07-21-2008, 16:50 | #1 (permalink) |
Major Poster Join Date: Feb 2006
Member: 231124 Status: Offline Thanks Meter: 3 | TO Odia The Ultimate ------------------------------------------------------------------------ Issue: ------ Issue:Nokia phones give error: "ERR: CMT ALG Boot CERT MISM" or "CMT 2nd Boot CERT Mismatch" on "Check" or "Flash" Problem: -------- Some UFS manufacturers used a National LP2951C M33 (3.3V) regulator, instead of a LP2951C M30 (3.0V) regulator (IC - U6) Workaround: ----------- Change regulator to LP2951C M30 ---------------------------------------------------------------------------- |
The Following User Says Thank You to djelloul71 For This Useful Post: |
07-22-2008, 11:27 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Here is the underside of a SHU box, you can see the regulator is marked U6 very clear. This one is a CM30A but same specs as a M30. Odia. |
to Odia The Ultimate | usmartu | HWK | 4 | 09-23-2008 18:38 |
to Odia the Ultimate | NDU | HWK | 3 | 09-26-2007 15:41 |
To Odia The Ultimate | yoyo5555 | HWK | 15 | 07-16-2007 08:27 |
To Odia the Ultimate | rafalkapalka | HWK | 6 | 02-20-2007 22:42 |
to Odia the Ultimate | NDU | HWK | 1 | 01-16-2007 11:58 |
