11-28-2009, 13:15 | #1 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1127597 Status: Offline Thanks Meter: 0 | ufs micro problem 1st Boot Err: Bad Resp UFSx 1st Boot Err: Bad Resp UFSx Rebooting Mobile i try to change cable but still the same , but in another computer work fine ?? Please help . |
11-28-2009, 13:21 | #2 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
If above does not help, they try another USB port, direct to mainboard are better ports, you maybe suffering from low USB power. Odia. | |
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post: |
11-29-2009, 12:50 | #5 (permalink) | |
Versions: Ufs2xx.dll x.x.xx, Ufs2xx.sys x.x.xx You also need to check the power and current supplied by your USB ports. Since you know this box works ok on another PC. Did you use the same USB cable on the other PC? Odia. | |
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
12-05-2009, 13:18 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 44
Member: 265133 Status: Offline Thanks Meter: 285 | my box is not working it gets connected well but whichever set i try to flash whether its dct4 or bb5 i get 1st boot error when i checked the voltage at battery point of each and every cable i connect the voltage is 0 what to do ? |
u900 micro problem | orangade | Samsung Hardware Repair | 1 | 03-29-2010 22:16 |
Ufs micro problem | ashish444_jse | UFS - Pro | 4 | 06-14-2009 14:25 |
