03-23-2015, 14:18 | #4606 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | S3770K IMEI Rebuild Done Code: MSL Active Old IMEI: 000000-00-000000-0 New IMEI: 352xxxxxxxxxxxxx IMEI Rebuild Done, Please Repower Phone Code: Software: S3770KDDLH1 Hardware: REV0.0 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2012 August Rev: 1 CSC Vers: S3770KODDLH1 MSL Active S/N : 0000000000 IMEI: 352xxxxxxxxxxxxx BTID: 0012:47:000001 SIMLOCK STATUS: 0000 MAST: <CRYPTED [UNFREEZE] NET : 00000000 [#SIMLOCK*NET*00000000#] SUB : 00000000 [#SIMLOCK*SUB*00000000#] SP : 00000000 [#SIMLOCK*SP*00000000#] CP : 00000000 [#SIMLOCK*CP*00000000#] SIM : 00000000 [#SIMLOCK*SIM*00000000#] |
03-25-2015, 14:51 | #4607 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Nokia 701 hang logo solved flashing Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 60,07 [Rm-774] [2.3.0.3] CMT ASICID: 000000030000022600010007400C192103032108 EM 1 ID : 00001040 EM 2 ID : 00001030 CMT PUBID : 5E040000FFFF7C404C2EADE09209B059092DB98E CMT MODE : 00 CMT HASH : 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROMID : 2CAC45E23BC33C8B CMT 2ND Bt: RAPUv21_2nd.fg, Ver: 11.34.0 CMT 2ND Bt: SILO OK CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00EC0060-00000032, Sam OneNAND-8G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : RAPUv21_XSR17_alg.fg, Ver: 11.34.0 CMT KSIG0 : FEB3BB7481D3E5D0EAC907335A4402A071493D53 CMT ALG Boot OK IMAGE : RM-774_113.010.1506_79u_prd.core.fpsx CMT NAND Erase Area: 0x00040000-0007FFFF CMT NAND Erase Area: 0x000C0000-008BFFFF CMT NAND Erase Area: 0x010C0000-170FFFFF CMT NAND Partition Format CMT FLASH ERASE OK, Time: 00:01 Written: 16 Certificate(s) CMT FLASH WRITE OK, Time: 00:20 IMAGE : RM-774_113.010.1506_U10.01_79u.uda.fpsx CMT NAND Erase Area: 0x17100000-3E5FFFFF CNT FLASH ERASE OK, Time: 00:02 CNT FLASH WRITE OK, Time: 00:43 IMAGE : RM-774_113.010.1506_18.01_India_79u_prd.rofs2.fpsx CMT NAND Erase Area: 0x0D1C0000-135BFFFF PPM FLASH ERASE OK, Time: 00:00 Written: 1 Certificate(s) PPM FLASH WRITE OK, Time: 00:05 IMAGE : RM-774_113.010.1506_C00.01_79u_prd.rofs3.fpsx CMT NAND Erase Area: 0x01678000-0169FFFF CMT NAND Erase Area: 0x135C0000-170FFFFF CUS FLASH ERASE OK, Time: 00:00 Written: 2 Certificate(s) CUS FLASH WRITE OK, Time: 00:00 Flashing Completed, Rebooting Mobile |
03-25-2015, 15:45 | #4608 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung E1207T Flash DOne :) Code: UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 1xxxx96 HID: 675xxxxxxxxxx4, HWK: A1.04-PRO1 Licence: True AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.5 by SarasSoft Build 54 LogFile: .\_!_LOG\10xxx6_2015_03_25_19_32_21_LOG.txt Loaded Settings from: Sams.ini MCU File: E1207TJPLI6.cla CRC32: 77E9B283 Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2012 September Rev: 6 LPD File: E1207TOJPLI6.lpd CRC32: 801443BD LPD File: E1207TOJPLI6.lpd CRC32: 801443BD MCU File: E1207TJPLI6.cla CRC32: 77E9B283 Connect Cable to Switched Off Mobile (with battery) Preloader Ok F8, 921600 Baud Flsloader Ok FLASH Id: Fidelix, FM25M64A MCU MSL Patched Ok, Time: 00:03 File CRC: 0x8D2A681A MCU Write Done, 4829876 byte(s), Time: 03:49 File CRC: 0xEAAD3051 LPD Write Done, 786432 byte(s), Time: 00:37 TFI File: E1207TOJPLI6.tfi CRC32: D7FC4251 TFI File: E1207TOJPLI6.tfi CRC32: D7FC4251 Connect Cable to Switched Off Mobile (with battery) Preloader Ok F8, 921600 Baud Flsloader Ok FLASH Id: Fidelix, FM25M64A File CRC: 0xD7FC4251 TFI Write Done, 1572864 byte(s), Time: 01:10 |
03-30-2015, 07:20 | #4609 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | C3262 Flashing Done Code: Partition Table: C3262WN.ptt Regions : .P Release : Rev: Connect Cable to Switched Off Mobile (with battery) PROD_ID: 8072DA182C490000 ASIC_ID: 48.31 PRLD_VS: 7.5.16 XL_BAUD: 921600 FLLD_VS: 7.5.16 XL_BAUD: 921600 FL_CHIP: Samsung K521F12ACH [NAND 1G] Read Done, 131072 byte(s), Time: 00:02 Partition IMAGE Erase Done, 1 block(s), Time: 00:00 Partition LCDACT Erase Done, 1 block(s), Time: 00:00 Partition DATA_RW Erase Done, 2 block(s), Time: 00:00 Partition DSP Erase Done, 3 block(s), Time: 00:00 Partition PAGE Erase Done, 55 block(s), Time: 00:00 Partition MAIN Erase Done, 107 block(s), Time: 00:00 Partition a Erase Done, 192 block(s), Time: 00:00 Partition b Erase Done, 280 block(s), Time: 00:00 Partition c Erase Done, 220 block(s), Time: 00:00 Partition d Erase Done, 96 block(s), Time: 00:00 Partition sysv File not Exists, Skipped Partition OTPW Erase Done, 1 block(s), Time: 00:00 Partition IMAGE Write Done, 20480 bytes(s), Time: 00:00 Partition LCDACT Write Done, 32912 bytes(s), Time: 00:00 Partition DATA_RW Write Done, 155648 bytes(s), Time: 00:02 Partition DSP Write Done, 352256 bytes(s), Time: 00:05 Partition PAGE Write Done, 7012324 bytes(s), Time: 01:51 Warning ECC Correction: 1, (Partition: MAIN) Partition MAIN Write Done, 13701120 bytes(s), Time: 03:39 Warning ECC Correction: 1, (Partition: a) Partition a Write Done, 23571778 bytes(s), Time: 06:16 Warning ECC Correction: 2, (Partition: b) Partition b Write Done, 29269376 bytes(s), Time: 07:30 Warning ECC Correction: 1, (Partition: c) Partition c Write Done, 6976256 bytes(s), Time: 01:45 Partition d Write Done, 230656 bytes(s), Time: 00:03 Partition sysv File not Exists, Skipped Warning ECC Correction: 1, (Partition: OTPW) Partition OTPW Write Done, 2112 bytes(s), Time: 00:00 Partition BOOTNAND Write Done, 45984 bytes(s), Time: 00:00 |
03-30-2015, 21:32 | #4612 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Neverland
Member: 1005489 Status: Offline Thanks Meter: 105 | UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 81111 HID: xxxxxxxxxxxxxxxxx, HWK: A1.04-PRO1 Licence: True AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.5 by SarasSoft Build 58 LogFile: .\_!_LOG\81111_2015_03_18_22_24_00_LOG.txt Loaded Settings from: Sams.ini <<< STOP >>> If used non Auto-Ignition cable, press Power-On button No Response from Target IFXFR_ERR_BAD_STX ST_ERR_CERT: If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD213, Ok IF_EBL: xmm2130_JH1_256_128_10.2_M1S1 10.2, Mode: BB BAUD_R: 921600 FL_ID : 89000489, Intel 38F40xxMOY1 256Mb Model : E2350B NCK : 35574410 [#0111*35574410#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] PCK : 00000000 [#0141*00000000#] MCK : 97537190 [#0199*97537190#] ShutDown Done |
03-31-2015, 08:59 | #4613 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung c3312 flashing Insert USB Cable to Switched Off Phone IF_USB: XGOLDxxx IF_SBL: XGOLD215, Ok IF_EBL: 2150_OD_KJ2_3.1 3.1, Mode: BB FL_ID : EC003000, Samsung OneNAND-1G 1024+32Mb Erase Area: 0x00000000 - 0x0FFFFFFD, Erased: 00:00 C3312DDLC5_psi.fls FLASH BUNDLE: Flash File: psi.fls Write Area: 0x00090000 - 0x000AF87E, Written: 00:00 C3312DDLC5_slb.fls FLASH BUNDLE: Flash File: slb.fls Write Area: 0x60000000 - 0x60046042, Written: 00:00 C3312DDLC5_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Write Area: 0x63F60000 - 0x63FB847E, Written: 00:00 C3312ODDLC3_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-C3312_ODD.dffs Write Area: 0x44160000 - 0x45D9665E, Written: 00:43 MSL Patched OK: 00:00 C3312DDLC5_BSY.fls FLASH BUNDLE: Flash File: CATFISH.fls Write Area: 0x63200000 - 0x6386B592, Written: 00:08 Write Area: 0x66000000 - 0x67E3398A, Written: 00:37 ShutDown Done All Done, Time: 01:45 Make [Reset MMI] or Use *2767*3855# at First Start ! |
04-29-2015, 11:46 | #4615 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Infront Of My Laptop Age: 34
Member: 799558 Status: Offline Thanks Meter: 430 | E2252 Flashing Done Code: Connect Cable to Switched Off Mobile (with battery) PROD_ID: 453299008B440510 ASIC_ID: 0A.35 PRLD_VS: PNX491x 1st Loader v.2009-07-08 XL_BAUD: 921600 FLLD_VS: 7.5.16 XL_BAUD: 921600 FL_CHIP: Samsung K521F12ACH [NAND 1G] Read Done, 131072 byte(s), Time: 00:01 Partition IMAGE Erase Done, 1 block(s), Time: 00:00 Partition LCDACT Erase Done, 1 block(s), Time: 00:00 Partition DATA_RW Erase Done, 4 block(s), Time: 00:00 Partition DSP Erase Done, 3 block(s), Time: 00:00 Partition PAGE Erase Done, 48 block(s), Time: 00:00 Partition MAIN Erase Done, 96 block(s), Time: 00:00 Partition ROOT Erase Done, 1 block(s), Time: 00:00 Partition a Erase Done, 157 block(s), Time: 00:00 Partition b Erase Done, 168 block(s), Time: 00:00 Partition c Erase Done, 400 block(s), Time: 00:00 Partition d Erase Done, 80 block(s), Time: 00:00 Partition sysv File not Exists, Skipped Partition IMAGE Write Done, 12288 bytes(s), Time: 00:00 Partition LCDACT Write Done, 24028 bytes(s), Time: 00:00 Partition DATA_RW Write Done, 303104 bytes(s), Time: 00:04 Partition DSP Write Done, 360448 bytes(s), Time: 00:05 Partition PAGE Write Done, 4909032 bytes(s), Time: 01:16 Partition MAIN Write Done, 12029952 bytes(s), Time: 03:06 Partition ROOT Write Done, 43256 bytes(s), Time: 00:00 Partition a Write Done, 19226374 bytes(s), Time: 04:54 Partition b Write Done, 8513472 bytes(s), Time: 02:05 Partition c Write Done, 6340224 bytes(s), Time: 01:34 Partition d Write Done, 145728 bytes(s), Time: 00:02 Partition sysv File not Exists, Skipped Partition BOOTNAND Write Done, 41676 bytes(s), Time: 00:00 |
The Following User Says Thank You to dey mobiles For This Useful Post: |
04-30-2015, 13:32 | #4617 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Samsung c3303 unlock done. Software: C3303XXJG5 Hardware: MP 0.804 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2010 July Rev: 5 CSC Vers: C3303XFVJH1 XFV Customer: South Africa MSL Active S/N : RQVBB46305 IMEI: 353341-04-474526-4 BTID: E4B0:21:6C2BA1 MSL Active SIMLOCK STATUS: 4000 MASTER KEY: 25950900 NET: 00000000, 00000000 SUB: 00000000, 00000000 SP : 00000000, 00000000 CP : 00000000, 00000000 SIM: <UN_SET>, 00000000 ACT: 00000000, 00000000 PLK: 19890311, 00000000 Unlock KeyString: PHONELOCK: 19890311 |
05-03-2015, 10:44 | #4619 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung c3200 write flash/hang logo solved Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2010 September Rev: 1 Insert USB Cable to Switched Off Phone IF_USB: XGOLDxxx IF_SBL: XGOLD213, Ok IF_EBL: xmm2130_INSA_JD2_10.2_M1S1 10.2, Mode: BB FL_ID : 8900B188, Intel 38F60xxMOY1 1024Mb Erase Area: 0x43000000 - 0x47DFFFFE, Erased: 06:31 MSL Patched OK: 00:00 C3200XXJI1_bin.fls FLASH BUNDLE: Flash File: ../HW/XMM6180_EHS2AGR_CATFISH_MADRAS_1.0_CUST/BSY_DEBUG/catfish.fls Erase Area: 0x40000000 - 0x42DFFFFE, Erased: 01:45 Write Area: 0x40000000 - 0x41E59002, Written: 01:49 C3200XXJI1_cds.fls FLASH BUNDLE: Flash File: ../HW/XMM6180_EHS2AGR_CATFISH_MADRAS_1.0_CUST/CDS_DEBUG/catfish.fls Erase Area: 0x42E00000 - 0x42FFFFFE, Erased: 00:06 Write Area: 0x42E00000 - 0x42FCE21A, Written: 00:06 C3200OXAJG3.dffs FLASH BUNDLE: Flash File: temp_GT-C3200_OXA.dffs Erase Area: 0x43000000 - 0x47CFFFFE, Erased: 00:00 Write Area: 0x43000000 - 0x444E3402, Written: 02:55 ShutDown Done All Done, Time: 13:36 Make [Reset MMI] or Use *2767*3855# at First Start ! |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
05-05-2015, 14:40 | #4620 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | S5292 Read UserCode Done Code: Software: S5292DDMB2/S5292ODDMB2 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2013 February Rev: 2 ProdCode: GT-S5292GNAINS IME1: 3546xxxxxxxxxxxxxxxx IME2: 3547xxxxxxxxxxxxxxxx S/N : Rxxxxxxxxxxx BTID: 9CE6E7-7324BD ULCK: 22222222 Level Of Lock: 00h Use Patch MSL, if Want to Read Codes or do IMEI Operations |
The Following User Says Thank You to ishant For This Useful Post: |
Successfully unlocked/repaired phones by Infinity-Box | Infinity-Box | Infinity-Box | 76078 | Yesterday 19:06 |
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX | kabirhossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3969 | 10-05-2016 05:13 |
jazz t161l Successfully Unlocked/repaired Phones By infinity box | honey_bbc2001 | Chinese Models & Cloned Phones | 0 | 07-07-2009 07:23 |
