06-29-2012, 17:53 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | samsung i9250 test mode firmware is there any firmware on the support area which can make the phone go into to test mode for unlock procedure with other boxes? because the firmware which is on the phone does not allow me to enter debug menu when i press *#9090# can this firmware make *#9090# to work i9250_CODE_I9250XXKK1_ITL41F_SIGNED_XEN.tar.zip |
06-29-2012, 18:05 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | to enter debug mode: from menu----------> setting ----------> applications------------> development--------->debug. good luck |
06-29-2012, 18:24 | #3 (permalink) |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | ah ok look here maybe this can help you http://forum.gsmhosting.com/vbb/f452...olved-1433276/ if you are using the same tool i give you the link then you can't use any other firmware. good luck |
06-29-2012, 18:34 | #4 (permalink) | |
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
06-29-2012, 18:59 | #5 (permalink) | |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | Quote:
he has only 2 options. - buying the same tool. - giving phone to you for unlock. good luck | |
06-29-2012, 19:04 | #6 (permalink) | |
do you know if this firmware can do that? i9250_CODE_I9250XXKK1_ITL41F_SIGNED_XEN.tar.zip its from hwk support | |
06-29-2012, 19:26 | #7 (permalink) |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | my friend the firmware you use for unlock isn't an ordinary firmware, it is what we named patched firmware, it allow read of some data or to put phone in some mode. your friend must write the same firmware(Test FIMWARE) you use with your tool, but as i know those firmware come crypted and only software of your tool will decrypte and flash it to phone. you cant find any patched firmware without encryption system ( this is needed for protecting solution form some copy paster not all) Regard adel |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
How to upgrade firmware on Nokia | Pepek | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-18-2000 23:29 |
I have that soft if smb need ask for testing.. | Nec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-01-2000 23:47 |
6150 firmware versions | maxim | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-25-2000 10:55 |
