09-21-2007, 12:57 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 43
Member: 57806 Status: Offline Thanks Meter: 4 | Unlock LG KE970 & SAM E590 not working! On Samsung E590 (or U600) I've tried with or without battery by reading codes or direct unlock, but not working On LG KE970 I can boot but if clicking unlock, it shows Bad Product Settings Any suggestions? |
09-21-2007, 17:16 | #2 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Correct INI file in attachment. Replace it in C: Program FIles SarasSoft UFS_LG_GSM, and all will be OK. Just unlocked KE970 w/o any problems. Quote:
BR | |
09-24-2007, 17:01 | #5 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: PH Age: 47
Member: 167930 Status: Offline Thanks Meter: 5 | Quote:
ini not configured well | |
10-04-2007, 12:01 | #7 (permalink) |
Freak Poster Join Date: Apr 2001
Member: 4184 Status: Offline Thanks Meter: 1 | Is the cable and pinout same for the KG800 and KE970? Because the KE970 doesn't boot for me. I press the power on button but nothing happens. If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done |
10-19-2007, 20:49 | #8 (permalink) |
Registered User Join Date: Mar 2006 Location: Hungary Age: 50
Member: 245884 Status: Offline Thanks Meter: 21 | Hi, press BOOT,insert battery and only now press power on when spell program how :If used non Auto-Ignition cable, press Power-On button IF_PL : SG2, Ok IF_EBL: Default_RAM_Bootloader.7.0, Mode: BB BAUD_R: 921600 FL_ID : 89007E88, Intel Sibley 512+512Mb Unlock Done, Time: 0:00 ShutDown Done .ini work good!!!!!!!!! B.R. |
10-30-2007, 22:16 | #10 (permalink) |
Member: 57806 Status: Offline Thanks Meter: 4 | Now what about Samsung E590 or U600? It's supported by HWK but i tried everything (with or without battery, read codes, direct unlock, unlock e2p,...) and didn't success! |
01-26-2008, 12:21 | #13 (permalink) |
Junior Member Join Date: Mar 2007 Location: poland
Member: 474481 Status: Offline Thanks Meter: 11 | i have ufs with hwk but can't unlock ke970 cuz this function is inaccessible, i don't know why only i can read this model, for example: IMEI: 356130-xx-******x-x PSN : 79820583071218002145000000000000 SWV : KE970P40FL-48-V10c-260-03 DEC 10 2007+0 how can i unlock this model? in other lg model was nck code but here only psn :/ |
04-11-2008, 20:53 | #14 (permalink) | ||
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | Quote:
If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done I have just bought the KG800 UFS service cable & it seems so good appears not damaged , shall i went to buyer to replace the cable or did i missed something tricky ???!!! | ||
sam p777 not working on gsm band 900/1800 | infogsm | Trident/AGERE Platform | 4 | 04-15-2011 17:02 |
V980 0 & 5 key not working after unlock | Softway | Motorola Hardware Repair | 1 | 05-11-2007 01:09 |
sam x686 not working 850 mhz band | gsmuy | UST Pro II | 0 | 02-23-2007 20:03 |
freia & update tool not work sst & universal remote work ok any help please | asmar | E-Gold Based Phones | 1 | 01-18-2006 15:49 |
unlock lg 7100 with red box not working. | billyuk009 | Redbox | 2 | 04-28-2004 07:23 |
