12-13-2007, 21:51 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 44
Member: 179813 Status: Offline Thanks Meter: 13 | N73 imei 12345..... when i made the downgrade the hwk saves automatic the PM file Rm-133_correct imei_13-12-2007184450_Back_308.pm after flashing the phone doesnt turn up . Then i use the BB5Erase_universal_rap file and write the file. Then i flash the phone again and the phone turn on ok, but imei is on 1234567..... i write the pm that was saved and still the same why ???????? the imei still 1234345.... br bronks |
12-14-2007, 10:56 | #3 (permalink) |
Member: 179813 Status: Offline Thanks Meter: 13 | ok ok.no problem i can send the phone to warranty !!! but how should i do next time i make a downgrade ? what's the procedure to make the imei backup ??? and write down again ??? br Bronks |
12-14-2007, 15:58 | #5 (permalink) |
Member: 179813 Status: Offline Thanks Meter: 13 | ok kabir forget that mobile. because i already flashed many times with mtbox , jaf , and hwk. i just want to know how should i do next time i make a downgrade ? what's the procedure to make the imei backup ??? and write down again ??? br bronks |
12-14-2007, 16:35 | #6 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
Next time mate, either press Read CRT before any jobs, or tick AUT Backup! If you tick AUT Backup, it will backup both pm and imei data for you! | |
12-14-2007, 17:03 | #7 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | @Bronks i have the same problem like your brother a week ago after flash 7370. donwgrade save backup and then write it back but imei remain 123........that was my first time to have that situation after flash. i even try later to touch other PM but noting .after post here Odia said it is because i write pm after He sent me a CNT file to use. Quote:
12-14-2007, 17:55 | #8 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | If you erase BB5 phones, you can also erase the certificate, in this case, even a backup of PM308 cannot help, you need to write back the phones certificate first, if you do not have a certificate backup, then your only option is ASK>RPL. Odia. |
12-14-2007, 22:53 | #10 (permalink) |
Member: 179813 Status: Offline Thanks Meter: 13 | ok so. next time if i select the autobackup , and also read the cert. if i have any problem i can write them down aftar i use the bb5erase file ??? best regards bronks |
N73 with imei 12345......? has signal and is not locked | ZetMen | Nokia Base Band 5 ( BB-5 ) | 8 | 08-11-2008 05:17 |
UB Team N73 log writting but imei 12345.... all lock open | tedcen34 | Universalbox | 8 | 07-30-2008 08:46 |
n73 imei 12345**** | t2520 | MT-BOX | 4 | 10-02-2007 13:18 |
n80,n73 imei 12345 .. lets disucss this problem commonly | makona | MT-BOX | 28 | 04-07-2007 06:19 |
