03-10-2010, 15:25 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | 5 pieces g1157 unlocked LOG: [03/10/10 18:59:01] Firmware: REL_P1.2PU04V01.04 [03/10/10 18:59:01] IMEI: 35633403729XXXX [03/10/10 18:59:01] [03/10/10 18:59:01] 2. Press Power ON shortly! [03/10/10 18:59:01] 1. Remove the battery and then insert it again! [03/10/10 18:59:01] [03/10/10 18:59:24] IMEI: 3563340372XXXX-X [03/10/10 18:59:25] Direct unlock succeeded. [03/10/10 19:06:42] [03/10/10 19:06:43] Firmware: REL_P1.2PU04V01.04 [03/10/10 19:06:43] IMEI: 35633403829XXXX [03/10/10 19:06:43] [03/10/10 19:06:43] 2. Press Power ON shortly! [03/10/10 19:06:43] 1. Remove the battery and then insert it again! [03/10/10 19:06:43] [03/10/10 19:07:04] IMEI: 3563340382XXXX-X [03/10/10 19:07:05] Direct unlock succeeded. [03/10/10 19:07:38] [03/10/10 19:07:38] Firmware: REL_P1.2PU04V01.04 [03/10/10 19:07:38] IMEI: 35633403830XXXX [03/10/10 19:08:15] Firmware: REL_P1.2PU04V01.04 [03/10/10 19:08:16] IMEI: 35633403830XXXX [03/10/10 19:08:16] [03/10/10 19:08:16] 2. Press Power ON shortly! [03/10/10 19:08:16] 1. Remove the battery and then insert it again! [03/10/10 19:08:16] [03/10/10 19:08:36] IMEI: 3563340383XXXX-X [03/10/10 19:08:37] Direct unlock succeeded. [03/10/10 19:09:53] Firmware: REL_P1.2PU04V01.04 [03/10/10 19:09:53] IMEI: 35633403829XXXX [03/10/10 19:09:54] [03/10/10 19:09:54] 2. Press Power ON shortly! [03/10/10 19:09:54] 1. Remove the battery and then insert it again! [03/10/10 19:09:54] [03/10/10 19:10:14] IMEI: 3563340382XXXX-X [03/10/10 19:10:15] Direct unlock succeeded. MIANLINKS |
03-10-2010, 15:47 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | i also unlock some !! [03/10/10 19:36:18] 2. Press Power ON shortly! [03/10/10 19:36:18] 1. Remove the battery and then insert it again! [03/10/10 19:36:18] [03/10/10 19:36:34] IMEI: 35633403736113-9 [03/10/10 19:36:35] Direct unlock succeeded. Br Faisal_Computer |
03-10-2010, 21:31 | #3 (permalink) | |
No Life Poster Join Date: Jun 2007
Member: 534777 Status: Offline Thanks Meter: 214 | What cable do you use???? Quote:
Is it the regular v3 cable or there's a dedicated cable for it??? If yes please provide the pin outs if any. Thanx and best wishes | |
G1157 unlock done 2 piecs | Tanveer_city01 | SAGEM JTAG UNLOCKER | 0 | 03-20-2010 14:03 |
Brand new unlocked 5 pieces blackberry 7730 for sale | deha | Sell ur Old and Used Stuff | 1 | 10-28-2006 14:15 |
5 pieces of 3100 v3.10 to 3.51 dont | ertorry | Griffin | 3 | 07-05-2004 12:15 |
5 pieces of 3100 v3.10 to 3.51 dont charge | ertorry | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 07-05-2004 09:37 |
nokia 6600 blocked 5 pieces | badat_81 | Sell ur Old and Used Stuff | 5 | 05-30-2004 21:42 |
