11-03-2018, 09:30 | #4756 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung E1205T Write firmware Done :) Code: MCU File: E1205TJP.cla CRC32: 85B3BCAF E1205TJP.cla TFS File: E1205TJPLD2.tfs CRC32: 75336D48 CFG File: E1205TJPLD2.cfg 7445 byte(s) CSC File: E1205TOJPLD1.csc CRC32: BC4C1CBB Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2012 April Rev: 1 CCF File: E1205TOJPLD1.ccf 9826 byte(s) LPD File: E1205TOJPLD2.lpd CRC32: 85795C50 LPD File: E1205TOJPLD2.lpd CRC32: 85795C50 MCU File: E1205TJP.cla CRC32: 85B3BCAF TFS File: E1205TJPLD2.tfs CRC32: 75336D48 CFG File: E1205TJPLD2.cfg 7445 byte(s) CSC File: E1205TOJPLD1.csc CRC32: BC4C1CBB CCF File: E1205TOJPLD1.ccf 9826 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok F8, 921600 Baud Flsloader Ok FLASH Id: Fidelix, FM25M64A Erase Done, 40 sector(s), Time: 00:10 MCU MSL Patched Ok, Time: 00:03 File CRC: 0xCF6BB109 MCU Write Done, 4041760 byte(s), Time: 03:19 File CRC: 0x6AA05149 LPD Write Done, 786432 byte(s), Time: 00:38 File CRC: 0x75336D48 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 20 Max_Files : 91 Files_Count: 91/91 Files Closed TFS Unmounted TFS Write Done, 509015 byte(s), Time: 00:29 CSC Format Done, Time: 00:06 File CRC: 0xBC4C1CBB TFS Version: TFS4.0_CORONA_01 Directories: 29 Max_Files : 107 Files_Count: 107/107 Files Closed CSC Unmounted CSC Write Done, 229949 byte(s), Time: 00:24 |
12-04-2018, 08:53 | #4757 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 1208 Write Flash Done :) Code: 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.3.0.3] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 8485B6FDF126EC259C814CCA40 Decoded MSID: 3E4EBAE9-00D7BB50-A8000000 Encoded FAID: 76207A67-80082CBC-9B8A2EA0 IMAGE: rh105_06.000 Erasing: 0x01000000-0x0100FFFF ... Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Erasing: 0x01010000-0x013AFFFF ... Area2: 0x01010000-0x013AFFFF Erased, Time: 00:38 Erasing: 0x013B0000-0x013EFFFF ... Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:20 IMAGE: rh1050_nai6.00ia Erasing: 0x01380000-0x013AFFFF ... Area1: 0x01380000-0x013AFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Running: Server fake reply for CUI phone. Contents Package Extracting Ok, Time: 00:10 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.3.0.3] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 84731DDC63B285305118F06EFF Decoded MSID: 3E4EBAE9-00D7BB50-A9000000 Encoded FAID: 6E2D7D8F-70666477-6B792404 IMAGE: rh105_06.00ia Erasing: 0x01240000-0x0124FFFF ... Area1: 0x01240000-0x0124FFFF Erased, Time: 00:00 Erasing: 0x01250000-0x0137FFFF ... Area2: 0x01250000-0x0137FFFF Erased, Time: 00:13 PPM Flashing Completed, Time: 00:10 Flashing Completed, Rebooting Mobile Set UI Defaults ... UI Defaults Ok, Time: 00:03 Set UI Factory Defaults ... Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults ... Set Full Factory Defaults Ok, Time: 00:01 Set Software Upgrade Defaults ... Set Software Upgrade Defaults Ok, Time: 00:00 Set Security 12345 ... Set Security Ok, Time: 00:00 MCU SW : V 6.00 30-09-09 RH-105 (c) NMP PPM SW : V 6.00 30-09-09 RH-105 (c) NMP IA Prd.Code: 0561971 Bpr.Code: 0571405 Prod.Sn : INM261745 HW Vers : 2602 UEM : 1328 UPP : 8850 [2292] RFIC Ver: 0700 DSP Vers: ICPR62_08w31_UPP LCD Type: TPO:NAXvD6 ST7628 IMEI : 351956-03-793194-4 SL Conf : 234-00-00300000000 SL Prof : 800000000001000-2 SL Var : 00003519560379319400 SL Aux : 000B0000 HW Sig : AF56E43E2DF9E291 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Virgin (some 3510i);United Kingdom |
01-10-2019, 09:55 | #4759 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung E1205T write firmware Done :) Code: UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 1038xx HID: 6754xxxxxxxx, HWK: A1.04-PRO1 Licence: True AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.5 by SarasSoft Build 71 LogFile: .\_!_LOG\103896_2019_01_10_13_43_09_LOG.txt Loaded Settings from: Sams.ini MCU File: E1205TJP.cla CRC32: 85B3BCAF E1205TJP.cla TFS File: E1205TJPLD2.tfs CRC32: 75336D48 CFG File: E1205TJPLD2.cfg 7445 byte(s) CSC File: E1205TOJPLD1.csc CRC32: BC4C1CBB Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2012 April Rev: 1 CCF File: E1205TOJPLD1.ccf 9826 byte(s) LPD File: E1205TOJPLD2.lpd CRC32: 85795C50 LPD File: E1205TOJPLD2.lpd CRC32: 85795C50 MCU File: E1205TJP.cla CRC32: 85B3BCAF TFS File: E1205TJPLD2.tfs CRC32: 75336D48 CFG File: E1205TJPLD2.cfg 7445 byte(s) CSC File: E1205TOJPLD1.csc CRC32: BC4C1CBB CCF File: E1205TOJPLD1.ccf 9826 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok F8, 921600 Baud Flsloader Ok FLASH Id: Fidelix, FM25M64A Erase Done, 40 sector(s), Time: 00:11 MCU MSL Patched Ok, Time: 00:03 File CRC: 0xCF6BB109 MCU Write Done, 4041760 byte(s), Time: 03:19 File CRC: 0x6AA05149 LPD Write Done, 786432 byte(s), Time: 00:38 File CRC: 0x75336D48 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 20 Max_Files : 91 Files_Count: 91/91 Files Closed TFS Unmounted TFS Write Done, 509015 byte(s), Time: 00:26 CSC Format Done, Time: 00:06 File CRC: 0xBC4C1CBB TFS Version: TFS4.0_CORONA_01 Directories: 29 Max_Files : 107 Files_Count: 107/107 Files Closed CSC Unmounted CSC Write Done, 229949 byte(s), Time: 00:23 |
01-12-2019, 10:35 | #4760 (permalink) | |
Major Poster Join Date: Jul 2005 Age: 50
Member: 163036 Status: Offline Thanks Meter: 2 | It is possible ??? Quote:
How i can run it or update ??? Can you help me ??? | |
09-27-2019, 07:47 | #4762 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | 1st Boot: Ok, DCT4, UPP: 2292 [] [2.3.0.3] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2606,Sam K8S3215ETF Algorithm: u3_amd.fia, Ver: 4.79.0 Rebooting Mobile MCU SW : V 5.80 14-11-08 RH-105 (c) NMP PPM SW : V 5.80 14-11-08 RH-105 (c) NMP IJ Prd.Code: 0549906 Bpr.Code: 0582127 Prod.Sn : HID770585 HW Vers : 1621 UEM : 1328 UPP : 8850 [2292] RFIC Ver: 0700 DSP Vers: ICPR62_08w31_UPP LCD Type: SDI:NAXv89 S6B33BD IMEI : 358243-03-576111-7 SL Conf : 001-01-00000000000 SL Prof : 000000000001000-2 SL Var : 00003582430357611100 SL Aux : 000B0000 HW Sig : 0ADFDF084120D828 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.3.0.3] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2606,Sam K8S3215ETF Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84383598C4B9447B00F68DC9D6 Decoded MSID: 3E4EBAE9-00C94932-A8000000 Encoded FAID: 8ED4E755-2BED923B-F993DAFE IMAGE: rh105_06.000 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:23 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:02 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:13 IMAGE: rh1050_nai6.00ia Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:00 Running: Server fake reply for CUI phone. Contents Package Extracting Ok, Time: 00:06 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.3.0.3] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2606,Sam K8S3215ETF Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 845ABC05E492FFC194F19B7050 Decoded MSID: 3E4EBAE9-00C94932-A9000000 Encoded FAID: D636F63D-CD1F118A-B7C9319A IMAGE: rh105_06.00ia Area1: 0x01240000-0x0124FFFF Erased, Time: 00:00 Area2: 0x01250000-0x0137FFFF Erased, Time: 00:07 PPM Flashing Completed, Time: 00:07 Flashing Completed, Rebooting Mobile Set Full Factory Defaults Ok, Time: 00:04 |
08-10-2020, 14:40 | #4763 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung gt-s3802 user lock read Code: Licence: True AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.5 by SarasSoft Build 71 LogFile: .\_!_LOG\79332_2020_08_10_19_03_49_LOG.txt Loaded Settings from: Sams.ini Software: S3802DDMC3/S3802ODDMC5 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2013 March Rev: 5 ProdCode: GT-S3802CWAINU IME1: 355433-05-++++++ IME2: 355434-05-++++++ S/N : RZ1D62M9MG BTID: 781FDB-70D170 ULCK: 0987 Level Of Lock: 00h Error when Extracting Codes |
09-18-2020, 15:44 | #4765 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | Quote:
Yes, download offline installer but you must obtain box update and hwk license online first, while you do the rest manually with the offline installer. | |
01-16-2021, 08:54 | #4766 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung e1207t blinking solve old box UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 79??? HID: D09CEAD7?????????, HWK: A1.04-PRO1 Licence: True AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.5 by SarasSoft Build 71 LogFile: .\_!_LOG\79???_2021_01_16_13_03_03_LOG.txt Loaded Settings from: Sams.ini LPD File: E1207TODDLJ2.lpd CRC32: AAB1BFA0 TFI File: E1207TODDLJ2.tfi CRC32: 32EA0040 MCU File: E1207TDDLL1.cla CRC32: E3719815 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2012 December Rev: 1 MCU File: E1207TDDLL1.cla CRC32: E3719815 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2012 December Rev: 1 LPD File: E1207TODDLJ2.lpd CRC32: AAB1BFA0 TFI File: E1207TODDLJ2.tfi CRC32: 32EA0040 MCU File: E1207TDDLL1.cla CRC32: E3719815 Connect Cable to Switched Off Mobile (with battery) 1st Boot Failed: Preloader not Run LPD File: E1207TODDLJ2.lpd CRC32: AAB1BFA0 TFI File: E1207TODDLJ2.tfi CRC32: 32EA0040 MCU File: E1207TDDLL1.cla CRC32: E3719815 Connect Cable to Switched Off Mobile (with battery) Preloader Ok F8, 921600 Baud Flsloader Ok FLASH Id: Fidelix, FM25M64A MCU MSL Patched Ok, Time: 00:03 File CRC: 0xB1D9CE24 MCU Write Done, 4856644 byte(s), Time: 04:25 File CRC: 0xC5166338 LPD Write Done, 1048576 byte(s), Time: 00:57 File CRC: 0x32EA0040 TFI Write Done, 1900544 byte(s), Time: 01:41 |
Successfully unlocked/repaired phones by Infinity-Box | Infinity-Box | Infinity-Box | 76097 | Yesterday 06:20 |
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX | kabirhossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3969 | 10-05-2016 05:13 |
jazz t161l Successfully Unlocked/repaired Phones By infinity box | honey_bbc2001 | Chinese Models & Cloned Phones | 0 | 07-07-2009 07:23 |
