Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 07-25-2007, 15:53   #1 (permalink)
Genius's Avatar
Member: 12663
UFS + HWK stop working, Odia please look...
Hi,
I have UFS3 and org. HWK inside since begining of sale.
I have working with some LG phone and evrything was OK, HWK was working
like usuall, but then afther reconect UFS it gives me and error and searching
for activation file. I dont even remmember when have I last time use any
activation for ufs ( maybe freia ) !
When I start Update Client and when it connects to box, it gives me
message " Licsnse 5 not active ", and nothing works.
Where is problem and how to solve it?
UFS is working 100%, I have test it with JAF software and select UFS as
desired device. Evrything was working OK, but HWK SW will not work ( cant connect )!.
Old 07-26-2007, 09:25   #2 (permalink)
Genius's Avatar
Member: 12663
Here is photo...
I have already contact my reseller and waiting for response...
Old 07-26-2007, 09:48   #3 (permalink)
llcoolr's Avatar
Member: 53408
Sonork: 100.1593951
ur ufs serial is currupted
try flash it with ufstool
best thing to do wait ur reseller for support
Old 07-26-2007, 09:53   #4 (permalink)
Genius's Avatar
Member: 12663
Yes, I have see that, but in STATUS BAR, my box serial is correct !
Only in main form window is ( - 86072142 ), which is incorrect.
Is there any HWK team member that can provide solution for this or any
caind of help how to solve this pb???
Old 07-27-2007, 06:37   #5 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Try to run the update client and click next, wait .... quit (No need to run Start HWK Update), record the log and post here, you can also try your box after this and check the status, use DCTxBB5.
The problem is with your UFS box, the test via JAF means nothing, since it does not boot the box, only uses the communication.
Odia.
Old 07-27-2007, 10:42   #6 (permalink)
Genius's Avatar
Member: 12663
Odia.
I have repair it yesterday, afther no response from any of HWK team, I decide to
flash box with new firmware & eeprom. Afther that I start upgrade client,
and box was updated. Now is working again and evrything is OK!
Here is log:
Upgrade log:
---------- HWK Update Client v 2.0.5.0 ----------
---------- HWK upgrade started:12:29:06 ----------
-- Target Id : 62 CF 1 7
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.6 (c) SarasSoft 2005.
-- UFSx S/N : XXXXX
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: UFS3
-- HWK ID : A1.04-PRO1-XXXXXXXXXXXXXXX
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication successfull.
Checking upgrade client version...
Your upgrade client is up-to-date.
Upgrading HWK...
HWK upgrade process completed.
---------- HWK upgrade finished:12:29:18 ----------
Before writing new flash & eeprom to box I was having error message with
upgrade client " License 5 not active ".
Also BOX_AUTH_ERROR_1111, something like that, dont remmember now...
At least, it works now!
Old 07-27-2007, 12:57   #7 (permalink)
tareen's Avatar
Member: 80475
if you send me box serial, I will calculate the activation code for you mate
Old 07-27-2007, 14:28   #8 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
its too late
problem solved see this
http:///vbb/showpo...39&postcount=6
Old 08-01-2007, 15:46   #9 (permalink)
Member: 80882
Lightbulb pliz................
Old 08-05-2007, 20:53   #10 (permalink)
chotky's Avatar
Member: 39460
Here is log:
Upgrade log:
-- UFSx S/N : XXXXX
-- Licence 5 : True
Upgrading HWK...
u have used wich tool ?
write uem failed dear odia please look at this fahim8888 HWK 1 10-05-2009 22:57
ufs hwk not working anymore lawrence9880 HWK 4 10-26-2006 13:21
Page generated in 0.39724 seconds with 12 queries
