09-17-2005, 20:21 | #46 (permalink) |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | |
09-17-2005, 20:49 | #47 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: UK
Member: 90865 Status: Offline Thanks Meter: 1 | Quote:
Is this to do with ini file entries? -- WolfMan | |
09-18-2005, 03:50 | #49 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 42
Member: 72851 Status: Offline Thanks Meter: 28 | Release LG is good and a lot of limitation at starting is normal but the real problem weather this addon will have full support from Saras Team? Or just like Siemen!! I think all HWK user want to know this!!! Best Regard Gsm-W |
09-18-2005, 14:53 | #51 (permalink) | |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Quote:
Jay My biggest problem is getting some damn LG gsm cables mate where did you get yours as no one has any listed an I could do with them to work with Vygis too same as you. Regards ur old mate Charlie | |
09-18-2005, 15:25 | #52 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
i use com leads for my vygis, as i have the original and not cracked, i would presume that universal cables would be ok though! | |
09-19-2005, 13:39 | #53 (permalink) |
Crazy Poster Join Date: Feb 2003
Member: 20847 Status: Offline Thanks Meter: 0 | since update 1, I can't use the ufs hwk for any samsung work, because it wouldn't put any phone into TAT mode, it was only to "OM/swift" models but now none of the models can be done. Just now i try to unlock a sonyericsson Z1010 and I can't; McuId: 71000301FFFFFF, CID: 29, 4 (Red) Baud Rate: 460800 Trying: CXC1325413_040614_1539_R3M{0101020101}.bin Trying: CXC1325413_040614_1539_R3M{0101020301}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 040614 1539 LLECXC1325413_CERTLOADER R3M, Ok IMEI : 353456-00-172975-0, CID: 29, CDT: 1 0 1 (Red) Fl_Id: 8964, Intel 640W18TD OTP_F: 0D7294012D406732 - Locked OTP_U: 0D80B06405F03A2A - Locked BLK_0: 0x240F0000 IMEI : 353456-00-172975-0 OTP CID: 29, GDFS CID: 29 ULCK : 0000 - Off NCK : Closed [5-5] 234-33 NSCK : Open [5-5] 234-33 SPCK : Open [5-5] 234-33 CCK : Open [5-5] 234-33 PCK : Open [5-5] 234-33 ESLK : Open [5-5] Flags : 01FFFFFFFFFFFFFFFFFF [UMTS] Security Backup: Z1010_35345600172975_19092005_132329.sim Security Initialization Done, Time: 00:05 and then this error come up; Exception: Access violation at address 004DE085 in module 'UFS_KXF.exe'. Write of address 075136FC UFS was working before, why more updates later, rather then getting better it get alot worst? |
need UFS Suite Setup v2.01 | adam92se | HWK | 3 | 07-28-2007 17:04 |
UFS Suite Setup v1.0 released - Discussion | Odia The Ultimate | HWK | 33 | 03-10-2007 07:20 |
UFS Suite Setup v2.0 released - Discussion | FullFLASHgSMPH | HWK | 100 | 12-30-2005 19:54 |
UFS Suite Setup v2.01 update | ufs2flasher | UFS2 + UFS3-Tornadoflasher | 0 | 09-17-2005 11:54 |
UFS Suite Setup v2.01 update | ufs2flasher | HWK | 0 | 09-17-2005 11:50 |
