Status: Offline Thanks Meter: 24 | Sos, can hwk solved 5300 contact service 1ST BOOT : C0,07 [Rm-146] [2.0.9.0] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 0820020B8A4D00529C9BEF3069F69D370356DB33 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC2208-00006921, Sam K8F5615ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent Rebooting Mobile MCU SW : V 07.20 23-10-08 RM-146 (c) Nokia. PPM SW : V 07.20 23-10-08 RM-146 (c) Nokia. X Prd.Code: 0536680 Bpr.Code: 0530536 Prod.Sn : DAN118382 HW Vers : 2011 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 17211721 DSP Vers: ICPR61_08w10 IMEI : 354831-02-297889-4 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland 1ST BOOT : C0,07 [Rm-146] [2.0.9.0] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 0820020B8A4D00529C9BEF3069F69D370356DB33 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC2208-00006921, Sam K8F5615ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm146__07.20.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 00:43 Written: 10 Certificate(s) CMT FLASH WRITE OK, Time: 01:27 Chip SECTOR_SIZE: 128k Warning, Must be Used 128Kb Sector_Size CNT File CONVERSION: Already 128K Paged Source IMAGE : rm146__07.20.image_x_128 CMT NOR Erase Area: 0x01600000-01FDFFFF CNT FLASH ERASE OK, Time: 00:23 CNT FLASH WRITE OK, Time: 00:28 IMAGE : rm146__07.20.ppm_x CMT NOR Erase Area: 0x01080000-015FFFFF PPM FLASH ERASE OK, Time: 00:15 PPM FLASH WRITE OK, Time: 00:31 Flashing Completed, Rebooting Mobile UI Defaults Ok, Time: 00:05 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:01 Unfortunately i can't upload the screen shot "SELF TEST", basically SET SECURITY FAILED in the log SELF TEST i don't why although i tried many times always fail and fail, it's moderators authority to check my account pls why i can't upload. br |
12-21-2009, 14:01 | #5 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Palestine - Nublus
Member: 431775 Status: Offline Thanks Meter: 94 | use sx4bb write full pm without 120 & 308 unlock it agein by zulya bb5+(be sure u don't have jaf kp) that work good on usf after that will work before that beakup crl and orgnal full pm |
12-21-2009, 14:17 | #6 (permalink) |
Freak Poster Join Date: Feb 2009 Location: MX-KEY is the BEST NOKIA TOOL
Member: 965510 Status: Offline Thanks Meter: 8 | make self test and post the log here if the security test failed write fully modified pm in mx key and with sx4auth u will get the solution |
01-30-2010, 15:29 | #8 (permalink) |
Junior Member Join Date: Dec 2007
Member: 645881 Status: Offline Thanks Meter: 11 | 5200 security test failed Phone Type: RM-174 (Nokia 5200) SW Version: V 07.20 23-10-08 RM-174 (c) Nokia. Imei plain: 35483202131955-1 Product Code: 0535511 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354832021319551 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
CAN cyclone solve 7210 CONTACT SERVICE | bahaqurini | Cyclonebox | 3 | 01-11-2010 16:22 |
CAN cyclone solve 513xm CONTACT SERVICE | Riteshgpt60 | Cyclonebox | 8 | 01-10-2010 12:10 |
Can i solve 5130 contact service | sirnavid2010 | Cyclonebox | 1 | 01-03-2010 09:20 |
can HWK repair 5220xm Contact Services | andre128 | HWK | 6 | 08-23-2009 08:46 |
5300 contact service solved | adreesas | Nokia Base Band 5 ( BB-5 ) | 3 | 05-11-2009 05:41 |
