08-15-2009, 11:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | Successfully flash kg290 with hwk Boot Ok, FL_ID : 89 88 16 [INTEL] 07 BaudRate Set to: 921600 IMEI: 350305-26-000000-1 File: KG290P40-07-V10b-XXX-XX OCT 22 2007 CodeData.mot MOT Format File, Converting to BIF Region: 1, 0x01000000-0x01B68AF7, Length: 11963128 bytes Processed: 747696 record(s) Saved as KG290P40-07-V10b-XXX-XX OCT 22 2007 AlchemyData.bif Write [01000000-01007FFF] Skipped Write [01000000-01B68AF7] Done, 03:31 Write [01000000-01007FFF] Skipped Write [01000000-01B68AF7] Done, 03:31 Erase [04800000-04FFFFFF] Done, 01:19 File: KG290P40-07-V10b-XXX-XX OCT 22 2007 AlchemyData.mot MOT Format File, Converting to BIF Region: 1, 0x04000000-0x045F1A63, Length: 6232676 bytes Processed: 389543 record(s) Saved as KG290P40-07-V10b-XXX-XX OCT 22 2007 AlchemyData.bif Write [04000000-045F1A63] Done, 01:48 File: KG290P40-07-V10b-XXX-XX OCT 22 2007 AlchemyData.bif Write [04000000-045F1A63] Done, 01:48 Read [01000000-01007FFF] Done, 00:00 Cal. Data Saved as KG290_CAL_350305-26-000000-1_15082009_120530.bif Rebuild Done, 00:00 Read [01000000-01007FFF] Done, 00:00 Cal. Data Saved as KG290_CAL_350305-26-000000-1_15082009_120540.bif Unlock Done, 00:00 Ini File: LG_Gsm.ini Created |
The Following User Says Thank You to luyanda For This Useful Post: |
08-17-2009, 10:23 | #2 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Yes,i have also successfull flashed 2 LGkg 290. thanks 2 HWK team. |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
08-22-2009, 06:54 | #3 (permalink) | |
Freak Poster Join Date: Sep 2005 Location: sky Age: 38
Member: 176744 Status: Offline Thanks Meter: 44 | Quote:
Successfully unlock j700 with hwk | SOHAIL BASHARAT | HWK | 13 | 09-11-2009 00:24 |
Success Unlock E390 With Hwk!!! | Umbabaraumba | HWK | 11 | 01-17-2009 22:50 |
Post Only Successfully flashed bb5 with HWK | Mounir | HWK | 0 | 10-22-2008 21:43 |
Never Success Flash LG with HWK | neokia | HWK | 3 | 02-10-2008 18:35 |
