05-19-2015, 10:54 | #4636 (permalink) |
Freak Poster Join Date: Apr 2014 Location: indore Age: 26
Member: 2175391 Status: Offline Sonork: 100.1663566 Thanks Meter: 104 | Samsung E1085F Sim Lock Unlock Done By Hwk Samsung E1085F Sim Lock Unlock Done By Hwk All Unlock Done ...:::BR:::.... RAVI_RAJPUT |
The Following User Says Thank You to ravi oad For This Useful Post: |
05-22-2015, 14:49 | #4637 (permalink) |
Member: 2175391 Status: Offline Sonork: 100.1663566 Thanks Meter: 104 | Samsung C3312 Full Flash Done With Box Samsung C3312 Full Flash Done With Box Just Write Flash Hang Logo Solve ...:::BR:::... RAVI_RAJPUT |
05-23-2015, 05:48 | #4638 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Samsung e2220 unlock done. Software: E2250XXLG2 Hardware: MP 0.500 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2012 July Rev: 2 CSC Vers: E2250XFMLG1 XFM Customer: South Africa MSL Active S/N : RV1C757S10 IMEI: 351849-05-173104-5 BTID: D857:EF:0D1F2E MSL Active SIMLOCK STATUS: 4020 IMSI: 9655103203491195 MASTER KEY: 74867610 NET: 00000000, 00000000 SUB: 00000000, 00000000 SP : 00000000, 00000000 CP : 00000000, 00000000 SIM: 5157, 00000000 ACT: 00000000, 00000000 PLK: 526256, 00000000 Unlock KeyString: PHONELOCK: 526256 MSL Active MSL Active SIMLOCK STATUS: 0000 IMSI: 9655103203491195 MASTER KEY: 74867610 NET: 00000000, 00000000 SUB: 00000000, 00000000 SP : 00000000, 00000000 CP : 00000000, 00000000 SIM: 5157, 00000000 ACT: 00000000, 00000000 PLK: 526256, 00000000 SLOCK Reset, Ok Unlock Done |
The Following User Says Thank You to ij_cell For This Useful Post: |
05-25-2015, 09:18 | #4639 (permalink) |
Member: 2175391 Status: Offline Sonork: 100.1663566 Thanks Meter: 104 | Samsung 1207 Few Minet Hang Pro... Slove By Hwk Box Just Full Flash Done ...:::BR:::... RAVI_RAJPUT |
05-25-2015, 16:24 | #4640 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung e2232 unlock ProdCode: GT-E2232ZKAINU IME1: 357108-04-++++++ IME2: 357109-04-++++++ S/N : RDDB494902 BTID: 2013E0-B1D03D ULCK: 0852 Level Of Lock: 00h Use Patch MSL, if Want to Read Codes or do IMEI Operations Or Untick [AT Info Mode] to Read Codes IME1: 357108-04-++++++ IME2: 357109-04-++++++ S/N : RDDB494902 Use Patch MSL, if Want to Read Codes or do IMEI Operations Or Untick [AT Info Mode] to Read Codes Factory Reset Done, Wait for Product Restart |
05-26-2015, 09:57 | #4641 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung e1200t unlock Connect Cable to Switched Off Mobile (with battery) Software: E1200TDDLC8 Hardware: MP 0.400 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2012 March Rev: 8 CSC Vers: E1200TODDLC9 INS Customer: India Use [Patch MSL] to bypass MSL S/N : RZ1C50KYN5 IMEI: 352475-05-472790-2 Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL Connect Cable to Switched Off Mobile (with battery) Preloader Ok F8, 921600 Baud Flsloader Ok FLASH Id: Fidelix, FM25M64A File CRC: 0x329CDB4D MCU Write Done, 262144 byte(s), Time: 00:13 MCU MSL Patched Ok, Time: 00:31 Connect Cable to Switched Off Mobile (with battery) MSL Deactivated SLOCK Reset, Ok Unlock Done MSL Deactivated Restart Done |
05-26-2015, 11:55 | #4642 (permalink) |
Member: 2175391 Status: Offline Sonork: 100.1663566 Thanks Meter: 104 | Samsung E1232B Dead recover Done By Hwk Box Samsung E1232B Dead recover Done By Hwk Box Just write Flash Done ...:::BR:::... RAVI_RAJPUT |
05-30-2015, 05:07 | #4644 (permalink) |
Member: 2175391 Status: Offline Sonork: 100.1663566 Thanks Meter: 104 | Samsung C6112 Dead Recover Done By Hwk Box Samsung C6112 Dead Recover Done By Hwk Box Just Full Flashing By Hwk Box Done ...:::BR:::... RAVI_RAJPUT |
06-08-2015, 15:33 | #4649 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Samsung b3210 flash done via usb cable. Region: 1, 0x20000000-0x20000063, Length: 100 bytes Region: 2, 0x2000C000-0x20011457, Length: 21592 bytes Region: 3, 0x20016000-0x2001C59B, Length: 26012 bytes Region: 4, 0x2001E000-0x2001E0B3, Length: 180 bytes Region: 5, 0x2003803C-0x20056A83, Length: 125512 bytes Region: 6, 0x20080000-0x20080037, Length: 56 bytes Region: 7, 0x20080138-0x20084F3D, Length: 19974 bytes Region: 8, 0x200A0000-0x201B632F, Length: 1139504 bytes Region: 9, 0x20300000-0x22617CDF, Length: 36797664 bytes USB Boot Ok, McuId: 00050015, Ubl: 43251F0E, 7-1.1 (Vision X115E) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s06_t.sre Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 MCU File: B3210ZCJL1.s3 Flashing NOR part... Write Done, 38130674 byte(s), Time: 04:01 CTS File: B3210CHNJL1.csc FS Formated (FDI) FS Mounted (FDI) Files Count: 103 FS Unmounted FS Write Done, 13662676 byte(s), Time: 06:22 MSL3 CODE Mismatch, use [Repair MSL] not need to Write E2P or MCU ! S/N : RD5Z316089 USB Closed, Reconnect Cable and Repower Phone for Next Operation |
Successfully unlocked/repaired phones by Infinity-Box | Infinity-Box | Infinity-Box | 76097 | Yesterday 06:20 |
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX | kabirhossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3969 | 10-05-2016 05:13 |
jazz t161l Successfully Unlocked/repaired Phones By infinity box | honey_bbc2001 | Chinese Models & Cloned Phones | 0 | 07-07-2009 07:23 |
