Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 03-28-2012, 09:03   #1 (permalink)
GSM BROTHER's Avatar
Member: 1714224
Arrow Ufs always problem on 3110 6300 3500c
I HAVE MANY CABLES BUT RESULT YOU CAN SEE
PLZ GIVE ME SOLUTION
The Following User Says Thank You to GSM BROTHER For This Useful Post:
Old 03-28-2012, 09:13   #2 (permalink)
jawad_anis's Avatar
Member: 726546
Sonork: 100.1578784
just uncheck ( 1331 ) then check again if u r sure about urs fbus cable
Old 03-28-2012, 09:35   #3 (permalink)
6622622's Avatar
Member: 1562066
Just unchecked dual line
Old 03-28-2012, 09:49   #4 (permalink)
Member: 472482
Flash with usb ,not with fbus ! Easy and faster!
Old 03-28-2012, 10:01   #5 (permalink)
Member: 1714224
Arrow
Originally Posted by dominik1 View Post
flash with usb ,not with fbus ! Easy and faster!
ok but here some problems via usb flashing calculater & some themes not recover
Old 03-29-2012, 06:44   #6 (permalink)
Member: 1714224
i,m waiting reply from team
Old 03-29-2012, 06:54   #7 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Calculator and Themes are firmware Error not Box, Cable or HWK platform.
Take ,3110c Version 7.30, has a case study. If you need calculator in it. You gotta download Image that contains it. look for {rm237__07.30.image_ora_pl_games_128} in navifirm
~~Always say thanks~~
The Following User Says Thank You to chubbie For This Useful Post:
Old 03-31-2012, 10:46   #8 (permalink)
ucokmonalisa's Avatar
Member: 527741
I used to use flasher box jaff .... but cut the purple flash cable ..... no problem at all if using jaff box if using the HWK is always a problem.....
Old 04-13-2012, 13:02   #9 (permalink)
Member: 1714224
any body give me write solution plz i will wait
Old 04-13-2012, 17:27   #10 (permalink)
Member: 540512
i was faced some problem. need to use 7pin fbus cable work fine......... do not use 5pin fbus cable.
Old 04-13-2012, 19:07   #11 (permalink)
Member: 1737175
Sonork: 100.1616423
I think your box is micro that also third party effected clone ... if it is then it is obvious to face this problem often ... but if you are using original HWK then it Cable problem .......
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
FREECALL HACKED SIMS ON SALE FROM FREECELL! FREECELLUK Main Sales Section 0 07-07-1999 23:22
Page generated in 0.82629 seconds with 11 queries
