01-21-2006, 14:29 | #16 (permalink) |
Freak Poster Join Date: Feb 2002 Location: singapore Age: 46
Member: 9194 Status: Offline Thanks Meter: 3 | Mcert: A1_DB2010_49_RED Baud Rate: 921600 X_W550_CXC1250032_APAC1_R4AB048_RED49.bin [DB2010_49_RED] X_W550_CXC1250087_CHINA_EL_R4AB048_RED49.bin [DB2010_49_RED] Trying: CXC1250165_050909_1014_R2A{DB2010_CID49_RED}.bin PayLoader Certificate Rejected :00 46 32 AA D9 Trying: CXC1326738_041214_0816_R2U{0101030402}.bin PayLoader Certificate Rejected :00 46 32 AA D9 Trying: CXC1326738_050207_0954_R2X{0101030402}.bin PayLoader Certificate Rejected :00 46 32 AA D9 Trying: CXC1326738_041214_0816_R2AA{0101030402}.bin PayLoader Certificate Rejected :00 46 32 AA D9 Not Found Required Loader MCU Part_1 Flashing Failed, Time: 00:09 here is the result when flashing mcu part.. no fs .. other flasher work .. |
01-21-2006, 14:32 | #17 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @ALL NO NEED TP TO CONNECT...JUST NEED TO SELECT TP OR TP1 .... WHEN ITS ASK YOU CONNECT TP DON'T NEED TO CONNECT JUST PRESS OK AND FLASH START.... MAN I ALREADY CLEARED STEP...BUT NOW I CAN'T POST SAME THING ON IT...JUST USE SOME BRAIN ALSO MY FRIEND... PLS:ho hard fillings... |
01-21-2006, 14:41 | #18 (permalink) | |
Member: 9194 Status: Offline Thanks Meter: 3 | Quote:
Brain . yes.. sure i use my brain.. for wad i post so much thread .. try all man.. iu wan me make every screenshot over here .. with TP TP1 TP2 ? yep i never connect tp as well ..\\ @mr stanner_austin. thnks for ur concern . anyway. i will stick to other flasher . HWK i got so long only use it for fast flashing swift/model .. | |
01-24-2006, 09:14 | #22 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | AS I SAY ALREADY....YOU DON'T NEED TP TO FLASH SO PLS DO CERFULLY.. FOR FLASHING MCU I UPLOADED BOTH IMAGES.... FOR FLASHING MCU YOU DON'T NEED TO CONNECT TP ON PHONE JUST SELECT TP ON SOFTWARE ..... AND WHEN ITS SAY CONNECT TP JUST PRESS OK........THEN MCU FLASHING WORKS...... NOW CUST/FS FLASHING FOR IT YOU HAVE TO DO SAME BUT THIS TIME YOU HAVE TO CONNECT TP WHEN SOFTWARE SAY.... SO DO STEP BY STEP ALL OK...... PHONE TP Last edited by stanner_austin; 09-27-2008 at 18:04. |
01-24-2006, 09:29 | #24 (permalink) |
Registered User Join Date: Mar 2004 Age: 49
Member: 59722 Status: Offline Thanks Meter: 0 | I connect with (bypass-tp) and tab flashmcu and tab OK at connectTP without connecting tp but error McuId: 80400301FFFFFF, CID: 49, 4 (Red) Mcert: A1_DB2010_49_RED Baud Rate: 921600 Trying: CXC1326739_R2F{0101030301}.bin PayLoader Certificate Accepted Prologue Error 2: PayLoader Failed MCU Part_1 Flashing Failed, Time: 00:02 |
01-24-2006, 10:30 | #26 (permalink) |
Member: 59722 Status: Offline Thanks Meter: 0 | thanks for your help . i flash mcu with tp1 and next flash cust with connect tp and phon is now on but with PLEASE WAIT .when i try to unlock it ,i see this error GDFS CRRUPTED .have any body repair sollution for tthis problem? |
01-24-2006, 11:08 | #27 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | hmm BAD....YOU RECOVERED PHONE WITH TP? IF YES THEN HWK IS NOT ABLE TO HELP YOU.. YOU NEED CRUSER OR SETOOL OR USBSMART...... |
01-28-2006, 15:30 | #28 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 42
Member: 171288 Status: Offline Thanks Meter: 23 | sombody tell me who to flash W550universal. i tryed more than 1000timesbut,therr is some error: Terminated wite:Elashing patched software using smartcard is not possible. PLS |
01-29-2006, 19:35 | #29 (permalink) |
No Life Poster Join Date: May 2005 Location: iran Age: 43
Member: 143648 Status: Offline Thanks Meter: 179 | file kzf.ini&kzf.exe if difrent ver show this eror you can edit kzf.ini but you must have cxc file for edit ini if you can edit ini and you have cxc for w550 u can flash this phon becuse enother phon not ansewr this phon good luck |
3120c lighting problem...plz urgent help. | RATHNAMOBILESS | Nokia Hardware & Hardware Repair | 2 | 09-06-2009 20:06 |
1208 flash problem.... need urgent help | Ghaffar84 | BB5 No TP By Jafsupport | 1 | 03-02-2009 10:28 |
***** flash problem need urgent help plz | karouk | FuriousGold | 2 | 08-22-2007 09:14 |
w550i flashing problem need urgently help | manish665 | Cruiser Suite | 4 | 06-23-2007 12:21 |
