03-04-2008, 01:38 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 238559 Status: Offline Thanks Meter: 2 | urgent help required..bb5 dead |
03-04-2008, 07:43 | #3 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Yugoslavia Age: 47
Member: 10594 Status: Offline Thanks Meter: 83 | That's because of HWK killer software. I had that problem when I bought HWK. Format PC, reinstall windows and install hwk suite without any third party software and flash your phone again, it will be OK |
03-04-2008, 10:35 | #4 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 188556 Status: Offline Sonork: 100.114225 Thanks Meter: 36 | first setup HWK_Support_Suite_Setup_v02.06.000.exe will remove kill. after connect ufs+hwk.open hwk update client.press "next",when you can see the ufs sn and hwk id in update client software .you setup HWK_Suite_Setup_v02.06.000.exe |
03-04-2008, 14:47 | #5 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | I also have some problem. Everything was working fine even BB5 Flashing. But sometimes BB5 flashing goes fine, but sometime HWK kills BB5 phones. I have not used any third party software. One more question, are you sure that if there is some problem, Support Suite will repair that? Need urgent help. I can not install windows so often. |
03-05-2008, 16:12 | #7 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Thanks for your reply Mr. Odia. But I want to know that when I am using HWK and I update it every time whenever update is available then why I am facing this kind of problem How many time do I need to reinstall my windows Sorry to say but it is em*****ing |
03-05-2008, 19:47 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Location: Emmc & Ufs Chips Age: 42
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | Quote:
bro if u format and using original hwk software then it not possible that it killed bb5 phone may be you are using old ver flash file or other thing so kindly check their or post with logs thanks sachin | |
03-05-2008, 23:26 | #10 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Mr. Sachin! Same flash file worked on same set on another system. I am a computer professional and I am in this field for 7 years. After all I came to this point that after working sometime it automatically start killing BB5 phones. I think there is some programming mistake in their security routine. They have a lots of HWK check in software. Somewhere thier calculation for checking HWK or check for crack/patch is faulty and it assumes that you have patched HWK or something even if you are using Original HWK. Mr. Odia! I am not saying that I am a GENIUS but please try to understand our problem. I am saying this becuase I am also a software programmer. Thanks. |
03-05-2008, 23:59 | #11 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | it could be you are using crap calbes mate, hwk/ufs can occasionally get funny with shoddy cables! Check all cables, and look for correct resistors on cables! Also, dont forget, if you are using 7pin calbe, make sure you tick 'dual line' before flashing!" |
03-06-2008, 00:48 | #12 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: -worldwide-
Member: 592460 Status: Offline Thanks Meter: 110 | Quote:
03-06-2008, 16:08 | #13 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Here is what I did. I tried to flash 3110c and 5200. They both were flashing fine a few days ago. Two days ago, when I flashed 3110c, it went dead. I tried with every file I have but no result. As I have said that I am in computer profession, both software and hardware, I had a PC in hand. That was newly installed. I tried on that PC with same cable and flash file. And it worked. Any Idea! | |
03-06-2008, 18:06 | #14 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | HWK Module Account Please activate account for my HWK Module. A1.04-PRO1-9DA86FD24160002E Please!!!!!!!!!!!!!!!!!!!! |
v975 dead urgent help required | gsmindia | Smart-Clip | 2 | 08-23-2006 09:40 |
Z800 Dead... Urgent help required | supraman | Cruiser Suite | 0 | 12-09-2005 10:10 |
what do i need to sim clone??? urgent help required | Sc00ter | Sim Cloning and Scaning | 0 | 07-09-2003 19:16 |
urgent help required please!! t100 | suzyglam | VLSI, Conexant, Skyworks and Old Models | 1 | 04-19-2003 13:57 |
