Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 10-18-2007, 11:48   #1 (permalink)
Bigbrothers2000's Avatar
Member: 487
Thanks Meter: 65
About PCMCIA Parallel Port cards
Hi people,
i have here a laptop without lpt1 port,
i buyed 1 pcmcia to lpt port name=EX-1356
here is specifications,
http://www.exsys.ch/deutsch/produkte/ex_1356.html
after install xp can see it as lpt port (working fine)
i can change ports from lpt1 to lpt2 and lpt3,
but sagdd box dont see any box on lpt1.
in hardware manager when i look to the i/o range adress it is not 0X378 like standart lpt1 adress, it is different. like something FEDF
is this the problem??? because i can not change the irq adress
is there any change that i can use this with sagddbox ,
please help me out
Old 10-18-2007, 12:39   #2 (permalink)
Member: 12837
Thanks Meter: 2,740
Really USB_to_LPT cables, emulate printer port to OS (via suitable drivers),
which make it not fully "IEEE 1284 Compliant SPP, EPP and ECP Parallel Port".
check also here:
http:///vbb/showth...&highlight=LPT
Old 10-23-2007, 12:27   #3 (permalink)
Leshy's Avatar
Member: 70069
Thanks Meter: 5
I have PCMCIA-LPT card from QUATECH , Model SPP100 it workes for me with SAGDD , Smart Clip(only compatible mode) ,Sagmaster and all other LPT dongles
It can use real IRQ and Port adress such 0378h ,but you have to make some changes in INI file ,manuel ,you can change adress range from 0480-FFFF to
0278-all what you whant ,you have only to see ,that this resourses doesn't make a problemm with another devices (adress and IRQ) from your Laptop
Please make it Sticky , i don't whant to write it again
Old 11-27-2007, 15:01   #4 (permalink)
h34d_hunt3r's Avatar
Member: 104632
Thanks Meter: 103
@Oxo_Boxo
Whi dont you create support for FT245 ou FT2232 usb IC's?
Old 11-28-2007, 21:59   #5 (permalink)
Cheater -Don't Deal with him-
Special@gsm's Avatar
Member: 4003
Sonork: 100.111841
Thanks Meter: 39
yes correct
i buyed too PCMCIA-LPT card from QUANTECH ,
and worked fine
By Bigbrothers2000 best regards
Old 01-01-2008, 19:06   #6 (permalink)
Member: 647828
i am interested for sagdd & smart clip.
which one is better?
link will appreciated
WBR!
Old 01-01-2008, 23:15   #7 (permalink)
Johnessen's Avatar
Member: 19831
Thanks Meter: 46
WBR!
Sagdd is for Sagem handsets while Smart-Clip is for Motorola,Sendo and few sony ericsson handsets like Jxx series
Old 01-02-2008, 17:26   #8 (permalink)
Member: 647828
i know sagdd is for sagem , smart clip is for Motorola and setool is for s.e
what i am looking is related to topic.
usb to lpt adopter or pcmcia cards which works for both tools.
WBR!
Old 01-21-2008, 00:57   #9 (permalink)
Crazy Poster
Member: 297926
how to make these changes manually in ini file?
Old 04-06-2008, 13:48   #10 (permalink)
Gjakova's Avatar
Member: 189304
Sonork: 100.1614605
Thanks Meter: 40
anyone can tell me how to install drivers for new 3in1 cables,always lpt1 printer port appears after i install the drivers then when i insert cables they shows as unknown device,i cant bring them to work as a normal usb port.
Old 04-06-2008, 14:22   #11 (permalink)
Member: 12837
Thanks Meter: 2,740
Your question is in wrong place..there we talk about PCMCIA parallel port adapters!
Anyway, download drivers (-IO Cable-PL-2303HX-Drivers-Generic-wd_pl2303_v20019v2028.zip) file and install it first.
Plug Cable in PC USB port and wait until OS enumerate it successfully as COM N !
Start latest SagDD and select COM N in 'Unlocking Device' option box.
br
Old 04-06-2008, 15:00   #12 (permalink)
Gjakova's Avatar
Member: 189304
Sonork: 100.1614605
Thanks Meter: 40
br
sorry for the wrong thread.i did exatly like u describe before,but like i sayd soon the instal drivers some third non exsisting device get in staled,after i plug 3in1 cables they commes as unknown device,i belive could be an conflict betwen different devices i got already instaled on pc.
Old 06-20-2008, 00:33   #13 (permalink)
abumu3ed's Avatar
Member: 462224
Sonork: 100.1586374
Thanks Meter: 85
so, any real solution for new pc without lpt port. really intersting if sagDD team works on that.
PS: most new pc/laptop generation have no parallel/com ports.
Old 06-24-2008, 17:41   #14 (permalink)
Leshy's Avatar
Member: 70069
Thanks Meter: 5
@abumu3ed
can you read ? for a long rime ago , i have written ,that solution is PCMCIA or EXPRESSCARD ------LPT converter , so , it doesn't a problemm at all
@Product Supporter
why this tread is not sticky any more ?
Old 06-24-2008, 19:04   #15 (permalink)
abumu3ed's Avatar
Member: 462224
Sonork: 100.1586374
Thanks Meter: 85
@Leshy
as you can see i'm talking about pc not laptop.
Br.
No parallel port how to udate ? rampe Smart-Clip 5 11-28-2005 23:22
parallel Port Spy Needed.....?! SoftSkiner GSM Programming & Reverse Engineering 20 05-21-2003 11:10
Making data connection parallel port with Visual Basi starphone GSM Programming & Reverse Engineering 4 04-19-2003 20:20
Parallel port setting for MAK nokia flasher? taichip Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-30-2001 01:24
Dejan Flasher + Parallel Port Settings PhoeniX Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 05-24-2001 20:09
Page generated in 0.42434 seconds with 8 queries
