01-15-2012, 13:03 | #1 (permalink) |
Insane Poster Join Date: Mar 2008 Location: western kenya-bungoma
Member: 717304 Status: Offline Thanks Meter: 14 | x2-01 security code problem. Insert USB Cable to Switched ON Phone Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 56,06 [Rm-709] [2.2.0.3] CMT ASICID: 000000000000000022000509200C0000 EM 1 ID : 00005361 CMT PUBID : 0000000000E4A4E861D88E068885D4FA556A7AF2 CMT MODE : 00 CMT HASH : 1B0D74C532CA1C6133940C740E8C786E CMT ROMID : DE56D582BDDE7A3A CMT 2ND Bt: BCM21351_usb2nd.fg, Ver: 11.34.0 CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00200030-00000131, St OneNAND-1G CMT FLID1 : 00200030-00000131, St OneNAND-1G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : BCM21351_XSR16_usbalg.fg, Ver: 11.34.0 CMT KSIG0 : 37955B6FC432998EF0DB240E332228384D19ED09 CMT ALG Boot OK IMAGE : rm709__08.65.mcusw CMT NAND Erase Area: 0x00000000-0001FFFF CMT NAND Erase Area: 0x00020000-000203FF CMT NAND Erase Area: 0x00060000-012FFFFF CMT NAND Erase Area: 0x01300000-01DFFFFF CMT NAND Erase Area: 0x02600000-029FFFFF CMT NAND Partition Format CMT NAND Partition Format CMT FLASH ERASE OK, Time: 00:00 Written: 11 Certificate(s) CMT FLASH WRITE OK, Time: 00:34 IMAGE : rm709__08.65_001.image_l_claro_cam_v1_9g8n3 CMT NAND Erase Area: 0x02A00000-0753FFFF CMT NAND Partition Format CNT FLASH ERASE OK, Time: 00:01 CNT FLASH WRITE OK, Time: 00:33 IMAGE : rm709__08.65.ppm_l CMT NAND Erase Area: 0x01E00000-025FFFFF PPM FLASH ERASE OK, Time: 00:00 PPM FLASH WRITE OK, Time: 00:07 Flashing Completed, Rebooting Mobile |
01-15-2012, 21:41 | #9 (permalink) |
Freak Poster Join Date: Sep 2011 Location: INSIDE DEVICES
Member: 1652212 Status: Offline Thanks Meter: 73 | x2-01 unlocked with hwk 100% just use usb cable and fbus cable. remove battery and insert fbus cable without disconecting usb cable read info it will ask u 2 instal drivers just cancel it then u done...Nb u can use any fbus cable when connectors are the same. dont forget 2 say thanks |
The Following 2 Users Say Thank You to Macie provider For This Useful Post: |
01-18-2012, 09:27 | #11 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. 100% solution, again flash with hwk & dont disconnect after flashing you will see on top of hwk that it is in normal mode, so just click it to local mode & it will change to local mode, if you do this immediate after flash. now you can change user code from ui setting. have a good day.......... |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
