04-05-2006, 16:16 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 239119 Status: Offline Thanks Meter: 9 | w550 Backlight n Keypad problem after flash with kzf problem=no backlight n keypad just can press 1.3.5.7.9.0 After connect with KZF before press GO i press CHRG ON n MON ON i get this message --------------------------------------- MANY OF ERROR OR INVALID MESSAGE --------------------------------------- Code: UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 UFS_USB V2.6 (c) SarasSoft 2005. S/n: ****** HID: ********************** HWK: A1.02-TEST Licence: True FSFLASH: CPU is ARM 926, revision 3, architecture 6 FSFLASH: Inst Cache size is 16.00 Kb, 4-way, 32 bytes/line. FSFLASH: Data Cache size is 8.00 Kb, 4-way, 32 bytes/line. FSFLASH: NOR Flash device @ [0x44000000-0x45FFFFFF] 32768 Kb FSFLASH: Vendor (0x89): Intel FSFLASH: Device: ?????? (0x880D) FSFLASH: Unique Device Number: 0x92000283433C2169 FSFLASH: Page size: - FSFLASH: Write Buffer Size: 64 bytes FSFLASH: Burst Mode: ON FSFLASH: RAM @ 0x4C000000 FSFLASH: Burst Mode: ON FSFLASH: Erase region [0x44000000-0x45FDFFFF] has an erase block size of 128 Kb FSFLASH: Erase region [0x45FE0000-0x45FFFFFF] has an erase block size of 32 Kb FSFLASH: NAND Flash device @ [0x50000000-0x5FFFFFFF] 262144 Kb FSFLASH: Vendor (0x20): ST FSFLASH: Device: NAND02GR3B (0x00AA) FSFLASH: Unique Device Number: - FSFLASH: Page size: 2048 bytes FSFLASH: Write Buffer Size: 0 bytes FSFLASH: Burst Mode: OFF FSFLASH: Copy back: ON FSFLASH: Cache read: OFF FSFLASH: Mounting logical flash device 0 FSFLASH: Flash segment 0:0 located @ [0x45800000,0x45EFFFFF] (7168 Kb) FSFLASH: Flash type: NOR FSFLASH: Block size: 4096 FSFLASH: Logical erase size: 256 Kb FSFLASH: Flash segment 0:1 located @ [0x50000000,0x5FFFFFFF] (262144 Kb) FSFLASH: Flash type: NAND FSFLASH: Block size: 4096 FSFLASH: Logical erase size: 256 Kb FSFLASH: Check FSFLASH: Stage 1 FSFLASH: Non valid super header block found @ 0x50A13000 FSFLASH: Non valid super header block found @ 0x50CA8000 FSFLASH: Stage 2 FSFLASH: Stage 3 FSFLASH: Re-allocated block LUT from 65009 to 74980 logical blocks FSFLASH: Stage 4 FSFLASH: DELETED block 17173 @ 0x50A23000 rolled back FSFLASH: Block 17172 @ 0x50A22000 replaced by 0x50C9A000 FSFLASH: Block 17173 @ 0x50A23000 replaced by 0x50C9F000 FSFLASH: State 5 skipped FSFLASH: Stage 6 FSFLASH: Stage 7 FSFLASH: Stage 8 FSFLASH: Check done FSFLASH: TOTAL number of blocks: 67328 FSFLASH: AVAILABLE blocks: 65009 FSFLASH: MAX logical block nbr: 74979 FSFLASH: COMMITTED blocks: 4304 FSFLASH: FREE blocks: 60705 FSFLASH: DIRTY blocks: 60970 (0 BAD) FSFLASH: CLEAN blocks: 2044 (0 NOR) FSFLASH: HEADER blocks: 10 FS: Mounting FAT file system partition / for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT16 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 125065 (0x1E889) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 72 (0x48) FS: Clusters: 15621 (0x3D05) FS: Cluster start: 104 (0x68) FS: Cluster last: 125071 (0x1E88F) FS: File System Size: 15621 (62484 Kb) FS: Free Logical Blocks: 11945 (47780 Kb) FS: Free Physical Blocks: 60705 (242820 Kb) FS: Used Blocks: 3676 (14704 Kb) FS: Partition / mounted FS: Mounting FAT file system partition /tpa/system/bg_images/cache for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT12 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 3193 (0xC79) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 16 (0x10) FS: Clusters: 394 (0x18A) FS: Cluster start: 48 (0x30) FS: Cluster last: 3199 (0xC7F) FS: File System Size: 394 (1576 Kb) FS: Free Logical Blocks: 258 (1032 Kb) FS: Free Physical Blocks: 60705 (242820 Kb) FS: Used Blocks: 136 (544 Kb) FS: Partition /tpa/system/bg_images/cache mounted FS: Mounting FAT file system partition /ifs for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT12 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 4433 (0x1151) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 16 (0x10) FS: Clusters: 549 (0x225) FS: Cluster start: 48 (0x30) FS: Cluster last: 4439 (0x1157) FS: File System Size: 549 (2196 Kb) FS: Free Logical Blocks: 197 (788 Kb) FS: Free Physical Blocks: 60705 (242820 Kb) FS: Used Blocks: 352 (1408 Kb) FS: Partition /ifs mounted FS: Mounting FAT file system partition /system for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT12 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 2793 (0xAE9) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 16 (0x10) FS: Clusters: 344 (0x158) FS: Cluster start: 48 (0x30) FS: Cluster last: 2799 (0xAEF) FS: File System Size: 344 (1376 Kb) FS: Free Logical Blocks: 312 (1248 Kb) FS: Free Physical Blocks: 60705 (242820 Kb) FS: Used Blocks: 32 (128 Kb) FS: Partition /system mounted FS: Mounting FAT file system partition /smsdata for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT12 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 1833 (0x729) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 16 (0x10) FS: Clusters: 224 (0xE0) FS: Cluster start: 48 (0x30) FS: Cluster last: 1839 (0x72F) FS: File System Size: 224 (896 Kb) FS: Free Logical Blocks: 207 (828 Kb) FS: Free Physical Blocks: 60705 (242820 Kb) FS: Used Blocks: 17 (68 Kb) FS: Partition /smsdata mounted FS: Mounting FAT file system partition /usb for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT16 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 462377 (0x70E29) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 240 (0xF0) FS: Clusters: 57764 (0xE1A4) FS: Cluster start: 272 (0x110) FS: Cluster last: 462383 (0x70E2F) FS: Phone not properly shut down, running FSCK on partition /usb FS: FSCK level is 1 FSCK: Directory Check FS: Partition /usb set to dirty FS: Partition /usb set to clean FSCK: Done FS: Partition /usb set to dirty FS: Partition /usb set to clean FS: Partition /usb set to dirty FS: Partition /usb re-sized from 57764 to 57774 clusters FS: File System Size: 57774 (231096 Kb) FS: Free Logical Blocks: 57757 (231028 Kb) FS: Free Physical Blocks: 60705 (242820 Kb) FS: Used Blocks: 17 (68 Kb) FS: Partition /usb mounted FS: Partition / set to dirty BuildInfo: Label: <BAS_G210_R3B_EC6_050824_1913> Variant: <cxc1329035_G200_PHONE_Ellen> BuildInfo: Generated: 2005-08-24 21:54 by Off.Bld Product : <Sony Ericsson W550> Version: 0000 HW Setup : Marita Compact P2A (Id:0x8040) IRDA: B026 BT: C026 RS232: A026 Vendor : <Sony Ericsson> PNP: SER USB: 0FCE BT: 0000 OS: core startup complete! Prototype start process started! MPH: PID 65601 MPH: GSM Search Intervals 1 10 40 10 35 - 40 0 0 0 0 RLC: RLC_LLC RLC: RLC_IDLE_REQ = 6940 RLC: RLC_GMM_DATA_REQ = 6941 RLC: RLC_DATA_REQ = 6942 RLC: RLC_UNITDATA_REQ = 6943 RLC: RLC_RLC_DATA_REQ = 6945 RLC: RLC_RLC_UNITDATA_REQ = 6946 RLC: RLC_DATA_RSP = 6947 RLC: LLC_RLC RLC: RLC_DATA_CNF = 6950 RLC: RLC_DATA_IND = 6951 RLC: RLC_STATUS_IND = 6952 RLC: RR_RLC RLC: RR_TBF_ESTABLISH_REQ = 6495 RLC: RR_UPLINK_TBF_RELEASE_REQ = 6497 RLC: RR_DOWNLINK_TBF_RELEASE_REQ = 6498 RLC: RR_TBF_RELEASE_RSP = 6499 RLC: RR_DOWNLINK_ACK_NACK_REQ = 6500 RLC: RLC_RR RLC: RR_TBF_ESTABLISH_CNF = 6505 RLC: RR_UPLINK_TBF_RELEASE_CNF = 6507 RLC: RR_DOWNLINK_TBF_RELEASE_CNF = 6508 RLC: RR_TBF_ESTABLISH_IND = 6506 RLC: RR_TBF_RELEASE_IND = 6509 RLC: RR_UPLINK_ACK_NACK_IND = 6510 RLC: PH_RLC RLC: PH_RLC_DATA_REQ = 6805 RLC: PH_RLC_DATA_RELEASE_REQ = 6807 RLC: PH_RLC_CONTROL_REQ = 6808 RLC: PH_RLC_CONTROL_CONTROL_0_PDCH_REQ = 6810 RLC: PH_RLC_CONTROL_CONTROL_1_PDCH_REQ = 6811 RLC: PH_RLC_CONTROL_CONTROL_2_PDCH_REQ = 6812 RLC: PH_RLC_CONTROL_CONTROL_3_PDCH_REQ = 6813 RLC: PH_RLC_CONTROL_CONTROL_4_PDCH_REQ = 6814 RLC: PH_RLC_CONTROL_CONTROL_5_PDCH_REQ = 6815 RLC: PH_RLC_CONTROL_DATA_0_PDCH_REQ = 6816 RLC: PH_RLC_CONTROL_DATA_1_PDCH_REQ = 6817 RLC: PH_RLC_CONTROL_DATA_2_PDCH_REQ = 6818 RLC: PH_RLC_CONTROL_DATA_3_PDCH_REQ = 6819 RLC: PH_RLC_CONTROL_DATA_4_PDCH_REQ = 6820 RLC: PH_RLC_CONTROL_DATA_5_PDCH_REQ = 6821 RLC: PH_RLC_CONTROL_CONTROL_0_PDTCH_PDCH_REQ = 6822 RLC: PH_RLC_CONTROL_CONTROL_1_PDTCH_PDCH_REQ = 6823 RLC: PH_RLC_CONTROL_CONTROL_2_PDTCH_PDCH_REQ = 6824 RLC: PH_RLC_CONTROL_CONTROL_3_PDTCH_PDCH_REQ = 6825 RLC: PH_RLC_CONTROL_CONTROL_4_PDTCH_PDCH_REQ = 6826 RLC: PH_RLC_CONTROL_CONTROL_5_PDTCH_PDCH_REQ = 6827 RLC: PH_RLC_CONTROL_DATA_0_PDTCH_PDCH_REQ = 6828 RLC: PH_RLC_CONTROL_DATA_1_PDTCH_PDCH_REQ = 6829 RLC: PH_RLC_CONTROL_DATA_2_PDTCH_PDCH_REQ = 6830 RLC: PH_RLC_CONTROL_DATA_3_PDTCH_PDCH_REQ = 6831 RLC: PH_RLC_CONTROL_DATA_4_PDTCH_PDCH_REQ = 6832 RLC: PH_RLC_CONTROL_DATA_5_PDTCH_PDCH_REQ = 6833 RLC: PH_RLC_RELEASE_REQ = 6834 RLC: RLC_PH RLC: PH_RLC_DATA_CNF = 6845 RLC: PH_RLC_DATA_IND = 6846 RLC: PH_RLC_DATA_RTS_IND = 6847 RLC: PH_RLC_DATA_RELEASE_CNF = 6848 RLC: PH_RLC_CONNECT_IND = 6849 RLC: PH_RLC_CONTROL_CNF = 6850 RLC: PH_RLC_CONTROL_IND = 6851 RLC: PH_RLC_RELEASE_CNF = 6852 RLC: RLC_TIMER RLC: RLC_TIMER_T3164 = 7020 RLC: RLC_TIMER_T3166 = 7021 RLC: RLC_TIMER_T3180 = 7022 RLC: RLC_TIMER_T3182 = 7023 RLC: RLC_TIMER_T3190 = 7024 RLC: RLC_TIMER_T3192 = 7027 RLC_UL: S I RR: PID 65603 RR: RR_MM_PRIM 6255 RR: MM_RR_PRIM 6265 RR: MPH_RR_PRIM 6275 RR: RR_MPH_PRIM 6345 RR: DL_RR_PRIM 6395 RR: RR_DL_PRIM 6405 RR: RR_MMM_PRIM 6465 RR: MMM_RR_PRIM 6475 RR: RR_RLC_PRIM 6495 RR: RLC_RR_PRIM 6505 RR: PH_MPH_PRIM 6565 RR: MPH_PH_PRIM 6635 RR: MPH_CB_PRIM 6695 RR: CB_MPH_PRIM 6705 RR: MPH_MMM_PRIM 6735 RR: MMM_MPH_PRIM 6745 RR: PH_RLC_PRIM 6805 RR: RLC_PH_PRIM 6845 RR: RLC_LLC_PRIM 6940 RR: LLC_RLC_PRIM 6950 RR: RR_LLC_PRIM 6990 RR: LLC_RR_PRIM 7000 RR: PH_RR_PRIM 7200 RR: RR_PH_PRIM 7205 RR: RR_TIMER_PRIM 7170 RR: MPH_TIMER_PRIM 7140 MPH_Low: PID 65606 LLC: PID 65607 LLC: <SMS 3378 LLC: >SMS 3389 LLC: <SNDCP 6895 6903 LLC 1: state 0 LLC 3: state 0 LLC 5: state 0 LLC 7: state 0 LLC 9: state 0 LLC 11: state 0 RLC_DL: S I ### Print Server: Requesting DebugMux channel... 1782 ### Print Server: Started OK 1783 AM: MODULE_INIT 1783 LLRS232: EILD_LLRS232_HandleSignal_R_Do_Start 1784 [SIM] State Changed: SIM_STATE_NULL, Appl: 0, Ref: 0 E 1784 [ICC-LD] ICC_Reader_0_Process Started 1784 [ICC-LD] Status Changed: ICC_READER_DEACTIVATED, Reader: 0 1785 RLink: RLINK_PH 1785 RLink: PH_RLINK_CONNECT_IND = 6227 1785 RLink: PH_RLINK_DISCONNECT_IND = 6228 1785 RLink: PH_RLINK_RTS_IND = 6225 1785 RLink: PH_RLINK_DATA_IND = 6226 1785 RLC: PH_RLINK 1785 RLink: PH_RLINK_DATA_REQ = 6215 1785 RLink: RLINK_RLP 1785 RLink: RLINK_RLP_RTS_IND = 4566 1785 RLink: RLINK_RLP_DATA_IND = 4568 1785 RLC: RLP_RLINK 1785 RLink: RLINK_RLP_DATA_REQ = 4569 1785 RLink: RLINK_RLP_DTX_REQ = 4570 1785 RLC: RLINK_RR 1785 RLC: RR_CHANNEL_MODE_INFO_IND = 23552 1785 RLC: RR_CHANNEL_MODE_MODIFY_IND = 23553 1785 RLink: State IdleILD_HCITL.c: 603 EILD_HCITL_SetTXPin: PinLevel = 0 1785 OS Time and RTC syncronized. The time diff was 1144278013 sRH: Activate on LRRAT = 0 1786 RH state: InactiveRational Rose RealTime C Target Run Time SystemRelease 6.50.C.00 1786 Copyright (c) 1993-2003 Rational Software 1786 SM: Initiated; ProcessID = 65659 ! 1786 NS versions: 1786 cnh1010128_rrtose => CNH1010128_R5S 1787 cnh1010235-2_ns_cas => BAS_G210_CUST_CNH1010235_2_050810_1512 1787 cnh1010237_ns_was_if => CNH1010237_R9L 1787 cnh1010238_ns_was => CNH1010238_R9AB 1787 cnh1010278_rose_rt_codegen => CNH1010278_R4F 1787 cnh1601471_ns_gas_l23 => CNH1601471_R1T002 1787 cnh160294-3_ns => CNH160294_3_R2S001 1787 cnh160573_network_asi => CNH160573_R6K 1787 cnh160884_ns_rrt_top_model => CNH160884_R7G 1787 MM: reset TMSI 1787 MM: No valid GSM keys 1787 MM: No valid WCDMA keys 1787 MM: state 0GMM: ResetSIM_Data 1787 GMM: No valid GSM-GPRS keys 1787 GMM: No valid WCDMA keys 1787 LLC 1: Unexpected signal #6972SEMC_ACB: Process started, pid 0x100d4. 1788 SEMC_ACB: Version = ACBM V3.10, debuglevel = 0x1131* CC1 state 0 1788 * CC2 state 0 1788 * CC3 state 0 1788 * CC4 state 0 1788 * CC5 state 0 1788 * CC6 state 0 1788 * CC7 state 0 1788 DRM: DRM_Process started 1784 tcp_flow_t : Entries= 50, Entry size= 212 1788 tcp_flow_lite_t : Entries= 50, Entry size= 32 1788 tpl_pcb_t : Entries= 50, Entry size= 128 1789 *** PID started 65587. *** 1789 *** Test code: .... disabled. *** 1789 *** Runtime checks: disabled. *** 1789 *** Fatal errors: . enabled. *** 1789 *** Debug traces: . disabled. *** 1789 max timers 1 1792 ACM: Starting Application Side. 1792 SS: State Idle @CallMeter startedSMC_MO_1 (65634) state 4 1792 SMC_MO_2 (65635) state 4 1792 SMC_MT (65636) state 4 1792 SMR_MO state 3 1792 SMR_MT state 3 1792 GDFS_SRV State 1-Closed 1796 Prototype Start Process [File System Version Control]: Type OK (Ellen) 1799 Prototype Start Process [File System Version Control]: Version OK (R3A_1) 1816 FS: Partition /ifs set to dirtyRLP: process started 1839 L2RCOP: process started 1839 RLP: state changed to 'S0_ADMandDetached' 1839 L2RCOP: state changed to 'Initial' 1855 GDFS: Format version 1 1857 GDFS Log[0] <- Phys[0] 67758 bytes left. Erased 1 times 1859 GDFS Log[1] <- Phys[1] 104594 bytes left. Erased 1 times 1861 GDFS Log[3] <- Phys[3] 53179 bytes left. Erased 1 times 1863 GDFS Log[4] <- Phys[4] 66644 bytes left. Erased 1 times 1865 GDFS Log[5] <- Phys[5] 75315 bytes left. Erased 1 times 1866 GDFS Log[6] <- Phys[6] 104465 bytes left. Erased 1 times 1868 GDFS Log[2] <- Phys[7] 103875 bytes left. Erased 1 times[sysctrl] start-up cause : Charger Connected (Restart) 1871 [sysctrl] Enabling UICC refresh task. 1871 GDFS_SRV State 2-Opening 1871 CC: speech ver config 2 0 1 15 15 1871 BT Dispatch signal base: 16025 (0x3e99) 1871 BT Request signal base: 15715 (0x3d63) 1871 BT Response signal base: 15870 (0x3dfe) 1871 BT Module Internal base: 583 (0x247) 1872 BT_UART_ON_TIMER: 590 (0x24e) 1872 EVENT_BT_EBT_STACK: 615 (0x267) 1872 BT Signal Interval end: 887 (0x377) 1872 BT/EBT_sil.c: 374 SIL_OpenConnection: COM1:baud=115200 parity=N data=8 stop=1 1872 EILD_HCITL.c: 603 EILD_HCITL_SetTXPin: PinLevel = 1 1872 EILD_HCITL.c: 752 SetBaudRate: = 115200, Stopbits = 1 1873 ###Downloading DSP for first time after startup of phone!### 1873 DSPIF_INT Exception: MPORTIF Soft reset 1873 DSPIF_INT Exception: MPORTIF Soft reset 1873 CC: TTY mode = 0 1873 * CC0 state 0 1873 MPH: PacketChannels activated 1873 RR Multislot class GPRS = 10 1873 RR state 0 1873 MS_TYPE = MS_EGSM900_DCS1800_PCS1900 1873 MPH:SelectedModeIndex=1 1874 MPH_GD_Info.SensitivityLimit_dBm[BAND_GSM900_OR_EGSM900] = -107 1874 ETX OK 1874 MPH_GD_Info.SensitivityLimit_dBm[BAND_DCS1800] = -107 1875 FSUSB: FS-USB Connection was initiated. 1878 DSPIF_INT Exception: MPORTIF Soft reset 1878 DSPIF_INT Exception: MPORTIF Soft reset 1878 VCXO_Control_BlockClockUserIndex = 8 1879 MPH_GD_Info.SensitivityLimit_dBm[BAND_PCS1900] = -107 1879 MPH_GD_Info.SensitivityLimit_dBm[BAND_GSM850] = -107 1879 MPH_GD_Info.MinNrOfIdentifiedCellsToSkipWeakCells = 0 1879 MPH: EGSM900_DCS1800 1880 MPH: Default value 57 used for MPH_GD_AFC_Hz_Per_DAC_Step 1880 MMM IMEI = 357442-00-756630-0, IMEI_SVN=02 1880 MMM EqPLMN List read from GDFS, nbr=1, 502 12 1880 MMM state 0 1881 MPH: Default values used for MPH_GD_AFC_Window_Frequency_Limit 1881 DebugMux[IMEI] Length=8, TypeOfID=2, OddEven=1, Digits: 3 5 7 4 4 2 0 0 7 1881 MPH: Default values used for MPH_GD_AFC_Window_Frequency_Limit 1881 MPH NullState 1881 ENH_Control_Reset: IsPkt 0 IsARFCNsInit 0 1881 ENH_Control_Reset: IsPkt 1 IsARFCNsInit 0 1881 ENH_NCParameters_Reset ALL 1881 ENH_RTD_RP_MP_Reset 1881 ENH_RTD_RP_Reset 1882 ENH_RTD_RP_MP_Reset 1882 ENH_RTD_RP_Reset 1882 ## DSP VersionIdentity: "CRH109693_R4F MIDI_PCM_ASR --- QSTEMOH_CRH109693_R4F Wed May 11 17:55:39 2005" 1884 HW_Radio_Init: VCXO_DAC_Value: 0x294 1884 [SIM_FILE_UTIL] FCP Cache Size 80 1884 MMM MS_OperationMode=0IrDA_ll.c:: IrLAP Nickname: Sony Ericss 1884 IrDA_lap_rec.c: IrLAP process ready ! 1884 IrDA_lmp_rec.c: IrLMP process ready ! 1884 IrDA Request signal base: 21514 (0x540a) 1884 IrDA Response signal base: 21538 (0x5422) 1884 IrDA Event signal base: 21563 (0x543b) 1884 IrDA Module Internal start: 2673 (0x0a71) 1884 IRLAP_CONNECT_IND: 2674 (0x0a72) 1884 LM_CONNECT_REQ: 2706 (0x0a92) 1884 IrDA Module Internal end: 2736 (0x0ab0) 1885 FSUSB: USB Mass Storage process started, pid = 0x100D7. 1885 GMM<-GMM_EXTREGISTRATIONINFO_SET_REQ[lockctrl] SimLock : NOT OK, PhoneLock : NOT OK, Sim Active : NOT ACTIVE 1891 EILD_HCITL.c: 1425 ReportUnexpectedError: HCITL_ErrorCode = 0, UART_ErrorCode = 0x06 1891 [ICC-PD] RD(270) WR(270) VR(1..2) T1(0) D8(1) D16(1) D32(0) D64(0) RM(0) CS(0) 1892 CCS: Idle[lockctrl] SimLock : NOT OK, PhoneLock : NOT OK, Sim Active : NOT ACTIVE 1892 [lockctrl] SimLock : NOT OK, PhoneLock : NOT OK, Sim Active : NOT ACTIVE 1892 [lockctrl] SimLock : OK, PhoneLock : OK, Sim Active : NOT ACTIVE 1893 SL: SearchingMode = 1 1894 SM: Received REQUEST_PS_PERIODICREPORT_ENABLE 1894 SL: RAT_Mode = GSM single mode 1894 ns_util: MS Features:27f11 1894 ns_util: CFG_ENABLE_GSM_GPRS_CALL_SUPPORT 1894 SL: SIGID_INTERVAL_START_MOD_NS_CAS = 3215 1894 SL: ProcessID = 1005c 1894 SL: CFG_DISABLE_SECURITY_HANDLING is NOT! defined 1894 SL: DUAL_RAT_SUPPORT is NOT! defined 1894 SL state 0 1894 SL<-EVENT_SIM_STATE_CHANGED in State 0 from 100b5 1894 SL: Not active 1894 SL new SIM handle=0 1895 SL<-23321 in State 0 from 1002e 1895 SL: Not active 1903 [ICC-PD] Fi: 1 Di: 1 Div1: 0 Div2: 0 1934 [ICC-PD] Fi: 1 Di: 1 Div1: 0 Div2: 0 1952 [SIM] *** ERROR *** No Card Present 1952 [SIM] InitialiseCard SIM_APPLICATION_UNKNOWN 1952 [SIM] WARNING - Destruction of Application Parameters 1952 [SIM_FILE_UTIL] Used Cache Records 0 1952 [SIM_FILE_UTIL] Max Cache Records 80 1952 [SIM] WARNING - Destruction of Card Parameters 1952 [SIM] State Changed: SIM_STATE_POWER_OFF, Appl: 0, Ref: 0[lockctrl] SimLock : OK, PhoneLock : OK, Sim Active : NOT ACTIVE 1952 SL<-EVENT_SIM_STATE_CHANGED in State 0 from 100b5 1952 SL: Not active 1952 SL new SIM handle=0ACM.StartMain: Starting First App. id=1... 1981 ACM.StartMain: Start of First App ok. 1981 AM: MODULE_INIT_READY 1981 1981 1981 ****************************************** 1981 * Sony Ericsson Mobile Communications AB * 1981 * Copyright 2003 * 1981 ****************************************** 1981 * R4AB048 prgCXC1250086_CHINA_EL * 1981 ****************************************** 1981 1981 (OBEX/obex_session.c line: 2254) OBEX Started. 1982 RTP_Ctrl started 1983 SPBC Process started 1983 SPBC <- SIM_STATE_POWER_OFFMMPROT[SIP]: SIP started 1984 MMPROT[RTSP]: RTSP Process Started 1999 BATT: Battery type is TYPE 2 1999 BATT: Measurements are 4056 mV and 0.0 mA 1999 BATT: Compensated VBAT (3931 mV) based remaining capacity is 70.1% 2003 GVI:Ready 2052 TIME LD:ld_time.c Init of RTC failedGDFS_Wrapper: **** Up and running **** 2097 CSATSERVICES_IMP: CSatServices_Constructor 2098 Watchdog: process up and running. 2098 Watchdog: Crash SMS not activated 2100 SL<-REQUEST_CSS_VOICECALLVOLUME_SET in State 0 from 100de 2100 SL: Not active 2103 SL<-23321 in State 0 from 100df 2103 SL: Not active 2104 [CLH] Server started 2108 [CLH] Read 0 customized ECCs 2109 UI: UI_Backlight_Init, did not get a valid backlight level - 0 2111 *** Warning: Not valid window. NULL *** 2112 Disp_CreateFont: Creating font 0 2112 Disp_CreateFont: Creating font 15 2113 Disp_CreateFont: Creating font 16 2113 Disp_CreateFont: Creating font 17 2113 Disp_CreateFont: Creating font 18 2113 Disp_CreateFont: Creating font 21 2113 Disp_CreateFont: Creating font 22 2114 Disp_CreateFont: Creating font 24 2114 Disp_CreateFont: Creating font 25 2114 Disp_CreateFont: Creating font 34 2114 Disp_CreateFont: Creating font 35 2114 Disp_CreateFont: Creating font 37 2114 Disp_CreateFont: Creating font 38 2115 Disp_CreateFont: Creating font 45 2115 Disp_CreateFont: Creating font 46 2115 Disp_CreateFont: Creating font 54 2115 Disp_CreateFont: Creating font 53 2115 ***** Investigating Language Availability ***** 2119 ENG: FS = Unavailable, ROM = Available 2121 IND: FS = Available, ROM = Unavailable 2121 MAL: FS = Available, ROM = Unavailable 2121 TAG: FS = Available, ROM = Unavailable 2121 VTN: FS = Available, ROM = Unavailable 2121 PRC: FS = Available, ROM = Unavailable 2121 *********************************************** 2121 ***** Investigating Input Features ***** 2121 Arabic: NO 2121 China: YES 2121 Hebrew: NO 2121 T9: YES 2121 Greek: NO 2121 Cyrillic: NO 2121 Thai: NO 2121 Icelandic: NO 2121 Ukrainian: NO 2121 Hindi: NO 2121 Bengali: NO 2121 **************************************** 2121 ***** Investigating Input Language Availability *****BT/EBT_sil.c: 393 SIL_OpenConnection: Start event OK! 2122 BT/EBT_sil.c: 419 Free expected "break" 2122 BT/BT.c: 4208 BT_UART_Clock: ON 2122 BT/BT.c: 5949 HCI_CONFIGURE_PORT_CNF: 2122 BT/BT.c: 5938 HCI_START_CNF: 2121 Predictive state is: ON 2122 Predictive default (cust) is: ON 2122 ENG: allowed = YES, T9-FS = YES, T9-ROM = NO 2124 PRC: allowed = YES, T9-FS = NO, T9-ROM = YES 2124 ABC: allowed = YES, T9-FS = NO, T9-ROM = NO 2124 123: allowed = YES, T9-FS = NO, T9-ROM = NO 2125 ***************************************************** 2304 SL<-REQUEST_ROAMING_CURRENTPLMN_STATUS_GET in State 0 from 100eb 2305 SL: Not activeAT/CFS/PrintToTraceLog_AT_CmdList: Forwarding to app layer (e.g. AAS); Commands/identifiers listed in 'at_cmds.dat': 2367 AT/CFS, FwdCmd: '*' 2367 AT/CFS, FwdCmd: 'VOICE_CMDS' 2367 AT/CFS, FwdCmd: 'Z' 2367 AT/CFS, FwdCmd: '&F' 2367 AT/CFS, FwdCmd: '*EAID' 2367 AT/CFS, FwdCmd: '*EALR' 2367 AT/CFS, FwdCmd: '*EALS' 2367 AT/CFS, FwdCmd: '*EAM' 2367 AT/CFS, FwdCmd: '*EAMS' 2367 AT/CFS, FwdCmd: '*EAPN' 2367 AT/CFS, FwdCmd: '*EAPP' 2367 AT/CFS, FwdCmd: '*EAPS' 2367 AT/CFS, FwdCmd: '*EARS' 2368 AT/CFS, FwdCmd: '*EASM' 2368 AT/CFS, FwdCmd: '*EAST' 2368 AT/CFS, FwdCmd: '*EBCA' 2368 AT/CFS, FwdCmd: '*ECAP' 2368 AT/CFS, FwdCmd: '*ECAR' 2368 AT/CFS, FwdCmd: '*ECAS' 2368 AT/CFS, FwdCmd: '*ECAW' 2368 AT/CFS, FwdCmd: '*ECBP' 2368 AT/CFS, FwdCmd: '*ECCQ' 2368 AT/CFS, FwdCmd: '*ECCR' 2368 AT/CFS, FwdCmd: '*ECSP' 2368 AT/CFS, FwdCmd: '*ECUR' 2368 AT/CFS, FwdCmd: '*EDIF' 2368 AT/CFS, FwdCmd: '*EDIS' 2368 AT/CFS, FwdCmd: '*EDST' 2368 AT/CFS, FwdCmd: '*EENL' 2368 AT/CFS, FwdCmd: '*EIPS' 2368 AT/CFS, FwdCmd: '*EJAVA' 2368 AT/CFS, FwdCmd: '*EGIR' 2368 AT/CFS, FwdCmd: '*EKSR' 2368 AT/CFS, FwdCmd: '*ELAN' 2368 AT/CFS, FwdCmd: '*ELIB' 2368 AT/CFS, FwdCmd: '*ELIF' 2368 AT/CFS, FwdCmd: '*ELIN' 2368 AT/CFS, FwdCmd: '*ELOO' 2368 AT/CFS, FwdCmd: '*EKEY' 2368 AT/CFS, FwdCmd: '*EMAR' 2368 AT/CFS, FwdCmd: '*EMEM' 2368 AT/CFS, FwdCmd: '*EMIC' 2368 AT/CFS, FwdCmd: '*EMIR' 2368 AT/CFS, FwdCmd: '*EMWS' 2369 AT/CFS, FwdCmd: '*ENAD' 2369 AT/CFS, FwdCmd: '*EPED' 2369 AT/CFS, FwdCmd: '*EPEW' 2369 AT/CFS, FwdCmd: '*EPHD' 2369 AT/CFS, FwdCmd: '*EPNR' 2369 AT/CFS, FwdCmd: '*EPNW' 2369 AT/CFS, FwdCmd: '*EPRD' 2369 AT/CFS, FwdCmd: '*EPRR' 2369 AT/CFS, FwdCmd: '*EPRW' 2369 AT/CFS, FwdCmd: '*ERIF' 2369 AT/CFS, FwdCmd: '*ERIL' 2369 AT/CFS, FwdCmd: '*ERIN' 2369 AT/CFS, FwdCmd: '*ERIP' 2369 AT/CFS, FwdCmd: '*ESAG' 2369 AT/CFS, FwdCmd: '*ESAM' 2369 AT/CFS, FwdCmd: '*ESBL' 2369 AT/CFS, FwdCmd: '*ESCG' 2369 AT/CFS, FwdCmd: '*ESCN' 2369 AT/CFS, FwdCmd: '*ESDF' 2369 AT/CFS, FwdCmd: '*ESDG' 2369 AT/CFS, FwdCmd: '*ESDI' 2369 AT/CFS, FwdCmd: '*ESGR' 2369 AT/CFS, FwdCmd: '*ESIL' 2369 AT/CFS, FwdCmd: '*ESKL' 2369 AT/CFS, FwdCmd: '*ESLN' 2369 AT/CFS, FwdCmd: '*ESKS' 2369 AT/CFS, FwdCmd: '*ESMA' 2369 AT/CFS, FwdCmd: '*ESMM' 2369 AT/CFS, FwdCmd: '*ESNU' 2370 AT/CFS, FwdCmd: '*ESTF' 2370 AT/CFS, FwdCmd: '*ESVM' 2370 AT/CFS, FwdCmd: '*EVA' 2370 AT/CFS, FwdCmd: '*EVAA' 2370 AT/CFS, FwdCmd: '*EVD' 2370 AT/CFS, FwdCmd: '*EVH' 2370 AT/CFS, FwdCmd: '*EWHP' 2370 AT/CFS, FwdCmd: '*EWPR' 2370 AT/CFS, FwdCmd: '*EWPN' 2370 AT/CFS, FwdCmd: '*EWDT' 2370 AT/CFS, FwdCmd: '*EWCT' 2370 AT/CFS, FwdCmd: '*EWIL' 2370 AT/CFS, FwdCmd: '*EWLI' 2370 AT/CFS, FwdCmd: '*EWPB' 2370 AT/CFS, FwdCmd: '*EWCG' 2370 AT/CFS, FwdCmd: '*EWBA' 2370 AT/CFS, FwdCmd: '*EWBR' 2370 AT/CFS, FwdCmd: '*SAKED' 2370 AT/CFS, FwdCmd: '*SAKEH' 2370 AT/CFS, FwdCmd: '*SEAM' 2370 AT/CFS, FwdCmd: '*SEACC' 2370 AT/CFS, FwdCmd: '*SEACID' 2370 AT/CFS, FwdCmd: '*SEAUDIO' 2370 AT/CFS, FwdCmd: '*SEAUP' 2370 AT/CFS, FwdCmd: '*SECHA' 2370 AT/CFS, FwdCmd: '*SEDE' 2370 AT/CFS, FwdCmd: '*SEDEL' 2370 AT/CFS, FwdCmd: '*SEDMS' 2370 AT/CFS, FwdCmd: '*SEDMG' 2370 AT/CFS, FwdCmd: '*SEFEXP' 2371 AT/CFS, FwdCmd: '*SEFIN' 2371 AT/CFS, FwdCmd: '*SEFORM' 2371 AT/CFS, FwdCmd: '*SEFRY' 2371 AT/CFS, FwdCmd: '*SEGAUGE' 2371 AT/CFS, FwdCmd: '*SEGUP' 2371 AT/CFS, FwdCmd: '*SEIMAGE' 2371 AT/CFS, FwdCmd: '*SELERT' 2371 AT/CFS, FwdCmd: '*SELIST' 2371 AT/CFS, FwdCmd: '*SELOG' 2371 AT/CFS, FwdCmd: '*SEMOD' 2371 AT/CFS, FwdCmd: '*SEMP' 2371 AT/CFS, FwdCmd: '*SEONO' 2371 AT/CFS, FwdCmd: '*SEPING' 2371 AT/CFS, FwdCmd: '*SEREDI' 2371 AT/CFS, FwdCmd: '*SERSK' 2371 AT/CFS, FwdCmd: '*SESAF' 2371 AT/CFS, FwdCmd: '*SESAKE' 2371 AT/CFS, FwdCmd: '*SESLE' 2371 AT/CFS, FwdCmd: '*SESTRI' 2371 AT/CFS, FwdCmd: '*SETICK' 2371 AT/CFS, FwdCmd: '*SEUIS' 2371 AT/CFS, FwdCmd: '*SEYNG' 2371 AT/CFS, FwdCmd: '*ZAPC' 2371 AT/CFS, FwdCmd: '*ZFSC' 2371 AT/CFS, FwdCmd: '*ZFSD' 2371 AT/CFS, FwdCmd: '*ZFSI' 2371 AT/CFS, FwdCmd: '*ZFSL' 2372 BT/BT.c: 1279 HostController_Init: Bluetooth Spec 1.2 2373 AT/CFS, FwdCmd: '*ZFSMD' 2373 AT/CFS, FwdCmd: '*ZFSP' 2373 AT/CFS, FwdCmd: '*ZFSR' 2373 AT/CFS, FwdCmd: '*ZFST' 2373 AT/CFS, FwdCmd: '*ZFSW' 2373 AT/CFS, FwdCmd: '*ZIPI' 2373 AT/CFS, FwdCmd: '*ZISI' 2373 AT/CFS, FwdCmd: '*ZGUI' 2373 AT/CFS, FwdCmd: '*ZMEM' 2373 AT/CFS, FwdCmd: '*ZPPI' 2373 AT/CFS, FwdCmd: '*ZORRO' 2373 AT/CFS, FwdCmd: '+BINP' 2373 AT/CFS, FwdCmd: '+BLDN' 2373 AT/CFS, FwdCmd: '+BVRA' 2373 AT/CFS, FwdCmd: '+BRSF' 2373 AT/CFS, FwdCmd: '+CALA' 2373 AT/CFS, FwdCmd: '+CALD' 2374 AT/CFS, FwdCmd: '+CAPD' 2374 AT/CFS, FwdCmd: '+CSAS' 2374 AT/CFS, FwdCmd: '+CSCA' 2374 AT/CFS, FwdCmd: '+CCLK' 2374 AT/CFS, FwdCmd: '+CGMM' 2374 AT/CFS, FwdCmd: '+CGMR' 2374 AT/CFS, FwdCmd: '+CHLD' 2374 AT/CFS, FwdCmd: '+CHUP' 2374 AT/CFS, FwdCmd: '+CIND' 2374 AT/CFS, FwdCmd: '+CKPD' 2374 AT/CFS, FwdCmd: '+CLAN' 2374 AT/CFS, FwdCmd: '+CLCK' 2374 AT/CFS, FwdCmd: '+CLIP' 2374 AT/CFS, FwdCmd: '+CLVL' 2374 AT/CFS, FwdCmd: '+CMAR' 2374 AT/CFS, FwdCmd: '+CMER' 2374 AT/CFS, FwdCmd: '+CMUT' 2374 AT/CFS, FwdCmd: '+CPBF' 2374 AT/CFS, FwdCmd: '+CPBR' 2374 AT/CFS, FwdCmd: '+CPBS' 2375 AT/CFS, FwdCmd: '+CPBW' 2375 AT/CFS, FwdCmd: '+CPUC' 2375 AT/CFS, FwdCmd: '+CRES' 2375 AT/CFS, FwdCmd: '+CRMP' 2375 AT/CFS, FwdCmd: '+CRSL' 2375 AT/CFS, FwdCmd: '+CSCB' 2375 AT/CFS, FwdCmd: '+CSCC' 2375 AT/CFS, FwdCmd: '+CSDF' 2375 AT/CFS, FwdCmd: '+CSIL' 2375 AT/CFS, FwdCmd: '+CSNS' 2375 AT/CFS, FwdCmd: '+CSTF' 2375 AT/CFS, FwdCmd: '+CSTA' 2375 AT/CFS, FwdCmd: '+CTFR' 2375 AT/CFS, FwdCmd: '+CVIB' 2375 AT/CFS, FwdCmd: '+GMR' 2375 AT/CFS, FwdCmd: '+NREC' 2375 AT/CFS, FwdCmd: '+VGM' 2375 AT/CFS, FwdCmd: '+VGS' 2375 AT/CFS, FwdCmd: '+WS46' 2377 BT/BT.c: 1739 HCI_Version = BT1.2, LM_Version = R4A Generated: 2005-04-11 15:24 Comment: BbyoneSW_2LLP 1.1 2377 BT/BT.c: 1748 CHIP_ID = 0x313e402b, HCI_Revision = 0x0798, BT_LMP_Subversion = 0x041c 2381 BT/BT.c: 1980 Download: PatchFile_2LLP_1_1_PatchId_01.fdw, Size = 444 2383 AT process: Awake and AT your service! 2383 AT/SysInfo SYS_VENDOR_NAME: Sony Ericsson 2383 AT/SysInfo SYS_PRODUCT_NAME: Sony Ericsson W550 2383 AT/SysInfo SYS_PRODUCT_VERSION: 0000 2383 AT/SysInfo SYS_SW_ID: 2005-08-24 21:54 Off.Bld BAS_G210_R3B_EC6_050824_1913 cxc1329035_G200_PHONE_Ellen 2383 AT/SysInfo SYS_SW_PRODUCT_ID: BAS_G210_R3B_EC6_050824_1913 cxc1329035_G200_PHONE_Ellen 2383 AT/SysInfo SYS_SW_VERSION: BAS_G210_R3B_EC6_050824_1913 2384 AT/SysInfo SYS_SW_VERSION_DATE: BAS_G210_R3B_EC6_050824_1913 2384 AT/ AT-3; Received signal 'RESPONSE_RS232_GETCAPABILITIES'(24907), executing CEI_OnRS232_GetCapabilities() 2384 AT/CEI_OnRS232_GetCapabilities: Warning !! The channel already destroyed, execution stopped: ClientTag = d! 2384 AT/ AT-3; Received signal 'REQUEST_AT_GET_STATE_OF_ACTIVE_CHANNELS'(15078), executing CFS_OnRequest_AT_GetStateOfActiveChannels() 2392 [StandbyBook#65] CreatedBT/BT.c: 1980 Download: FS_050324_BGB204_HEAD_SEMC_02_2LLP1.0.ofs, Size = 264 2397 UI: Disp_SetFont - INVALID FONT (65) 2398 [Session#1 "Standby"] Got focus 2402 SoftkeyManager: 2402 Subaction doesn't exist. Creating one. 2402 SoftkeyManager: 2402 Subaction doesn't exist. Creating one.BT/BT.c: 1861 Download: GD_BT_Dynamic_Settings_File, Size = 44 2615 Handle_Shell_Timeout: Time-out from non-existent timer: 4c5e7c3c - Ignored. 2617 Handle_Shell_Timeout: Time-out from non-existent timer: 4c5e7c3c - Ignored. 2629 DRM: Init OK 2629 DRM_PRS: DRM_PRS_Process started 2631 MSG: msgmain.c: State 255 2636 [StandbyBook#65] Goto StandbyBook_StandbyPage 2637 [VolumeControlBook#66] Created 2637 [Feedbackticker#67] Created 2637 [InitBook#68] Created 2637 [InitBook#68] Goto InitBook_StartUp_PageWAP:Start (process id 0x1008F) 2647 WAP: File API Initiated 2647 WAP: fileMkDir(.../msm) 2651 WAP: created task 0 2652 WAP: fileMkDir(.../stk) 2653 WAP: fileMkDir(.../stk/tmp) 2659 WAP: created task 1 2662 WAP: createTask failure for 2 2663 [InitBook#68] Goto InitBook_LockedMode_Page 2664 [StandbyBook#65] Goto StandbyBook_ChargingOnly_Page changed to state 0 2673 PBS Process started 2673 PBS: Dispatch PHB_NO_ACCESS 2674 [MassStorageApplicationBook#69] Created 2733 DISP: Warning!!! Nothing drawn in Canvas === 2756 GDFS_WR State 1-Closed 2756 GDFS_WR Start check 2864 Handle_Shell_Timeout: Time-out from non-existent timer: 4c5e7c3c - Ignored. 2874 MSG: msgmain.c: State 0 changed to state 1 2874 MSG: msgmain.c: EVENT_SIM_STATE_CHANGED accepted 2874 MSG: msgmain.c: SIM_STATE NOT Active 2874 MSG: msgmain.c: EVENT_SIM_STATE_CHANGED accepted 2874 MSG: msgmain.c: SIM_STATE NOT ActiveEILD_HCITL.c: 752 SetBaudRate: = 921600, Stopbits = 1 3032 BT/HCI.c: 757 Philips_Set_UART_Baud_Rate: Status = 0x00 3035 EILD_HCITL.c: 1550 R_Do_SetPowerOffTime: 500 ms 3174 BATT: Measurements are 4013 mV and -129.0 mA 3174 BATT: Compensated VBAT (3888 mV) based remaining capacity is 63.7% 3174 BATT: Average remaining capacity is 63.7% 3375 GDFS Free Blk 2 Ok 3375 GDFS_WR Check done 3375 GDFS_SRV State 3-Open 3375 GDFS_WR State 2-Open 3424 BATT: Measurements are 4013 mV and -123.0 mA 3676 BATT: Measurements are 4013 mV and 182.0 mA 3926 BATT: Measurements are 4067 mV and 220.0 mA 3926 BATT: Charge current (220.0 mA) based remaining capacity is 94.6% 3926 BATT: Average remaining capacity is 71.4% 4174 BATT: Average remaining capacity is 76.0% 4386 FS: Partition / set to clean 4387 FS: Partition /ifs set to clean 4388 FS: Partition /usb set to clean 4424 BATT: Measurements are 4078 mV and 215.0 mA 4424 BATT: Charge current (215.0 mA) based remaining capacity is 94.8% 4425 BATT: Average remaining capacity is 79.1% 4514 BATT: Battery Temperature is 29 4676 BATT: Measurements are 4078 mV and 220.0 mA 4676 BATT: Charge current (220.0 mA) based remaining capacity is 94.6% 4676 BATT: Average remaining capacity is 81.3% 4926 BATT: Average remaining capacity is 83.0% 5174 BATT: Compensated VBAT (3953 mV) based remaining capacity is 73.3% 5174 BATT: Average remaining capacity is 81.9% 5426 BATT: Average remaining capacity is 81.0% 5676 BATT: Average remaining capacity is 80.3% 5924 BATT: Average remaining capacity is 79.7% 6175 BATT: Average remaining capacity is 79.2% 6426 BATT: Average remaining capacity is 78.8% 6676 BATT: Measurements are 4078 mV and 231.0 mA 6676 BATT: Average remaining capacity is 78.4% 6890 SL<-R_REQ_NSAD_DEACTIVATE in State 0 from 10035 6890 MMM state 17 6890 MM: IsMM_Connected=0 6890 MM: REG FAILED, Cause = DETACHED 6890 GMM<-GMM_DEACTIVATE_REQ 6890 GMM: No TVP timer 6890 GMM: New TLLI distributed to RR: 0xffffffff (255, 255, 255, 255) 6890 TLLI_PTMSI_New 6890 case1 UnassBoth 6890 GMM: Reset combined procedures 6890 GMM: REG FAILED, Cause = DETACHED 6890 MMM HandleNOM: NOM_GSM->NOM_UNKNOWN, MS_Mode=1, ForcedFlag=0 6890 GMM<-RH_GMM_RESUME_IND 6899 ENH_NCParameters_Reset GPRS 6899 ENH_RTD_RP_MP_Reset 6899 ENH_RTD_RP_Reset 6899 ENH_NCParameters_Reset GPRS 6899 ENH_RTD_RP_MP_Reset 6899 ENH_RTD_RP_Reset 6899 ENH_Control_Reset: IsPkt 1 IsARFCNsInit 1 6899 PH_Control: StateIdle, Disable - one signal down -442503144 6899 PH_Control: StateIdle, Disable - one signal down -442503144 6899 MMM state 0 6899 SL<-MM_REGISTRATION_FAIL_IND in State 0 from 10050 6899 SL: Not active 6899 SL: CS_RegFail_Ind sent 6899 SL<-GMM_REGISTRATION_FAIL_IND in State 0 from 10052 6899 SL: Not active 6900 SL: PS_RegFail_Ind sent 6900 SL<-MMM_SERVINGCELLINFO_IND in State 0 from 10051 6900 SL: Not active 6900 SL: No Coverage 6900 SL<-REQUEST_ROAMING_CURRENTPLMN_STATUS_GET in State 0 from 100dc 6900 SL: Not active 6900 SL<-REQUEST_ROAMING_CURRENTPLMN_STATUS_GET in State 0 from 100dc 6900 SL: Not active 6901 SL<-REQUEST_ROAMING_SEARCHMODE_GET in State 0 from 100ab 6901 SL: Not activeAT/ AT-3; Received signal 'EVENT_PS_REGISTRATIONFAIL_IND'(23880), executing PS_OnEvent_PS_RegistrationFailInd() 6901 AT/ AT-3; Received signal 'EVENT_COVERAGESTATUS_IND'(23882), executing PS_OnEvent_CoverageStatus_Ind() 6924 BATT: Measurements are 4078 mV and 264.0 mA 6924 BATT: Average remaining capacity is 78.1% 7013 BATT: Battery Temperature is 29 7176 BATT: Measurements are 4089 mV and 264.0 mA 7176 BATT: Compensated VBAT (3964 mV) based remaining capacity is 75.0% 7176 BATT: Average remaining capacity is 77.9% 7426 BATT: Average remaining capacity is 77.8% 7674 BATT: Measurements are 4089 mV and 270.0 mA 7674 BATT: Average remaining capacity is 77.6% 7926 BATT: Measurements are 4089 mV and 276.0 mA 7926 BATT: Average remaining capacity is 77.5% 8176 BATT: Measurements are 4089 mV and 292.0 mA 8176 BATT: Average remaining capacity is 78.1% 8424 BATT: Measurements are 4089 mV and 287.0 mA 8424 BATT: Average remaining capacity is 78.6% 8676 BATT: Measurements are 4089 mV and 292.0 mA 8676 BATT: Average remaining capacity is 79.2% 8926 BATT: Measurements are 4089 mV and 287.0 mA 8926 BATT: Average remaining capacity is 78.2% 9174 BATT: Average remaining capacity is 77.2% 9426 BATT: Measurements are 4089 mV and 292.0 mA 9426 BATT: Average remaining capacity is 76.2% 9483 CBS: cbs_main.c: CBS_ALIVE_TIMER_IND accepted 9513 BATT: Battery Temperature is 29 9649 Load Module Starter: Hunt for Program Manager failed 9681 BATT: Measurements are 4089 mV and 287.0 mA 9683 BATT: Average remaining capacity is 75.3% 9924 BATT: Measurements are 4100 mV and 292.0 mA 9924 BATT: Compensated VBAT (3975 mV) based remaining capacity is 76.6% 9924 BATT: Average remaining capacity is 74.4% 10176 BATT: Measurements are 4089 mV and 287.0 mA 10176 BATT: Compensated VBAT (3964 mV) based remaining capacity is 75.0% 10426 BATT: Measurements are 4089 mV and 292.0 mA 10426 BATT: Average remaining capacity is 74.5% 10676 BATT: Average remaining capacity is 74.6% 10926 BATT: Measurements are 4100 mV and 287.0 mA 10926 BATT: Compensated VBAT (3975 mV) based remaining capacity is 76.6% 10926 BATT: Average remaining capacity is 74.8% 11180 BATT: Measurements are 4089 mV and 292.0 mA 11180 BATT: Compensated VBAT (3964 mV) based remaining capacity is 75.0% 11182 BATT: Average remaining capacity is 74.9% 11429 BATT: Measurements are 4100 mV and 292.0 mA 11429 BATT: Compensated VBAT (3975 mV) based remaining capacity is 76.6% 11429 BATT: Average remaining capacity is 75.0% 11676 BATT: Measurements are 4100 mV and 287.0 mA 11681 BATT: Average remaining capacity is 75.2% 11924 BATT: Measurements are 4100 mV and 292.0 mA 11925 BATT: Average remaining capacity is 75.4% 12014 BATT: Battery Temperature is 29 12426 BATT: Measurements are 4100 mV and 287.0 mA 12431 BATT: Average remaining capacity is 75.5% 12674 BATT: Measurements are 4100 mV and 292.0 mA 12675 BATT: Average remaining capacity is 75.6% 12924 BATT: Measurements are 4100 mV and 287.0 mA 12925 BATT: Average remaining capacity is 75.7% 13174 BATT: Measurements are 4100 mV and 292.0 mA 13174 BATT: Average remaining capacity is 75.8% 13424 BATT: Measurements are 4100 mV and 287.0 mA 13676 BATT: Measurements are 4100 mV and 292.0 mA 13681 BATT: Average remaining capacity is 75.9% 13926 BATT: Measurements are 4100 mV and 287.0 mA -------------------------------- Code: 1892 CCS: Idle[lockctrl] SimLock : NOT OK, PhoneLock : NOT OK, Sim Active : NOT ACTIVE 1892 [lockctrl] SimLock : NOT OK, PhoneLock : NOT OK, Sim Active : NOT ACTIVE 1892 [lockctrl] SimLock : OK, PhoneLock : OK, Sim Active : NOT ACTIVE 1893 SL: SearchingMode = 1 1894 SM: Received REQUEST_PS_PERIODICREPORT_ENABLE 1894 SL: RAT_Mode = GSM single mode 1894 ns_util: MS Features:27f11 1894 ns_util: CFG_ENABLE_GSM_GPRS_CALL_SUPPORT 1894 SL: SIGID_INTERVAL_START_MOD_NS_CAS = 3215 1894 SL: ProcessID = 1005c 1894 SL: CFG_DISABLE_SECURITY_HANDLING is NOT! defined 1894 SL: DUAL_RAT_SUPPORT is NOT! defined 1894 SL state 0 1894 SL<-EVENT_SIM_STATE_CHANGED in State 0 from 100b5 1894 SL: Not active 1894 SL new SIM handle=0 1895 SL<-23321 in State 0 from 1002e 1895 SL: Not active 1903 [ICC-PD] Fi: 1 Di: 1 Div1: 0 Div2: 0 1934 [ICC-PD] Fi: 1 Di: 1 Div1: 0 Div2: 0 1952 [SIM] *** ERROR *** No Card Present 1952 [SIM] InitialiseCard SIM_APPLICATION_UNKNOWN 1952 [SIM] WARNING - Destruction of Application Parameters 1952 [SIM_FILE_UTIL] Used Cache Records 0 1952 [SIM_FILE_UTIL] Max Cache Records 80 1952 [SIM] WARNING - Destruction of Card Parameters 1952 [SIM] State Changed: SIM_STATE_POWER_OFF, Appl: 0, Ref: 0[lockctrl] SimLock : OK, PhoneLock : OK, Sim Active : NOT ACTIVE 1952 SL<-EVENT_SIM_STATE_CHANGED in State 0 from 100b5 1952 SL: Not active 1952 SL new SIM handle=0ACM.StartMain: Starting First App. id=1... 1981 ACM.StartMain: Start of First App ok. 1981 AM: MODULE_INIT_READY 1981 1981 1981 ****************************************** 1981 * Sony Ericsson Mobile Communications AB * 1981 * Copyright 2003 * 1981 ****************************************** 1981 * R4AB048 prgCXC1250086_CHINA_EL * 1981 ****************************************** 1981 1981 (OBEX/obex_session.c line: 2254) OBEX Started. 1982 RTP_Ctrl started 1983 SPBC Process started 1983 SPBC <- SIM_STATE_POWER_OFFMMPROT[SIP]: SIP started 1984 MMPROT[RTSP]: RTSP Process Started 1999 BATT: Battery type is TYPE 2 1999 BATT: Measurements are 4056 mV and 0.0 mA 1999 BATT: Compensated VBAT (3931 mV) based remaining capacity is 70.1% 2003 GVI:Ready 2052 TIME LD:ld_time.c Init of RTC failedGDFS_Wrapper: **** Up and running **** 2097 CSATSERVICES_IMP: CSatServices_Constructor 2098 Watchdog: process up and running. 2098 Watchdog: Crash SMS not activated 2100 SL<-REQUEST_CSS_VOICECALLVOLUME_SET in State 0 from 100de 2100 SL: Not active 2103 SL<-23321 in State 0 from 100df 2103 SL: Not active 2104 [CLH] Server started 2108 [CLH] Read 0 customized ECCs 2109 UI: UI_Backlight_Init, did not get a valid backlight level - 0 2111 *** Warning: Not valid window. NULL *** 2112 Disp_CreateFont: Creating font 0 2112 Disp_CreateFont: Creating font 15 2113 Disp_CreateFont: Creating font 16 2113 Disp_CreateFont: Creating font 17 2113 Disp_CreateFont: Creating font 18 2113 Disp_CreateFont: Creating font 21 2113 Disp_CreateFont: Creating font 22 2114 Disp_CreateFont: Creating font 24 2114 Disp_CreateFont: Creating font 25 2114 Disp_CreateFont: Creating font 34 2114 Disp_CreateFont: Creating font 35 2114 Disp_CreateFont: Creating font 37 2114 Disp_CreateFont: Creating font 38 2115 Disp_CreateFont: Creating font 45 2115 Disp_CreateFont: Creating font 46 2115 Disp_CreateFont: Creating font 54 2115 Disp_CreateFont: Creating font 53 2115 ***** Investigating Language Availability ***** 2119 ENG: FS = Unavailable, ROM = Available 2121 IND: FS = Available, ROM = Unavailable 2121 MAL: FS = Available, ROM = Unavailable 2121 TAG: FS = Available, ROM = Unavailable 2121 VTN: FS = Available, ROM = Unavailable 2121 PRC: FS = Available, ROM = Unavailable 2121 *********************************************** 2121 ***** Investigating Input Features ***** 2121 Arabic: NO 2121 China: YES 2121 Hebrew: NO 2121 T9: YES 2121 Greek: NO 2121 Cyrillic: NO 2121 Thai: NO 2121 Icelandic: NO 2121 Ukrainian: NO 2121 Hindi: NO 2121 Bengali: NO 2121 **************************************** 2121 ***** Investigating Input Language Availability *****BT/EBT_sil.c: 393 SIL_OpenConnection: Start event OK! 2122 BT/EBT_sil.c: 419 Free expected "break" 2122 BT/BT.c: 4208 BT_UART_Clock: ON 2122 BT/BT.c: 5949 HCI_CONFIGURE_PORT_CNF: 2122 BT/BT.c: 5938 HCI_START_CNF: 2121 Predictive state is: ON 2122 Predictive default (cust) is: ON 2122 ENG: allowed = YES, T9-FS = YES, T9-ROM = NO 2124 PRC: allowed = YES, T9-FS = NO, T9-ROM = YES 2124 ABC: allowed = YES, T9-FS = NO, T9-ROM = NO 2124 123: allowed = YES, T9-FS = NO, T9-ROM = NO 2125 ***************************************************** --------------------------------------- or flash file wrong b coz my phone is have 2 use test phone...(test phone use for new w550i only) so i think i need new firmware....like ******41 firmware file? or other? help odia ,,,how 2 get my phone have backlight and keypad can back 2 normal. |
04-06-2006, 03:47 | #2 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | AFTER FLASH WITH CHINA FLASH FILE WHY CAN BE LIKE THIS? Code: FSFLASH: Non valid super header block found @ 0x50FC2000 FSFLASH: Non valid super header block found @ 0x51038000 FSFLASH: Non valid super header block found @ 0x5105E000 FSFLASH: Non valid super header block found @ 0x510A2000 FSFLASH: Stage 2 FSFLASH: Stage 3 FSFLASH: Re-allocated block LUT from 65009 to 74980 logical blocks FSFLASH: Stage 4 FSFLASH: State 5 skipped FSFLASH: Stage 6 FSFLASH: Stage 7 FSFLASH: Stage 8 FSFLASH: Check done FSFLASH: TOTAL number of blocks: 67328 FSFLASH: AVAILABLE blocks: 65009 FSFLASH: MAX logical block nbr: 74979 FSFLASH: COMMITTED blocks: 5621 FSFLASH: FREE blocks: 59388 FSFLASH: DIRTY blocks: 60707 (0 BAD) FSFLASH: CLEAN blocks: 986 (0 NOR) FSFLASH: HEADER blocks: 14 FS: Mounting FAT file system partition / for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT16 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 125065 (0x1E889) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 72 (0x48) FS: Clusters: 15621 (0x3D05) FS: Cluster start: 104 (0x68) FS: Cluster last: 125071 (0x1E88F) FS: File System Size: 15621 (62484 Kb) FS: Free Logical Blocks: 10621 (42484 Kb) FS: Free Physical Blocks: 59388 (237552 Kb) FS: Used Blocks: 5000 (20000 Kb) FS: Partition / mounted FS: Mounting FAT file system partition /tpa/system/bg_images/cache for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT12 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 3193 (0xC79) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 16 (0x10) FS: Clusters: 394 (0x18A) FS: Cluster start: 48 (0x30) FS: Cluster last: 3199 (0xC7F) FS: File System Size: 394 (1576 Kb) FS: Free Logical Blocks: 258 (1032 Kb) FS: Free Physical Blocks: 59388 (237552 Kb) FS: Used Blocks: 136 (544 Kb) FS: Partition /tpa/system/bg_images/cache mounted FS: Mounting FAT file system partition /ifs for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT12 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 4433 (0x1151) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 16 (0x10) FS: Clusters: 549 (0x225) FS: Cluster start: 48 (0x30) FS: Cluster last: 4439 (0x1157) FS: File System Size: 549 (2196 Kb) FS: Free Logical Blocks: 200 (800 Kb) FS: Free Physical Blocks: 59388 (237552 Kb) FS: Used Blocks: 349 (1396 Kb) FS: Partition /ifs mounted FS: Mounting FAT file system partition /system for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT12 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 2793 (0xAE9) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 16 (0x10) FS: Clusters: 344 (0x158) FS: Cluster start: 48 (0x30) FS: Cluster last: 2799 (0xAEF) FS: File System Size: 344 (1376 Kb) FS: Free Logical Blocks: 312 (1248 Kb) FS: Free Physical Blocks: 59388 (237552 Kb) FS: Used Blocks: 32 (128 Kb) FS: Partition /system mounted FS: Mounting FAT file system partition /smsdata for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT12 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 1833 (0x729) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 16 (0x10) FS: Clusters: 224 (0xE0) FS: Cluster start: 48 (0x30) FS: Cluster last: 1839 (0x72F) FS: File System Size: 224 (896 Kb) FS: Free Logical Blocks: 214 (856 Kb) FS: Free Physical Blocks: 59388 (237552 Kb) FS: Used Blocks: 10 (40 Kb) FS: Partition /smsdata mounted FS: Mounting FAT file system partition /usb for read/write FS: SecPerClus = 8 FS: BytesPerSec = 512 FS: RootEntCnt = 512 FS: NumFATs = 1 FS: RsvdSecCnt = 1 FS: blockSize = 4096 FS: Type: FAT16 FS: FAT mirroring: OFF FS: Sector locations FS: Size: 462377 (0x70E29) FS: PBR: 7 (0x7) FS: FAT start: 8 (0x8) FS: Active FAT start: 8 (0x8) FS: Root start: 240 (0xF0) FS: Clusters: 57764 (0xE1A4) FS: Cluster start: 272 (0x110) FS: Cluster last: 462383 (0x70E2F) FS: Phone not properly shut down, running FSCK on partition /usb FS: FSCK level is 1 FSCK: Directory Check FS: Partition /usb set to dirty FS: Partition /usb set to clean FSCK: Done FS: Partition /usb set to dirty FS: Partition /usb set to clean FS: Partition /usb set to dirty FS: Partition /usb re-sized from 57764 to 57774 clusters FS: File System Size: 57774 (231096 Kb) FS: Free Logical Blocks: 57749 (230996 Kb) FS: Free Physical Blocks: 59388 (237552 Kb) FS: Used Blocks: 25 (100 Kb) FS: Partition /usb mounted FS: Partition / set to dirty BuildInfo: Label: <BAS_G210_R3B_EC6_050824_1913> Variant: <cxc1329035_G200_PHONE_Ellen> BuildInfo: Generated: 2005-08-24 21:54 by Off.Bld Product : <Sony Ericsson W550> Version: 0000 HW Setup : Marita Compact P2A (Id:0x8040) IRDA: B026 BT: C026 RS232: A026 Vendor : <Sony Ericsson> PNP: SER USB: 0FCE BT: 0000 OS: core startup complete! Prototype start process started! MPH: PID 65601 MPH: GSM Search Intervals 1 10 40 10 35 - 40 0 0 0 0 RLC: RLC_LLC RLC: RLC_IDLE_REQ = 6940 RLC: RLC_GMM_DATA_REQ = 6941 RLC: RLC_DATA_REQ = 6942 RLC: RLC_UNITDATA_REQ = 6943 RLC: RLC_RLC_DATA_REQ = 6945 RLC: RLC_RLC_UNITDATA_REQ = 6946 RLC: RLC_DATA_RSP = 6947 RLC: LLC_RLC RLC: RLC_DATA_CNF = 6950 RLC: RLC_DATA_IND = 6951 RLC: RLC_STATUS_IND = 6952 RLC: RR_RLC RLC: RR_TBF_ESTABLISH_REQ = 6495 RLC: RR_UPLINK_TBF_RELEASE_REQ = 6497 RLC: RR_DOWNLINK_TBF_RELEASE_REQ = 6498 RLC: RR_TBF_RELEASE_RSP = 6499 RLC: RR_DOWNLINK_ACK_NACK_REQ = 6500 RLC: RLC_RR RLC: RR_TBF_ESTABLISH_CNF = 6505 RLC: RR_UPLINK_TBF_RELEASE_CNF = 6507 RLC: RR_DOWNLINK_TBF_RELEASE_CNF = 6508 RLC: RR_TBF_ESTABLISH_IND = 6506 RLC: RR_TBF_RELEASE_IND = 6509 RLC: RR_UPLINK_ACK_NACK_IND = 6510 RLC: PH_RLC RLC: PH_RLC_DATA_REQ = 6805 RLC: PH_RLC_DATA_RELEASE_REQ = 6807 RLC: PH_RLC_CONTROL_REQ = 6808 RLC: PH_RLC_CONTROL_CONTROL_0_PDCH_REQ = 6810 RLC: PH_RLC_CONTROL_CONTROL_1_PDCH_REQ = 6811 RLC: PH_RLC_CONTROL_CONTROL_2_PDCH_REQ = 6812 RLC: PH_RLC_CONTROL_CONTROL_3_PDCH_REQ = 6813 RLC: PH_RLC_CONTROL_CONTROL_4_PDCH_REQ = 6814 RLC: PH_RLC_CONTROL_CONTROL_5_PDCH_REQ = 6815 RLC: PH_RLC_CONTROL_DATA_0_PDCH_REQ = 6816 RLC: PH_RLC_CONTROL_DATA_1_PDCH_REQ = 6817 RLC: PH_RLC_CONTROL_DATA_2_PDCH_REQ = 6818 RLC: PH_RLC_CONTROL_DATA_3_PDCH_REQ = 6819 RLC: PH_RLC_CONTROL_DATA_4_PDCH_REQ = 6820 RLC: PH_RLC_CONTROL_DATA_5_PDCH_REQ = 6821 RLC: PH_RLC_CONTROL_CONTROL_0_PDTCH_PDCH_REQ = 6822 RLC: PH_RLC_CONTROL_CONTROL_1_PDTCH_PDCH_REQ = 6823 RLC: PH_RLC_CONTROL_CONTROL_2_PDTCH_PDCH_REQ = 6824 RLC: PH_RLC_CONTROL_CONTROL_3_PDTCH_PDCH_REQ = 6825 RLC: PH_RLC_CONTROL_CONTROL_4_PDTCH_PDCH_REQ = 6826 RLC: PH_RLC_CONTROL_CONTROL_5_PDTCH_PDCH_REQ = 6827 RLC: PH_RLC_CONTROL_DATA_0_PDTCH_PDCH_REQ = 6828 RLC: PH_RLC_CONTROL_DATA_1_PDTCH_PDCH_REQ = 6829 RLC: PH_RLC_CONTROL_DATA_2_PDTCH_PDCH_REQ = 6830 RLC: PH_RLC_CONTROL_DATA_3_PDTCH_PDCH_REQ = 6831 RLC: PH_RLC_CONTROL_DATA_4_PDTCH_PDCH_REQ = 6832 RLC: PH_RLC_CONTROL_DATA_5_PDTCH_PDCH_REQ = 6833 RLC: PH_RLC_RELEASE_REQ = 6834 RLC: RLC_PH RLC: PH_RLC_DATA_CNF = 6845 RLC: PH_RLC_DATA_IND = 6846 RLC: PH_RLC_DATA_RTS_IND = 6847 RLC: PH_RLC_DATA_RELEASE_CNF = 6848 RLC: PH_RLC_CONNECT_IND = 6849 RLC: PH_RLC_CONTROL_CNF = 6850 RLC: PH_RLC_CONTROL_IND = 6851 RLC: PH_RLC_RELEASE_CNF = 6852 RLC: RLC_TIMER RLC: RLC_TIMER_T3164 = 7020 RLC: RLC_TIMER_T3166 = 7021 RLC: RLC_TIMER_T3180 = 7022 RLC: RLC_TIMER_T3182 = 7023 RLC: RLC_TIMER_T3190 = 7024 RLC: RLC_TIMER_T3192 = 7027 RLC_UL: S I RR: PID 65603 RR: RR_MM_PRIM 6255 RR: MM_RR_PRIM 6265 RR: MPH_RR_PRIM 6275 RR: RR_MPH_PRIM 6345 RR: DL_RR_PRIM 6395 RR: RR_DL_PRIM 6405 RR: RR_MMM_PRIM 6465 RR: MMM_RR_PRIM 6475 RR: RR_RLC_PRIM 6495 RR: RLC_RR_PRIM 6505 RR: PH_MPH_PRIM 6565 RR: MPH_PH_PRIM 6635 RR: MPH_CB_PRIM 6695 RR: CB_MPH_PRIM 6705 RR: MPH_MMM_PRIM 6735 RR: MMM_MPH_PRIM 6745 RR: PH_RLC_PRIM 6805 RR: RLC_PH_PRIM 6845 RR: RLC_LLC_PRIM 6940 RR: LLC_RLC_PRIM 6950 RR: RR_LLC_PRIM 6990 RR: LLC_RR_PRIM 7000 RR: PH_RR_PRIM 7200 RR: RR_PH_PRIM 7205 RR: RR_TIMER_PRIM 7170 RR: MPH_TIMER_PRIM 7140 MPH_Low: PID 65606 LLC: PID 65607 LLC: <SMS 3378 LLC: >SMS 3389 LLC: <SNDCP 6895 6903 LLC 1: state 0 LLC 3: state 0 LLC 5: state 0 LLC 7: state 0 LLC 9: state 0 LLC 11: state 0 RLC_DL: S I ### Print Server: Requesting DebugMux channel... 1838 ### Print Server: Started OK 1838 LLRS232: EILD_LLRS232_HandleSignal_R_Do_Start 1840 Prototype Start Process [File System Version Control]: Type OK (Ellen) E 1841 OS Time and RTC syncronized. The time diff was 1128038814 s 1841 RLink: RLINK_PH 1841 RLink: PH_RLINK_CONNECT_IND = 6227 t 1841 RLink: PH_RLINK_DISCONNECT_IND = 6228 A 1841 RLink: PH_RLINK_RTS_IND = 6225 1841 RLink: PH_RLINK_DATA_IND = 6226 1841 RLC: PH_RLINK 1841 RLink: PH_RLINK_DATA_REQ = 6215 1841 RLink: RLINK_RLP 1841 RLink: RLINK_RLP_RTS_IND = 4566 1841 RLink: RLINK_RLP_DATA_IND = 4568 1841 RLC: RLP_RLINK 1841 RLink: RLINK_RLP_DATA_REQ = 4569 1841 RLink: RLINK_RLP_DTX_REQ = 4570 1841 RLC: RLINK_RR 1841 RLC: RR_CHANNEL_MODE_INFO_IND = 23552 1841 RLC: RR_CHANNEL_MODE_MODIFY_IND = 23553 1841 RLink: State IdleRH: Activate on LRRAT = 0 1841 RH state: InactiveRational Rose RealTime C Target Run Time SystemRelease 6.50.C.00 1841 Copyright (c) 1993-2003 Rational Software 1842 ILD_HCITL.c: 603 EILD_HCITL_SetTXPin: PinLevel = 0 1842 SM: Initiated; ProcessID = 65659 ! 1842 NS versions: 1842 cnh1010128_rrtose => CNH1010128_R5S 1842 cnh1010235-2_ns_cas => BAS_G210_CUST_CNH1010235_2_050810_1512 1842 cnh1010237_ns_was_if => CNH1010237_R9L 1842 cnh1010238_ns_was => CNH1010238_R9AB 1842 cnh1010278_rose_rt_codegen => CNH1010278_R4F 1842 cnh1601471_ns_gas_l23 => CNH1601471_R1T002 1842 cnh160294-3_ns => CNH160294_3_R2S001 1842 cnh160573_network_asi => CNH160573_R6K 1842 cnh160884_ns_rrt_top_model => CNH160884_R7G 1842 MM: reset TMSI 1842 MM: No valid GSM keys 1842 MM: No valid WCDMA keys 1842 MM: state 0GMM: ResetSIM_Data 1842 GMM: No valid GSM-GPRS keys 1842 GMM: No valid WCDMA keys 1842 LLC 1: Unexpected signal #6972DRM: DRM_Process started 1842 * CC7 state 0 1842 * CC6 state 0 1842 * CC5 state 0 1842 * CC4 state 0 1842 * CC3 state 0 1842 * CC2 state 0 1843 * CC1 state 0 1843 SEMC_ACB: Process started, pid 0x100d4. 1843 SEMC_ACB: Version = ACBM V3.10, debuglevel = 0x1131SMC_MT (65636) state 4 1843 SMC_MO_2 (65635) state 4 1843 SMC_MO_1 (65634) state 4 1843 CallMeter startedSS: State Idle @GDFS_SRV State 1-ClosedSMR_MT state 3 1846 SMR_MO state 3 1846 cp_flow_t : Entries= 50, Entry size= 212 1846 tcp_flow_lite_t : Entries= 50, Entry size= 32 1846 tpl_pcb_t : Entries= 50, Entry size= 128 1846 [ICC-LD] ICC_Reader_0_Process Started 1846 [ICC-LD] Status Changed: ICC_READER_DEACTIVATED, Reader: 0[SIM] State Changed: SIM_STATE_NULL, Appl: 0, Ref: 0M: MODULE_INIT 1850 ACM: Starting Application Side. 1852 Prototype Start Process [File System Version Control]: Version OK (R3A_1) 1866 GDFS: Format version 1 1867 GDFS Log[0] <- Phys[0] 94120 bytes left. Erased 1 times 1868 GDFS Log[1] <- Phys[1] 104594 bytes left. Erased 1 times 1870 GDFS Log[2] <- Phys[2] 92108 bytes left. Erased 1 times 1871 GDFS Log[3] <- Phys[3] 112565 bytes left. Erased 1 times 1871 GDFS Log[4] <- Phys[4] 122314 bytes left. Erased 1 times 1871 GDFS Log[5] <- Phys[5] 125059 bytes left. Erased 1 times 1872 GDFS Log[6] <- Phys[6] 127338 bytes left. Erased 1 times 1874 GDFS_SRV State 2-Opening 1874 CC: speech ver config 2 0 1 15 15 1874 BT Dispatch signal base: 16025 (0x3e99) 1874 BT Request signal base: 15715 (0x3d63) 1874 BT Response signal base: 15870 (0x3dfe) 1874 BT Module Internal base: 583 (0x247) 1875 BT_UART_ON_TIMER: 590 (0x24e) 1875 EVENT_BT_EBT_STACK: 615 (0x267) 1875 BT Signal Interval end: 887 (0x377) 1875 BT/EBT_sil.c: 374 SIL_OpenConnection: COM1:baud=115200 parity=N data=8 stop=1 1875 ###Downloading DSP for first time after startup of phone!### 1875 DSPIF_INT Exception: MPORTIF Soft reset 1875 DSPIF_INT Exception: MPORTIF Soft reset 1875 CC: TTY mode = 0 1876 * CC0 state 0 1876 MPH: PacketChannels activated 1876 RR Multislot class GPRS = 10 1876 RR state 0 1876 MS_TYPE = MS_EGSM900_DCS1800_PCS1900 1876 MPH:SelectedModeIndex=1 1876 MPH_GD_Info.SensitivityLimit_dBm[BAND_GSM900_OR_EGSM900] = -107 1876 MPH_GD_Info.SensitivityLimit_dBm[BAND_DCS1800] = -107 1876 MPH_GD_Info.SensitivityLimit_dBm[BAND_PCS1900] = -107 1878 FSUSB: FS-USB Connection was initiated. 1880 DSPIF_INT Exception: MPORTIF Soft reset 1880 DSPIF_INT Exception: MPORTIF Soft reset 1880 MPH_GD_Info.SensitivityLimit_dBm[BAND_GSM850] = -107 1880 MPH_GD_Info.MinNrOfIdentifiedCellsToSkipWeakCells = 0 1880 MPH: EGSM900_DCS1800 1880 MPH: Default value 57 used for MPH_GD_AFC_Hz_Per_DAC_Step 1880 MPH: Default values used for MPH_GD_AFC_Window_Frequency_Limit 1881 MPH: Default values used for MPH_GD_AFC_Window_Frequency_Limit 1881 MPH NullState 1881 ENH_Control_Reset: IsPkt 0 IsARFCNsInit 0 1881 ENH_Control_Reset: IsPkt 1 IsARFCNsInit 0 1881 ENH_NCParameters_Reset ALL 1881 ENH_RTD_RP_MP_Reset 1881 ENH_RTD_RP_Reset 1881 ENH_RTD_RP_MP_Reset 1881 ENH_RTD_RP_ResetEILD_HCITL.c: 603 EILD_HCITL_SetTXPin: PinLevel = 1 1881 EILD_HCITL.c: 752 SetBaudRate: = 115200, Stopbits = 1 1881 IrDA_ll.c:: IrLAP Nickname: Sony Ericss 1881 IrDA_lap_rec.c: IrLAP process ready ! 1881 IrDA_lmp_rec.c: IrLMP process ready ! 1881 IrDA Request signal base: 21514 (0x540a) 1881 IrDA Response signal base: 21538 (0x5422) 1881 IrDA Event signal base: 21563 (0x543b) 1882 IrDA Module Internal start: 2673 (0x0a71) 1882 IRLAP_CONNECT_IND: 2674 (0x0a72) 1882 LM_CONNECT_REQ: 2706 (0x0a92) 1882 IrDA Module Internal end: 2736 (0x0ab0) 1882 FSUSB: USB Mass Storage process started, pid = 0x100D7. 1882 GMM<-GMM_EXTREGISTRATIONINFO_SET_REQ[sysctrl] start-up cause : Charger Connected 1882 [sysctrl] Enabling UICC refresh task. 1882 ETX OK 1883 MMM IMEI = 357442-00-756630-0, IMEI_SVN=02 1883 MMM EqPLMN List read from GDFS, nbr=1, 502 12 1883 MMM state 0 1883 MMM MS_OperationMode=0 1884 ## DSP VersionIdentity: "CRH109693_R4F MIDI_PCM_ASR --- QSTEMOH_CRH109693_R4F Wed May 11 17:55:39 2005" 1884 DebugMux[IMEI] Length=8, TypeOfID=2, OddEven=1, Digits: 3 5 7 4 4 2 0 0 7 1885 VCXO_Control_BlockClockUserIndex = 8 1888 HW_Radio_Init: VCXO_DAC_Value: 0x294 1888 [SIM_FILE_UTIL] FCP Cache Size 80 1888 CCS: Idle[lockctrl] SimLock : NOT OK, PhoneLock : NOT OK, Sim Active : NOT ACTIVE 1892 [lockctrl] SimLock : NOT OK, PhoneLock : NOT OK, Sim Active : NOT ACTIVE 1892 [lockctrl] SimLock : NOT OK, PhoneLock : NOT OK, Sim Active : NOT ACTIVE 1892 [lockctrl] SimLock : OK, PhoneLock : OK, Sim Active : NOT ACTIVE 1893 [ICC-PD] RD(270) WR(270) VR(1..2) T1(0) D8(1) D16(1) D32(0) D64(0) RM(0) CS(0) 1893 SL: SearchingMode = 1 1893 SL: RAT_Mode = GSM single mode 1893 ns_util: MS Features:27f11 1894 ns_util: CFG_ENABLE_GSM_GPRS_CALL_SUPPORT 1894 SL: SIGID_INTERVAL_START_MOD_NS_CAS = 3215 1894 SL: ProcessID = 1005c 1894 SL: CFG_DISABLE_SECURITY_HANDLING is NOT! defined 1894 SL: DUAL_RAT_SUPPORT is NOT! defined 1894 SL state 0 1894 SL<-EVENT_SIM_STATE_CHANGED in State 0 from 100b5 1894 SL: Not active 1894 SL new SIM handle=0*** PID started 65587. *** 1894 *** Test code: .... disabled. *** 1895 *** Runtime checks: disabled. *** 1895 *** Fatal errors: . enabled. *** 1895 *** Debug traces: . disabled. *** 1895 max timers 1 1895 RLP: process started 1895 L2RCOP: process started 1895 RLP: state changed to 'S0_ADMandDetached' 1895 L2RCOP: state changed to 'Initial' 1896 SM: Received REQUEST_PS_PERIODICREPORT_ENABLE 1897 SL<-23321 in State 0 from 1002e 1897 SL: Not active 1907 [ICC-PD] Fi: 1 Di: 1 Div1: 0 Div2: 0 1907 FS: Partition /ifs set to dirty 1940 [ICC-PD] Fi: 1 Di: 1 Div1: 0 Div2: 0EILD_HCITL.c: 1425 ReportUnexpectedError: HCITL_ErrorCode = 0, UART_ErrorCode = 0x06 1964 [SIM] *** ERROR *** No Card Present 1964 [SIM] InitialiseCard SIM_APPLICATION_UNKNOWN 1964 [SIM] WARNING - Destruction of Application Parameters 1964 [SIM_FILE_UTIL] Used Cache Records 0 1964 [SIM_FILE_UTIL] Max Cache Records 80 1964 [SIM] WARNING - Destruction of Card Parameters 1964 [SIM] State Changed: SIM_STATE_POWER_OFF, Appl: 0, Ref: 0[lockctrl] SimLock : OK, PhoneLock : OK, Sim Active : NOT ACTIVE 1964 SL<-EVENT_SIM_STATE_CHANGED in State 0 from 100b5 1964 SL: Not active 1964 SL new SIM handle=0ACM.StartMain: Starting First App. id=1... 2030 ACM.StartMain: Start of First App ok. 2030 AM: MODULE_INIT_READY 2030 2030 2030 ****************************************** 2030 * Sony Ericsson Mobile Communications AB * 2030 * Copyright 2003 * 2030 ****************************************** 2030 * R4AB048 prgCXC1250086_CHINA_EL * 2030 ****************************************** 2030 2030 (OBEX/obex_session.c line: 2254) OBEX Started. 2031 RTP_Ctrl started 2032 SPBC Process started 2032 SPBC <- SIM_STATE_POWER_OFFMMPROT[SIP]: SIP started 2033 MMPROT[RTSP]: RTSP Process Started 2048 BATT: Battery type is TYPE 2 2049 BATT: Measurements are 4089 mV and 0.0 mA 2049 BATT: Compensated VBAT (3964 mV) based remaining capacity is 75.0% 2052 GVI:Ready 2107 TIME LD:ld_time.c Init of RTC failedGDFS_Wrapper: **** Up and running **** 2131 BT/EBT_sil.c: 393 SIL_OpenConnection: Start event OK! 2131 BT/EBT_sil.c: 419 Free expected "break" 2131 BT/BT.c: 4208 BT_UART_Clock: ON 2131 BT/BT.c: 5949 HCI_CONFIGURE_PORT_CNF: 2131 BT/BT.c: 5938 HCI_START_CNF: 2148 CSATSERVICES_IMP: CSatServices_Constructor 2149 Watchdog: process up and running. 2149 Watchdog: Crash SMS not activated 2150 SL<-REQUEST_CSS_VOICECALLVOLUME_SET in State 0 from 100de 2150 SL: Not active 2151 SL<-REQUEST_CSS_VOICECALLVOLUME_SET in State 0 from 100de 2151 SL: Not active 2151 SL<-REQUEST_CSS_VOICECALLVOLUME_SET in State 0 from 100de 2151 SL: Not active 2154 SL<-23321 in State 0 from 100df 2154 SL: Not active 2155 [CLH] Server started 2160 [CLH] Read 0 customized ECCs 2160 UI: UI_Backlight_Init, did not get a valid backlight level - 0 2162 *** Warning: Not valid window. NULL *** 2164 Disp_CreateFont: Creating font 0 2164 Disp_CreateFont: Creating font 15 2164 Disp_CreateFont: Creating font 16 2165 Disp_CreateFont: Creating font 17 2165 Disp_CreateFont: Creating font 18 2165 Disp_CreateFont: Creating font 21 2165 Disp_CreateFont: Creating font 22 2165 Disp_CreateFont: Creating font 24 2166 Disp_CreateFont: Creating font 25 2166 Disp_CreateFont: Creating font 34 2166 Disp_CreateFont: Creating font 35 2166 Disp_CreateFont: Creating font 37 2166 Disp_CreateFont: Creating font 38 2166 Disp_CreateFont: Creating font 45 2167 Disp_CreateFont: Creating font 46 2167 Disp_CreateFont: Creating font 54 2167 Disp_CreateFont: Creating font 53 2167 ***** Investigating Language Availability ***** 2171 ENG: FS = Unavailable, ROM = Available 2172 IND: FS = Prohibited, ROM = Unavailable 2172 MAL: FS = Prohibited, ROM = Unavailable 2172 TAG: FS = Prohibited, ROM = Unavailable 2173 VTN: FS = Prohibited, ROM = Unavailable 2173 PRC: FS = Available, ROM = Unavailable 2173 *********************************************** 2173 ***** Investigating Input Features ***** 2173 Arabic: NO 2173 China: YES 2173 Hebrew: NO 2173 T9: YES 2173 Greek: NO 2173 Cyrillic: NO 2173 Thai: NO 2173 Icelandic: NO 2173 Ukrainian: NO 2173 Hindi: NO 2173 Bengali: NO 2173 **************************************** 2173 ***** Investigating Input Language Availability ***** 2173 Predictive state is: ON 2173 Predictive default (cust) is: ON 2174 ENG: allowed = YES, T9-FS = YES, T9-ROM = NO 2175 PRC: allowed = YES, T9-FS = NO, T9-ROM = YES 2176 ABC: allowed = YES, T9-FS = NO, T9-ROM = NO 2176 123: allowed = YES, T9-FS = NO, T9-ROM = NO 2176 ***************************************************** 2356 SL<-REQUEST_ROAMING_CURRENTPLMN_STATUS_GET in State 0 from 100eb 2356 SL: Not activeBT/BT.c: 1279 HostController_Init: Bluetooth Spec 1.2 2386 BT/BT.c: 1739 HCI_Version = BT1.2, LM_Version = R4A Generated: 2005-04-11 15:24 Comment: BbyoneSW_2LLP 1.1 2386 BT/BT.c: 1748 CHIP_ID = 0x313e402b, HCI_Revision = 0x0798, BT_LMP_Subversion = 0x041c 2389 BT/BT.c: 1980 Download: PatchFile_2LLP_1_1_PatchId_01.fdw, Size = 444 2404 BT/BT.c: 1980 Download: FS_050324_BGB204_HEAD_SEMC_02_2LLP1.0.ofs, Size = 264 2412 BT/BT.c: 1861 Download: GD_BT_Dynamic_Settings_File, Size = 44 2421 AT/CFS/PrintToTraceLog_AT_CmdList: Forwarding to app layer (e.g. AAS); Commands/identifiers listed in 'at_cmds.dat': 2421 AT/CFS, FwdCmd: '*' 2421 AT/CFS, FwdCmd: 'VOICE_CMDS' 2421 AT/CFS, FwdCmd: 'Z' 2421 AT/CFS, FwdCmd: '&F' 2421 AT/CFS, FwdCmd: '*EAID' 2421 AT/CFS, FwdCmd: '*EALR' 2421 AT/CFS, FwdCmd: '*EALS' 2421 AT/CFS, FwdCmd: '*EAM' 2421 AT/CFS, FwdCmd: '*EAMS' 2422 AT/CFS, FwdCmd: '*EAPN' 2422 AT/CFS, FwdCmd: '*EAPP' 2422 AT/CFS, FwdCmd: '*EAPS' 2422 AT/CFS, FwdCmd: '*EARS' 2422 AT/CFS, FwdCmd: '*EASM' 2422 AT/CFS, FwdCmd: '*EAST' 2422 AT/CFS, FwdCmd: '*EBCA' 2422 AT/CFS, FwdCmd: '*ECAP' 2422 AT/CFS, FwdCmd: '*ECAR' 2422 AT/CFS, FwdCmd: '*ECAS' 2422 AT/CFS, FwdCmd: '*ECAW' 2422 AT/CFS, FwdCmd: '*ECBP' 2422 AT/CFS, FwdCmd: '*ECCQ' 2422 AT/CFS, FwdCmd: '*ECCR' 2422 AT/CFS, FwdCmd: '*ECSP' 2422 AT/CFS, FwdCmd: '*ECUR' 2422 AT/CFS, FwdCmd: '*EDIF' 2422 AT/CFS, FwdCmd: '*EDIS' 2422 AT/CFS, FwdCmd: '*EDST' 2422 AT/CFS, FwdCmd: '*EENL' 2422 AT/CFS, FwdCmd: '*EIPS' 2422 AT/CFS, FwdCmd: '*EJAVA' 2422 AT/CFS, FwdCmd: '*EGIR' 2422 AT/CFS, FwdCmd: '*EKSR' 2422 AT/CFS, FwdCmd: '*ELAN' 2422 AT/CFS, FwdCmd: '*ELIB' 2422 AT/CFS, FwdCmd: '*ELIF' 2422 AT/CFS, FwdCmd: '*ELIN' 2422 AT/CFS, FwdCmd: '*ELOO' 2422 AT/CFS, FwdCmd: '*EKEY' 2422 AT/CFS, FwdCmd: '*EMAR' 2423 AT/CFS, FwdCmd: '*EMEM' 2423 AT/CFS, FwdCmd: '*EMIC' 2423 AT/CFS, FwdCmd: '*EMIR' 2423 AT/CFS, FwdCmd: '*EMWS' 2423 AT/CFS, FwdCmd: '*ENAD' 2423 AT/CFS, FwdCmd: '*EPED' 2423 AT/CFS, FwdCmd: '*EPEW' 2423 AT/CFS, FwdCmd: '*EPHD' 2423 AT/CFS, FwdCmd: '*EPNR' 2423 AT/CFS, FwdCmd: '*EPNW' 2423 AT/CFS, FwdCmd: '*EPRD' 2423 AT/CFS, FwdCmd: '*EPRR' 2423 AT/CFS, FwdCmd: '*EPRW' 2423 AT/CFS, FwdCmd: '*ERIF' 2423 AT/CFS, FwdCmd: '*ERIL' 2423 AT/CFS, FwdCmd: '*ERIN' 2423 AT/CFS, FwdCmd: '*ERIP' 2423 AT/CFS, FwdCmd: '*ESAG' 2423 AT/CFS, FwdCmd: '*ESAM' 2423 AT/CFS, FwdCmd: '*ESBL' 2423 AT/CFS, FwdCmd: '*ESCG' 2423 AT/CFS, FwdCmd: '*ESCN' 2423 AT/CFS, FwdCmd: '*ESDF' 2423 AT/CFS, FwdCmd: '*ESDG' 2423 AT/CFS, FwdCmd: '*ESDI' 2423 AT/CFS, FwdCmd: '*ESGR' 2423 AT/CFS, FwdCmd: '*ESIL' 2423 AT/CFS, FwdCmd: '*ESKL' 2423 AT/CFS, FwdCmd: '*ESLN' 2423 AT/CFS, FwdCmd: '*ESKS' 2424 AT/CFS, FwdCmd: '*ESMA' 2424 AT/CFS, FwdCmd: '*ESMM' 2424 AT/CFS, FwdCmd: '*ESNU' 2424 AT/CFS, FwdCmd: '*ESTF' 2424 AT/CFS, FwdCmd: '*ESVM' 2424 AT/CFS, FwdCmd: '*EVA' 2424 AT/CFS, FwdCmd: '*EVAA' 2424 AT/CFS, FwdCmd: '*EVD' 2424 AT/CFS, FwdCmd: '*EVH' 2424 AT/CFS, FwdCmd: '*EWHP' 2424 AT/CFS, FwdCmd: '*EWPR' 2424 AT/CFS, FwdCmd: '*EWPN' 2424 AT/CFS, FwdCmd: '*EWDT' 2424 AT/CFS, FwdCmd: '*EWCT' 2424 AT/CFS, FwdCmd: '*EWIL' 2424 AT/CFS, FwdCmd: '*EWLI' 2424 AT/CFS, FwdCmd: '*EWPB' 2424 AT/CFS, FwdCmd: '*EWCG' 2424 AT/CFS, FwdCmd: '*EWBA' 2424 AT/CFS, FwdCmd: '*EWBR' 2424 AT/CFS, FwdCmd: '*SAKED' 2424 AT/CFS, FwdCmd: '*SAKEH' 2424 AT/CFS, FwdCmd: '*SEAM' 2424 AT/CFS, FwdCmd: '*SEACC' 2424 AT/CFS, FwdCmd: '*SEACID' 2424 AT/CFS, FwdCmd: '*SEAUDIO' 2424 AT/CFS, FwdCmd: '*SEAUP' 2424 AT/CFS, FwdCmd: '*SECHA' 2424 AT/CFS, FwdCmd: '*SEDE' 2425 AT/CFS, FwdCmd: '*SEDEL' 2425 AT/CFS, FwdCmd: '*SEDMS' 2425 AT/CFS, FwdCmd: '*SEDMG' 2425 AT/CFS, FwdCmd: '*SEFEXP' 2425 AT/CFS, FwdCmd: '*SEFIN' 2425 AT/CFS, FwdCmd: '*SEFORM' 2425 AT/CFS, FwdCmd: '*SEFRY' 2425 AT/CFS, FwdCmd: '*SEGAUGE' 2425 AT/CFS, FwdCmd: '*SEGUP' 2425 AT/CFS, FwdCmd: '*SEIMAGE' 2425 AT/CFS, FwdCmd: '*SELERT' 2425 AT/CFS, FwdCmd: '*SELIST' 2425 AT/CFS, FwdCmd: '*SELOG' 2425 AT/CFS, FwdCmd: '*SEMOD' 2425 AT/CFS, FwdCmd: '*SEMP' 2425 AT/CFS, FwdCmd: '*SEONO' 2425 AT/CFS, FwdCmd: '*SEPING' 2425 AT/CFS, FwdCmd: '*SEREDI' 2425 AT/CFS, FwdCmd: '*SERSK' 2425 AT/CFS, FwdCmd: '*SESAF' 2425 AT/CFS, FwdCmd: '*SESAKE' 2425 AT/CFS, FwdCmd: '*SESLE' 2425 AT/CFS, FwdCmd: '*SESTRI' 2425 AT/CFS, FwdCmd: '*SETICK' 2425 AT/CFS, FwdCmd: '*SEUIS' 2425 AT/CFS, FwdCmd: '*SEYNG' 2425 AT/CFS, FwdCmd: '*ZAPC' 2425 AT/CFS, FwdCmd: '*ZFSC' 2425 AT/CFS, FwdCmd: '*ZFSD' 2426 AT/CFS, FwdCmd: '*ZFSI' 2426 AT/CFS, FwdCmd: '*ZFSL' 2426 AT/CFS, FwdCmd: '*ZFSMD' 2426 AT/CFS, FwdCmd: '*ZFSP' 2426 AT/CFS, FwdCmd: '*ZFSR' 2426 AT/CFS, FwdCmd: '*ZFST' 2426 AT/CFS, FwdCmd: '*ZFSW' 2426 AT/CFS, FwdCmd: '*ZIPI' 2426 AT/CFS, FwdCmd: '*ZISI' 2426 AT/CFS, FwdCmd: '*ZGUI' 2426 AT/CFS, FwdCmd: '*ZMEM' 2426 AT/CFS, FwdCmd: '*ZPPI' 2426 AT/CFS, FwdCmd: '*ZORRO' 2426 AT/CFS, FwdCmd: '+BINP' 2426 AT/CFS, FwdCmd: '+BLDN' 2426 AT/CFS, FwdCmd: '+BVRA' 2426 AT/CFS, FwdCmd: '+BRSF' 2426 AT/CFS, FwdCmd: '+CALA' 2426 AT/CFS, FwdCmd: '+CALD' 2426 AT/CFS, FwdCmd: '+CAPD' 2426 AT/CFS, FwdCmd: '+CSAS' 2426 AT/CFS, FwdCmd: '+CSCA' 2426 AT/CFS, FwdCmd: '+CCLK' 2426 AT/CFS, FwdCmd: '+CGMM' 2426 AT/CFS, FwdCmd: '+CGMR' 2426 AT/CFS, FwdCmd: '+CHLD' 2426 AT/CFS, FwdCmd: '+CHUP' 2426 AT/CFS, FwdCmd: '+CIND' 2427 AT/CFS, FwdCmd: '+CKPD' 2427 AT/CFS, FwdCmd: '+CLAN' 2427 AT/CFS, FwdCmd: '+CLCK' 2427 AT/CFS, FwdCmd: '+CLIP' 2427 AT/CFS, FwdCmd: '+CLVL' 2427 AT/CFS, FwdCmd: '+CMAR' 2427 AT/CFS, FwdCmd: '+CMER' 2427 AT/CFS, FwdCmd: '+CMUT' 2427 AT/CFS, FwdCmd: '+CPBF' 2427 AT/CFS, FwdCmd: '+CPBR' 2427 AT/CFS, FwdCmd: '+CPBS' 2427 AT/CFS, FwdCmd: '+CPBW' 2427 AT/CFS, FwdCmd: '+CPUC' 2427 AT/CFS, FwdCmd: '+CRES' 2427 AT/CFS, FwdCmd: '+CRMP' 2427 AT/CFS, FwdCmd: '+CRSL' 2427 AT/CFS, FwdCmd: '+CSCB' 2427 AT/CFS, FwdCmd: '+CSCC' 2427 AT/CFS, FwdCmd: '+CSDF' 2427 AT/CFS, FwdCmd: '+CSIL' 2427 AT/CFS, FwdCmd: '+CSNS' 2427 AT/CFS, FwdCmd: '+CSTF' 2427 AT/CFS, FwdCmd: '+CSTA' 2427 AT/CFS, FwdCmd: '+CTFR' 2427 AT/CFS, FwdCmd: '+CVIB' 2427 AT/CFS, FwdCmd: '+GMR' 2427 AT/CFS, FwdCmd: '+NREC' 2427 AT/CFS, FwdCmd: '+VGM' 2427 AT/CFS, FwdCmd: '+VGS' 2427 AT/CFS, FwdCmd: '+WS46' 2432 AT process: Awake and AT your service! 2432 AT/SysInfo SYS_VENDOR_NAME: Sony Ericsson 2432 AT/SysInfo SYS_PRODUCT_NAME: Sony Ericsson W550 2432 AT/SysInfo SYS_PRODUCT_VERSION: 0000 2432 AT/SysInfo SYS_SW_ID: 2005-08-24 21:54 Off.Bld BAS_G210_R3B_EC6_050824_1913 cxc1329035_G200_PHONE_Ellen 2432 AT/SysInfo SYS_SW_PRODUCT_ID: BAS_G210_R3B_EC6_050824_1913 cxc1329035_G200_PHONE_Ellen 2432 AT/SysInfo SYS_SW_VERSION: BAS_G210_R3B_EC6_050824_1913 2432 AT/SysInfo SYS_SW_VERSION_DATE: BAS_G210_R3B_EC6_050824_1913 2432 AT/ AT-3; Received signal 'RESPONSE_RS232_GETCAPABILITIES'(24907), executing CEI_OnRS232_GetCapabilities() 2432 AT/CEI_OnRS232_GetCapabilities: Warning !! The channel already destroyed, execution stopped: ClientTag = d! 2432 AT/ AT-3; Received signal 'REQUEST_AT_GET_STATE_OF_ACTIVE_CHANNELS'(15078), executing CFS_OnRequest_AT_GetStateOfActiveChannels() 2440 [StandbyBook#65] Created 2442 UI: Disp_SetFont - INVALID FONT (65) 2443 [Session#1 "Standby"] Got focus 2447 SoftkeyManager: 2447 Subaction doesn't exist. Creating one. 2447 SoftkeyManager: 2447 Subaction doesn't exist. Creating one.WAP:Start (process id 0x1008F) 2647 WAP: File API Initiated 2647 WAP: fileMkDir(.../msm) 2652 WAP: created task 0 2653 WAP: fileMkDir(.../stk) 2654 WAP: fileMkDir(.../stk/tmp) 2660 WAP: created task 1 2663 WAP: createTask failure for 2 2669 Handle_Shell_Timeout: Time-out from non-existent timer: 4c5f1c3c - Ignored. 2671 Handle_Shell_Timeout: Time-out from non-existent timer: 4c5f1c3c - Ignored. 2694 DRM: Init OK 2694 DRM_PRS: DRM_PRS_Process started 2697 MSG: msgmain.c: State 255 changed to state 0 2702 [StandbyBook#65] Goto StandbyBook_StandbyPage 2702 [VolumeControlBook#66] Created 2702 [Feedbackticker#67] Created 2702 [InitBook#68] Created 2702 [InitBook#68] Goto InitBook_StartUp_Page 2708 [InitBook#68] Goto InitBook_LockedMode_Page 2708 [StandbyBook#65] Goto StandbyBook_ChargingOnly_Page 2718 PBS Process started 2718 PBS: Dispatch PHB_NO_ACCESS 2726 [MassStorageApplicationBook#69] Created 2785 DISP: Warning!!! Nothing drawn in Canvas === 2801 GDFS_WR State 1-Closed 2801 GDFS_WR Start check 2911 MSG: msgmain.c: State 0 changed to state 1 2911 MSG: msgmain.c: EVENT_SIM_STATE_CHANGED accepted 2911 MSG: msgmain.c: SIM_STATE NOT Active 2911 MSG: msgmain.c: EVENT_SIM_STATE_CHANGED accepted 2911 MSG: msgmain.c: SIM_STATE NOT ActiveEILD_HCITL.c: 752 SetBaudRate: = 921600, Stopbits = 1 2918 Handle_Shell_Timeout: Time-out from non-existent timer: 4c5f1c3c - Ignored.BT/HCI.c: 757 Philips_Set_UART_Baud_Rate: Status = 0x00 3044 EILD_HCITL.c: 1550 R_Do_SetPowerOffTime: 500 ms 3219 BATT: Measurements are 4067 mV and -123.0 mA 3219 BATT: Charge current (-123.0 mA) based remaining capacity is 100.0% 3219 BATT: Average remaining capacity is 100.0% 3251 GDFS Free Blk 7 Ok 3251 GDFS_WR Check done 3251 GDFS_SRV State 3-Open 3251 GDFS_WR State 2-Open 3470 BATT: Measurements are 4067 mV and -118.0 mA 3471 BATT: Charge current (-118.0 mA) based remaining capacity is 100.0% 3720 BATT: Measurements are 4100 mV and 176.0 mA 3721 BATT: Charge current (176.0 mA) based remaining capacity is 96.0% 3721 BATT: Average remaining capacity is 98.6% 3969 BATT: Measurements are 4132 mV and 220.0 mA 3969 BATT: Charge current (220.0 mA) based remaining capacity is 94.6% 3969 BATT: Average remaining capacity is 97.6% 4220 BATT: Measurements are 4132 mV and 215.0 mA 4221 BATT: Charge current (215.0 mA) based remaining capacity is 94.8% 4221 BATT: Average remaining capacity is 97.0% 4389 FS: Partition / set to clean 4390 FS: Partition /ifs set to clean 4391 FS: Partition /usb set to clean 4469 BATT: Measurements are 4132 mV and 209.0 mA 4469 BATT: Charge current (209.0 mA) based remaining capacity is 95.0% 4469 BATT: Average remaining capacity is 96.7% 4562 BATT: Battery Temperature is 30 4720 BATT: Measurements are 4132 mV and 215.0 mA 4720 BATT: Charge current (215.0 mA) based remaining capacity is 94.8% 4721 BATT: Average remaining capacity is 96.4% 4970 BATT: Measurements are 4132 mV and 209.0 mA 4971 BATT: Charge current (209.0 mA) based remaining capacity is 95.0% 4971 BATT: Average remaining capacity is 96.2% 5219 BATT: Measurements are 4132 mV and 215.0 mA 5219 BATT: Compensated VBAT (4007 mV) based remaining capacity is 81.4% 5219 BATT: Average remaining capacity is 94.6% 5470 BATT: Measurements are 4132 mV and 220.0 mA 5471 BATT: Average remaining capacity is 93.3% 5720 BATT: Average remaining capacity is 92.2% 5969 BATT: Average remaining capacity is 91.3% 6220 BATT: Average remaining capacity is 90.5% 6471 BATT: Average remaining capacity is 89.9% 6719 BATT: Measurements are 4143 mV and 237.0 mA 6719 BATT: Compensated VBAT (4018 mV) based remaining capacity is 83.0% 6719 BATT: Average remaining capacity is 89.4% 6890 SL<-R_REQ_NSAD_DEACTIVATE in State 0 from 10035 6890 MMM state 17 6890 MM: IsMM_Connected=0 6890 MM: REG FAILED, Cause = DETACHED 6890 GMM<-GMM_DEACTIVATE_REQ 6890 GMM: No TVP timer 6890 GMM: New TLLI distributed to RR: 0xffffffff (255, 255, 255, 255) 6890 TLLI_PTMSI_New 6890 case1 UnassBoth 6890 GMM: Reset combined procedures 6890 GMM: REG FAILED, Cause = DETACHED 6890 MMM HandleNOM: NOM_GSM->NOM_UNKNOWN, MS_Mode=1, ForcedFlag=0 |
04-06-2006, 04:03 | #3 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 239119 Status: Offline Thanks Meter: 9 | CANNOT READ INFO Code: McuId: 80400301FFFFFF, CID: 49, 4 (Red) Mcert: A1_DB2010_49_RED Baud Rate: 921600 Trying: CXC1250165_050909_1014_R2A{DB2010_CID49_RED}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 050909 1014 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2A, Ok IMEI : 135744-20-075663-0, CID: 49, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT Resp Ln: 1, 027C010000000000, Retrying nACK , 1500000000000000, Retrying No Resp, 0000000000000000, Retrying No Resp, 0000000000000000, Retrying Rd_Error at: 0x45EFFFF4, 0000000000000000 INFO Error 1 Configuration Err_40: No Resp User Stop, Total Time: 07:37 |
02-22-2008, 23:00 | #5 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Sogod So. Leyte Age: 47
Member: 139066 Status: Offline Thanks Meter: 6 | before changing anything to your hardware components, try to flash it first with SE tool. i have solve this kind of problem by flashing only with SEtool. hope this would help. |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
W550 keypad problem | mobiledada | Sony Ericsson Hardware Repair | 6 | 07-22-2009 15:06 |
w550 keypad problem | faju | Sony Ericsson Hardware Repair | 5 | 11-15-2008 08:41 |
w550 keypads problem | almobilelink | Sony Ericsson Hardware Repair | 5 | 07-11-2007 08:14 |
W550 Lcd And Keypad No Light Problem | gsm4sp | Sony Ericsson Hardware Repair | 3 | 08-22-2006 14:01 |
