Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 05-13-2013, 23:38   #1 (permalink)
Member: 1597617
ufs-hwk wont read flash g600
Hallo everybody...What can be problem..I want read flash from samsung g600 with micro ufs-hwk box and I cant..dont know why.
Im read same phones before and I was succesfull.
Can be phone blocked or somethink inside...why I cant read flash?
Here is log
1st Boot Failed: 1st Response: 1, 81
Every help will be appreciated.
Old 05-14-2013, 01:19   #2 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,512
Here is log
Friend! Put Log here from hwk.
Regards
Old 05-14-2013, 01:26   #3 (permalink)
Member: 1597617
Regards
Old 05-14-2013, 01:40   #4 (permalink)
Haicha's Avatar
Member: 330579
Friend! First is better you update to 2.2.0.3 after check drivers, use correct cable. Phone without battery.
Regards
Old 05-14-2013, 01:44   #5 (permalink)
Member: 1597617
Regards
Ok..I will do it..but other samsung g600 i can easy save flash..so should be problem inside phone?maybe hardware ..i open phone..dont see nothing inside..same pcb have other phones and I can save flash...
Old 05-14-2013, 01:49   #6 (permalink)
Haicha's Avatar
Member: 330579
Yes! can be hardware problem Try clean Phone connector.
Regards
Old 05-14-2013, 02:00   #7 (permalink)
Member: 1597617
Regards
im updae and still problem...also im already clean conector with special liquid.
this man do somethink with phone...thats why i cand read flash...just i need to find what he do...i cant read flash...
Old 05-16-2013, 11:43   #8 (permalink)
Member: 1597617
Im buy same phone from this seller..phone is new and I cant read flash again from g600..
Phone is new..and I see was opened..so now I know he made something inside....Can somebody help me what this man done ?..that I cant read flash from phone..I have ufs hwk and z3x box and both cant read flash..other phone I can.
Old 05-16-2013, 12:09   #9 (permalink)
satch1234's Avatar
Member: 1005489
Thanks Meter: 105
Hello,
That model is 6 years old,where did you buy new phones?
Why you want to flash it?
Download flashfiles from support and flash it.
Connect phone without battery and it should boot fine,just tested one.
I used J750 cable,should work also with E210 cable.If you want to see log i will post here.
Regards
Old 05-16-2013, 12:37   #10 (permalink)
satch1234's Avatar
Member: 1005489
Thanks Meter: 105
Hi,
I use 2.2.0.2 version because 2.2.0.3 have bugs.
Use baud rate 460800,
Try to change cable,
Can you make mobile info with battery?TAT mode ok?
If mobile info ok then remove battery and try read flash.
Br.
Software: G600XFGL1
Hardware: MP 0.901
Regions : Bulgaria,Croatia,Hungary,Macedonia,Romania,Serbia, Slovenia
Language: bg,en,hr,hu,mk,ro,sl,sr
Release : 2007 December Rev: 1
MSL Active
S/N : R1VQ125014
IMEI: 351891-02-xxxxxxxx
BTID: 001E:E2:0DD29C
MSL Active
SIMLOCK STATUS: 0000
MCC-MNC: 000-000
MASTER KEY: 00000000
NET 00000000, 00000000
SUB 00000000, 00000000
SP 00000000, 00000000
CP 00000000, 00000000
SIM 00000000, 00000000
ACT 00000000, 00000000
PLK 00000000, 00000000
MCU Id: 3541, PNX5230/31
Preloader Ok, 460800 Baud
Flashloader Ok
FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G]
<<< STOP >>>
Bad Resp: 0000 at: 0x10048000
MCU Read Failed, at: 0x00048000
Failed because i pressed stop button.
Old 05-16-2013, 13:21   #11 (permalink)
Member: 1597617
Both phone Im buy from this seller wont read mobile info and wont read flash...1 phone is new and 1 is used...
new g600 phone can buy on ebay..they still sell...
other phone g600 I can read and read mobile info..
He make some hardware changes..thats why I cant read flash..
because it is g600 stealth phone and he dont want somebody save flash from his phone....
I need to find what is disconected on pcb phone...
is there any options read flash ? with some eeprom reader etc..
Im try j750 and e210 cable
Page generated in 0.23224 seconds with 8 queries
