05-14-2008, 12:01 | #1 (permalink) |
Major Poster Join Date: Dec 2004 Age: 46
Member: 95133 Status: Offline Thanks Meter: 0 | boot loader failed This is my first time to unlock sagem 511x and 411 cv. when i press do the job. it said: 1. Remove the battery and then insert it again! 2. Press Power ON shortly! When i try to power on, it will not power on. and it said: PROBLEM: Bootloader failed! PS: i have credit to do the job Please advise. Thank you |
05-14-2008, 14:19 | #2 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | Quote:
1.Use USB-to-Com Cable with installed latest drivers 2.Use SagenDD V7.5 with unlocking option 'Com N' selected, where Com N is a virtual com port number representing USB-to-Com Cable. 3.Phone must be off. Press |do the job| and the shortly phone power btn. | |
05-21-2008, 22:14 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: twitter home
Member: 120893 Status: Offline Thanks Meter: 69 | me too i got this probleme with the new version SAGEM EG V0.8 i m using the usb cable 3 in one AND I GOT 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! |
05-22-2008, 07:08 | #6 (permalink) |
Member: 12837 Status: Offline Thanks Meter: 2,740 | Wrong cable/connection or incorrect Com port number is selected. Use latest driver version from support area. BR Last edited by Oxo_Boxo; 05-22-2008 at 07:14. |
05-22-2008, 07:12 | #7 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @cooloxf SagemEG works perfectly (Simplest, fastest, safest E-Gold unlocker)! Check your USB data cable (USB to COM convertor). Maybe Rx and Tx are swaped. You can check cable with SagemTools and my200C, my300C, my411, my511, VF526, VF527 (same connector). Checking procedure was described many times here. |
3.3rev 1.7 sending boot loader failed | yahoo.mobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-21-2010 09:41 |
V3i boot loader failed | izhanji | Motorola Hardware Repair | 1 | 09-22-2009 10:30 |
V3xx BOOT LOADER (06.24) UNLOCK FAIL | Nasmi | Smart-Clip | 3 | 03-20-2009 07:50 |
V190 Full Flash File In Boot-loader Checksum Check Failed | iruocoop | Smart-Clip | 20 | 07-18-2006 02:50 |
C975 boot loader failed (smart moto) | vrepair | Motorola P2k | 2 | 09-09-2005 14:42 |
