03-18-2010, 09:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: obamas village
Member: 952862 Status: Offline Thanks Meter: 48 | can u fix this zte unlocked but still locked how to write eeprom IMEI: 35949702019355-8 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 004999010640000 Firmware: EF-UG-ORANGE-P108E1(S)V1.0.0B01 PROBLEM: Bootloader failed! (00) 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 004999010640000 Firmware: EF-UG-ORANGE-P108E1(S)V1.0.0B01 PROBLEM: Phone not started! PROBLEM: Phone not started! |
The Following User Says Thank You to obama2 For This Useful Post: |
03-18-2010, 09:52 | #3 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @obama2 Move Backup_004999010640000.bin in another folder. Restore default lock! Unlock phone again! That is all! BTW, use prolific cable if you want to reduce comunication problems with ZTE phones. Just for info, eeprom ( static and dynamic) not have relation to your problem! |
The Following User Says Thank You to latigido For This Useful Post: |
Zte a306 shows unlocked but still locked | kfkevin | SAGEM JTAG UNLOCKER | 7 | 03-24-2010 15:41 |
to elco how can i enter simlock code softbank 707sc2. unlock but still lock usim. | dragories | NSPRO | 1 | 04-11-2009 16:33 |
zte 125 unlocked but still locked | gsmservices | Infinity-Box | 9 | 06-21-2008 10:15 |
How to write eeprom to T100? | zDEnaL | VLSI, Conexant, Skyworks and Old Models | 8 | 09-05-2002 23:14 |
how to write eeprom to aria? | aklishin | Mitsubishi | 0 | 05-10-2001 11:08 |
