05-16-2007, 09:39 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Age: 46
Member: 101863 Status: Offline Thanks Meter: 0 | HWK authorization error After I formated my computer and reinstalled UFS Suite and HWK I got this error messag: Unexpected Exceptation: BOX_AUTH_ERROR: 20 You have also attached the screenshot. Thanks in advance Attached Images |
05-16-2007, 10:36 | #3 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | DO NOT, perform this process unless you have Box Auth Error 20, or you are advised to do so. 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your reseller. 8. When you receive xxxxxx.fbi from your reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. Your reseller is the only person who can help with this process, do not ask here in the forum, we will not generate xxxxxx.fbi files for you. NOTES:- 1. the xxxxxx.fbi file sent by your reseller is one time use only. 2. once you have made the xxxxxx.req file, do not perform any other steps on the box, since this will cause the xxxxxx.fbi file to be out of sync. |
Authorization Error C4 DM***x after update hwk | Yz_Soebodonk | Typhoon Dongle | 5 | 03-31-2008 22:37 |
HWK Authorized, after some time un-authorised | karwos | HWK | 67 | 02-26-2007 13:44 |
HWK author pls answer | M@TRIX | HWK | 7 | 08-04-2005 14:34 |
LP2002 limit limited Flash Authority Error . . . index [fa010] | mobilemafia | Nokia Digital Core Technology 4 ( DCT-4 ) | 12 | 02-16-2004 00:29 |
