Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 01-25-2010, 14:29   #241 (permalink)
m_tahir1's Avatar
Member: 482214
Sonork: 100.1617896
Thumbs up Samsung c3010s successfully unlock done
SAMSUNG C3010S SUCCESSFULLY UNLOCK DONE
Software: C3010SXPIG1
Regions : O2,UK
Language: EN.ar,en,fr(fa,ur)
Release : 2009 July Rev: 1
CSC Vers: C3010SOJPIE6
Regions : O2,UK
Language: EN,ar,en,fr(fa,ur)
Release : 2009 May Rev: 6
Hardware: MP 0.400
IMEI: 353376-03-154971-7
BT Address: 00265f-b0a890
Lock Level: 234;00 [ Locked]
MSL : Active
S/N : RUNS882995
MSL : activated
PCK : 00000000 [#0141*00000000#]
NCK : 00000000 [#0111*00000000#]
SCK : 00000000 [#0121*00000000#]
SPCK: 00000000 [#0133*00000000#]
Phone Must be with Battery and Powered On !
All Network Keys Reset to: 00000000, Time: 00:00
#0111*00000000#
#0121*00000000#
#0133*00000000#
#0141*00000000#
#0149*00000000#
#0151*00000000#
#0199*00000000#
The Following User Says Thank You to m_tahir1 For This Useful Post:
Old 01-25-2010, 16:49   #242 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 100.1613804
Nokia 5320 Flash without error
1ST BOOT  : C0,07 [Rm-409] [2.0.9.0]
RAPx ID   : 000000010000022600010006400C192101031103
EM 1 ID   : 00000295
EM 2 ID   : 00000B22
RAPx PBID : 07C00103B86B0052DBD635419E434F4D9F44A155
RAPx MODE : 00
RAPx HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE
RAPx ROID : 4B9B75103E691FF8
CMT 1ST Boot OK
CMT 2ND Bt: RAPIDOv11_2nd.fg, Ver: 1.37.1
CMT FLID0 : 00EC0040-00800121, Sam OneNAND-2G
CMT FLCNT : 00030000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO  : RAPIDOv11_algo.fg, Ver: 1.40.0
CMT VPP   : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm409_05.16_prd_core.fpsx
CMT NAND Erase Area: 0x00040000-00082FFF
CMT NAND Erase Area: 0x00083400-0087FFFF
CMT NAND Erase Area: 0x00B80000-077FFFFF
CMT NAND Partition Format
CMT FLASH ERASE OK, Time: 00:00
Written: 11 Certificate(s)
CMT FLASH WRITE OK, Time: 06:37
IMAGE : rm409_05.16_prd_v03_05_UDA_PRD_MENA.fpsx
CMT NAND Erase Area: 0x07800000-0F8BFFFF
CNT FLASH ERASE OK, Time: 00:00
CNT FLASH WRITE OK, Time: 05:19
IMAGE : rm409_05.16_prd_v11_01_meab.fpsx
CMT NAND Erase Area: 0x05190000-06FFFFFF
PPM FLASH ERASE OK, Time: 00:00
Written: 1 Certificate(s)
PPM FLASH WRITE OK, Time: 01:56
IMAGE : rm409_05.16_prd_vC03_01_Blue.fpsx
CMT NAND Erase Area: 0x07000000-077FFFFF
CUS FLASH ERASE OK, Time: 00:00
CUS FLASH WRITE OK, Time: 00:15
Flashing Completed, Rebooting Mobile
UI Defaults Failed
UI Defaults Failed
UI Defaults Ok, Time: 00:03
Set UI Factory Defaults Ok, Time: 00:00
Set Full Factory Defaults Ok, Time: 00:01
Thanks sara Team
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 01-26-2010, 17:46   #243 (permalink)
Riteshgpt60's Avatar
Member: 1086393
Sonork: 100.1591056
Successfully revive B520 by HWK!!!
Region: 1, 0x20000000-0x20000063, Length: 100 bytes
Region: 2, 0x2000C000-0x200111C3, Length: 20932 bytes
Region: 3, 0x20016000-0x2001722B, Length: 4652 bytes
Region: 4, 0x2001E000-0x2001E08F, Length: 144 bytes
Region: 5, 0x2003803C-0x20040F87, Length: 36684 bytes
Region: 6, 0x20058000-0x20058037, Length: 56 bytes
Region: 7, 0x20058138-0x2005C93F, Length: 18440 bytes
Region: 8, 0x20078000-0x20184BA7, Length: 1100712 bytes
Region: 9, 0x20300000-0x21517253, Length: 18969172 bytes
1st Boot Ok, McuId: 00030021, Rom: 00030021, 13-1.2 (Vision X122A)
2nd Boot Ok, McuId: 00030021, Rom: 00030021, 7-2.0
Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s05_2.sre
Flash1: Fl_Id: 00010000_227E3D00 - Spansion SxxWS512P
Baud Rate Set: 460800 bps
Flashing NOR part...
Write Done, 20150972 byte(s), Time: 10:24
FS Formated (FDI)
FS Mounted (FDI)
Files Count: 15
Writing File: /Def/Feelin' Like This - Cleo.mp3, 6983183 byte(s)
Writing File: /JAVA/0000.jar, 69148 byte(s)
Writing File: /JAVA/0000.jad, 343 byte(s)
Writing File: /JAVA/0001.jar, 91454 byte(s)
Writing File: /JAVA/0001.jad, 314 byte(s)
Writing File: /JAVA/0002.jar, 86689 byte(s)
Writing File: /JAVA/0002.jad, 422 byte(s)
Writing File: /JAVA/0003.jar, 92188 byte(s)
Writing File: /JAVA/0003.jad, 424 byte(s)
Writing File: /JAVA/0004.jar, 84995 byte(s)
Writing File: /JAVA/0004.jad, 459 byte(s)
Writing File: /JAVA/0005.jar, 78633 byte(s)
Writing File: /JAVA/0005.jad, 396 byte(s)
Writing File: /JAVA/0006.jar, 81501 byte(s)
Writing File: /JAVA/0006.jad, 489 byte(s)
FS Unmounted
FS Write Done, 7574690 byte(s), Time: 06:40
Unlock Codes:
#0111*00000000# [NET]
#0121*00000000# [SUB]
#0133*00000000# [SP]
#0141*00000000# [SIM]
#0149*12614341# [SIM]
#0151*00000000# [AUTO]
#0199*12614341# [FREEZE]
Thanks HWK TEAM!!
Old 01-27-2010, 02:34   #244 (permalink)
Member: 679135
Sonork: 100.1606448
2760
IMEI: 352070-02-592224-3, ASIC: 11
FILE: rm258__03.62.mcusw
1st Boot: Ok, DCT4, UPP: 3162 [Rm-258] [2.0.9.0]
2nd Boot: u3_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x02FFFFFF,00EC2208,Sam K8F5615ETM
Algorithm: u3_amd.fia, Ver: 4.79.0
Algorithm Ok, MSID: 84776A91B639FEF77A1736104D
Decoded MSID: 2C40BAE9-0055CB6A-A8000000
Encoded FAID: 1C2FFEA0-FE2CECF9-38881AAD
Area1: 0x01080000-0x0109FFFF Erased, Time: 00:00
PAT Flashing Completed, Time: 00:04
SimLocks Initialized (Patch Ok), Time: 00:00
Area1: 0x01000000-0x0101FFFF Erased, Time: 00:00
Area2: 0x01080000-0x0109FFFF Erased, Time: 00:00
UNP Flashing Completed, Time: 00:09
SimLocks Initialized, Time: 00:51
Old 01-27-2010, 06:52   #245 (permalink)
mbiborna's Avatar
Member: 770503
samsung E250d usercode done.
Software: E250DJPHA2
Hardware: MP 0.805
Warning, Wrong Product Selected [E250]
Regions : Arabic
Language: ar,en,fr(fa,ur)
Release : 2008 January Rev: 2
MSL Active
S/N : RW*******91
IMEI: ***************
BTID: 00211:0F271C
MSL Active
SIMLOCK STATUS: 0000
MCC-MNC: 000-000
MASTER KEY: 47543390
NET 00000000, 00000000
SUB 00000000, 00000000
SP 00000000, 00000000
CP 00000000, 00000000
SIM 00000000, 00000000
ACT 00000000, 00000000
PLK 00000000, 00000000
MSL Active
CUSTOM Reset, Ok
Old 01-27-2010, 08:07   #246 (permalink)
ehsas_ghum's Avatar
Member: 171512
C300 FLASH OK
Old 01-28-2010, 13:28   #247 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
c3050 done
Old 01-28-2010, 15:31   #248 (permalink)
mbiborna's Avatar
Member: 770503
1st Boot: Ok, WD2, UPP: 0082 [Nhl-10] [2.0.9.0]
2nd Boot: w2_2nd.fia, Ver: 4.76.0
Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT
Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT
Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT
Fl3: 0x06000000-0x067FFFFF,0001267E,Amd 29BDS643HT
Algorithm: w2_amd.fia, w2_cbusb.fia, Ver: 4.76.0
Algorithm Ok, MSID: 84FA4F207B41525EFCF1ACAF30
Decoded MSID: 3E4EBAF7-00490BDE-A9000000
Encoded FAID: F5F153B4-80CCEDEA-4B922E19
IMAGE: NHL105530.C1
Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
Area2: 0x00010000-0x007FFFFF Erased, Time: 01:10
Area3: 0x04000000-0x046FFFFF Erased, Time: 01:00
Area4: 0x06000000-0x066FFFFF Erased, Time: 00:57
Area5: 0x047C0000-0x047EFFFF Erased, Time: 00:01
BT MCM (21) Image Found: 0x0002DD94
BT MCM Registering Done
MCU Flashing Completed, Time: 04:47
IMAGE: NHL105530.03
Area2: 0x02000000-0x0214FFFF Erased, Time: 00:11
PPM Flashing Completed, Time: 00:16
Old 01-29-2010, 10:02   #249 (permalink)
ehsas_ghum's Avatar
Member: 171512
Nokia 3500c repair ok
1st boot : C0,07 [rm-272] [2.0.9.0]
rapx id : 000000010000022600010006010c192101001101
em 1 id : 00000232
em 2 id : 00000353
rapx pbid : 26600109e3d96a50b0a8f51dadc9b85f2a2f948f
rapx mode : 00
rapx hash : Baf3a9c3dbfa8454937db77f2b8852b1
rapx roid : 191ec665dfaaf68f
cmt 1st boot ok
cmt 2nd bt: Rap3gv3_2nd.fg, ver: 9.11.1
cmt flid0 : 00ec2208-00006921, sam k8f5615etm
cmt flcnt : 00000000000000000000000000000000000000
cmt mcid0 : Ffff0000-00000000
cmt 2nd boot ok
cmt algo : Rap3gv3_algo.fg, ver: 9.17.0
cmt ksig0 : C0e691ea16a7593a9bb28832d7312a39f7ed668d
cmt vpp : Internal
dual line : True
cmt alg boot ok
image : Rm272__06.01.mcusw
cmt nor erase area: 0x00000000-000006bf
cmt nor erase area: 0x000006c0-0001ffff
cmt nor erase area: 0x00020000-0007ffff
cmt nor erase area: 0x00080000-000dffff
cmt nor erase area: 0x00100000-001fffff
cmt nor erase area: 0x00200000-0031ffff
cmt nor erase area: 0x00320000-0105ffff
cmt nor erase area: 0x01060000-01067fff
cmt nor erase area: 0x01068000-0107ffff
cmt flash erase ok, time: 00:37
written: 10 certificate(s)
cmt flash write ok, time: 02:15
chip sector_size: 128k
warning, must be used 128kb sector_size cnt file
128k image saved as: Rm272__06.01.image_s_azure_128
image : Rm272__06.01.image_s_azure_128
cmt nor erase area: 0x01520000-01fdffff
cnt flash erase ok, time: 00:26
cnt flash write ok, time: 00:51
image : Rm272__06.01.ppm_s
cmt nor erase area: 0x01080000-0151ffff
ppm flash erase ok, time: 00:07
ppm flash write ok, time: 00:26
flashing completed, rebooting mobile
Old 01-30-2010, 07:45   #250 (permalink)
m_tahir1's Avatar
Member: 482214
Sonork: 100.1617896
NOKIA 2330-C SUCCESSFULLY UNLOCK
IMEI: 355248-03-214865-8, ASIC: 11
1st Boot: Ok, DCT4, UPP: V 06.46 23-03-09 RM-512 (c) Nokia
Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032
Algorithm: u3_st_i.fia, Ver: 4.79.0
Algorithm Ok, MSID: 84A024B753E4549FDA95984F90
Decoded MSID: 3E4EBAE9-00110030-AA000000
Encoded FAID: 2DDD79D0-116FE82B-AE589052
Area1: 0x01140000-0x0117FFFF Erased, Time: 00:04
PAT Flashing Completed, Time: 00:02
UI Defaults Ok, Time: 00:06
Set Software Upgrade Defaults Ok, Time: 00:00
Set Security Ok, Time: 00:00
Init Normal Mode Failed, no SIM Card
MCU SW : V 06.46 23-03-09 RM-512 (c) Nokia
PPM SW : V 06.46 23-03-09 RM-512 (c) Nokia MEN
Prd.Code: 0572783
Bpr.Code: 0569925
Prod.Sn : DJP559447
HW Vers : 1000
UEM : 4386
UPP : 12648 [3168]
RFIC Ver: 0500
DSP Vers: ICPR72_09w08_UPP
LCD Type: SUEZ
IMEI : 355248-03-214865-8
SL Conf : 001-01-00000000000
SL Prof : 800000000003000-B
SL Var : 00553552480321486500
SL Aux : 000B5555
HW Sig : 919C460C6478DC5C
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
Old 01-30-2010, 10:02   #251 (permalink)
metals's Avatar
Member: 811779
SAMSUNG E1120
Connect Cable to Switched Off Mobile (with battery)
Software: E1120BVID1
Hardware: MP 0.600
Regions : Orange - Switzerland
Language: de,en,es,fr,hu,it,nl,pl,pt,ro,sl,tr
Release : 2009 April Rev: 1
S/N : RTBSA98498
IMEI: 358054-xx-xxxxxx-x
MSL Active
MSL Deactivated
Flags: 00000001 [Locked]
Key M: 33447550 [MASTER]
Prov : 234-33 Orange, UK
Key 1: 32023930, 00000000 [NET]
Key 2: 00000000, 00000000
Key 3: 00000000, 00000000
Key 4: 00000000, 00000000
Key 5: 00000000, 00000000
Key 6: 00000000, 00000000
Key 7: 00000000, 00000000
Hardware: MP 0.600
S/N : RTBSA98498
Flags: 00000000 [Not Locked]
SLOCK Reset, Ok
Unlock Done
Old 01-30-2010, 15:21   #252 (permalink)
Member: 570227
msung e2120 restart in logo done by hwk
Samsung E2120 restart in logo done by HWK via flashing.......
The Following 3 Users Say Thank You to ALEXIS_089 For This Useful Post:
Old 01-31-2010, 08:33   #253 (permalink)
m_tahir1's Avatar
Member: 482214
Sonork: 100.1617896
Post Samsung c160 successfully unlock phone lock code
SAMSUNG C160 SUCCESSFULLY UNLOCK PHONE LOCK CODE
Software: C160BJLHC1
Hardware: MP 0.300
Warning, Wrong Product Selected [C160]
Regions : JL
Release : 2008 March Rev: 1
MSL Active
S/N : RV2Q465405
IMEI: 357259-01-736301-2
MSL Active
SIMLOCK STATUS: 0020
MCC-MNC: 000-000
IMSI: 9410017560113496
MASTER KEY: 06330390
SIM 4194981064, 00000000
PLK <UN_SET>, <UN_SET>
Unlock KeyString:
Bad SIM Key: 4194981064
MSL Active
MSL Active
MCC-MNC: 000-000
SLOCK Reset, Ok
Unlock Done
MSL Active
CUSTOM Reset, Ok
The Following 2 Users Say Thank You to m_tahir1 For This Useful Post:
Old 02-01-2010, 05:29   #254 (permalink)
m_tahir1's Avatar
Member: 482214
Sonork: 100.1617896
Samsung e900 successfully unlock
SAMSUNG E900 SUCCESSFULLY UNLOCK
Software: E900ACFE2_FJ1
Regions : Vodafone - UK
Language: cs,da,de,el,en,es,fi,fr,hu,it,nl,no,pl,pt,sl,sv
Release : 2006 May Rev: 2
Hardware: MP 1.110
IMEI: 356030-01-214233-4
MSL : Active
S/N : R8WP473741
MSL : Deactivated
Lock Level: beh [Locked]
SPCode[20]: deh adh beh efh deh adh beh efh deh adh beh efh b0h 14h 05h 30h 63h
75h 4bh 20h
NB_CUR_LOCK:88h
NB_CUR_SPCODE:a4h
PCK : 440623439 [Code Error] [#0141*440623439#]
NCK : 438520896 [Code Error] [#0111*438520896#]
SCK : 706666977 [Code Error] [#0121*706666977#]
SPCK: 440623471 [Code Error] [#0133*440623471#]
MCK : 706667480 [Code Error]
BT Address: 001b98-95e138
MSL : Active
S/N : R8WP473741
MSL : Deactivated
Clear SPLocks Done, Time: 00:02
Clear SimLock Done, Time: 00:01
Clear UserLock Done, Time: 00:00
Unlock Done, Time: 00:04
Old 02-03-2010, 06:34   #255 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
M200 unlock done
Software: M200AMHI4
Hardware: MP 0.500
Regions : Vodafone - Germany
Language: de,en,es,fr,it,nl,pt,tr
Release : 2008 September Rev: 4
MSL Active
S/N : R5WQB27501
IMEI: 352653-0**********
BTID: 00236:939922
MSL Active
SIMLOCK STATUS: 0003
MCC-MNC: 262-02 Vodafone D2, Germany
MASTER KEY: 59735380 [Frozen]
NET 91962180, 00000000
SUB 91962180, 00000000
SP 91962180, 00000000
Unlock KeyStrings:
#SIMLOCK*NET*91962180#
#SIMLOCK*SUB*91962180#
MSL Active
MSL Active
SLOCK Reset, Ok
Unlock Done
The Following 2 Users Say Thank You to lilong_lee For This Useful Post:
Successfully unlocked/repaired phones by Infinity-Box gujjar_brothers Infinity-Box 8776 05-20-2013 13:07
MXKEY - Successfully Unlocked/repaired/flashed Phones By MXKey kabirhossain MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3844 04-22-2013 08:30
jazz t161l Successfully Unlocked/repaired Phones By infinity box honey_bbc2001 Chinese Models & Cloned Phones 0 07-07-2009 07:23
Page generated in 0.27760 seconds with 12 queries
