Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 10-04-2008, 09:53   #1 (permalink)
Member: 273705
Thanks Meter: 34
Connection problem with sagem V8.5 !!!
with version 8.3 I unlocked without problem all phones ( with logs via RJ45 Infinity Box )...with the last version 8.5 I couldn't connect via Infinity Box ...it gave me this message everytime :
[09/15/08 19:14:01] 2. Press Power ON shortly!
[09/15/08 19:14:01] 1. Remove the battery and then insert it again!
[09/15/08 19:14:01]
[09/15/08 19:14:16] PROBLEM: Bootloader failed!
Q. How can I unlock with the last version 8.5?
I am new user ...I don't know very much about this box but I unlocked over 30 phones without any problem ...i consider it to be a very safe box, easy to use and works very fast !
B.R.
Old 10-04-2008, 10:04   #2 (permalink)
Member: 9544
Thanks Meter: 5,533
SagemEG version is not related to your problem!
Since one week all users used SagemEG_V8.5 without any problem.
So, the problem is in another place.
What phone you can`t unlock?
Old 10-04-2008, 10:04   #3 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
try to unlock by tp procejig ok
Old 10-04-2008, 19:42   #4 (permalink)
Member: 498330
which model u try to unlock?
Old 10-05-2008, 09:08   #5 (permalink)
Member: 273705
Thanks Meter: 34
I don't remember phone's models... i have only the logs:
[09/15/08 19:14:00]
[09/15/08 19:14:01]
[09/15/08 19:14:54]
[09/15/08 19:14:55] 2. Press Power ON shortly!
[09/15/08 19:14:55] 1. Remove the battery and then insert it again!
[09/15/08 19:14:55]
[09/15/08 19:15:10] PROBLEM: Bootloader failed!
[09/22/08 21:12:06]
[09/22/08 21:12:06] 2. Press Power ON shortly!
[09/22/08 21:12:06] 1. Remove the battery and then insert it again!
[09/22/08 21:12:06]
[09/22/08 21:12:21] PROBLEM: Bootloader failed!
[09/22/08 21:13:10]
[09/22/08 21:13:10] 2. Press Power ON shortly!
[09/22/08 21:13:10] 1. Remove the battery and then insert it again!
[09/22/08 21:13:10]
[09/22/08 21:13:25] PROBLEM: Bootloader failed!
[09/22/08 21:14:53]
[09/22/08 21:14:53] 2. Press Power ON shortly!
[09/22/08 21:14:53] 1. Remove the battery and then insert it again!
[09/22/08 21:14:53]
[09/22/08 21:15:08] PROBLEM: Bootloader failed!
[09/22/08 21:15:24]
[09/22/08 21:15:24] 2. Press Power ON shortly!
[09/22/08 21:15:24] 1. Remove the battery and then insert it again!
[09/22/08 21:15:24]
[09/22/08 21:15:39] PROBLEM: Bootloader failed!
[09/22/08 21:20:16]
[09/22/08 21:20:16] 2. Press Power ON shortly!
[09/22/08 21:20:16] 1. Remove the battery and then insert it again!
[09/22/08 21:20:16]
[09/22/08 21:20:31] PROBLEM: Bootloader failed!
these are the logs from the last three phones(phones unlocked with logs and without test points, which were unlocked with ver.8.3 right after i tried with ver. 8.5)....iI will try to pay more attention to all details next time ...but every time i do this : I connect the Dongle to LPT1 an to USB cable, I connect Infinity Box to USB, I open the program ver.8.5 ( user name, pass and use internet connection ), i choose port( every time the same one ) and i hit " do the job " ...when i try 2,3 times with ver.8.5 and i doesn't work , i open ver.8.3 and it works every time ...the only differences between the 2 programs are : at ver. 8.3 next to the button "do the Job" I have "unlock device" and "phone speed" that is set to 115200 and direct unlock ...that's all !
B.R.
Old 10-05-2008, 10:37   #6 (permalink)
Member: 12837
Thanks Meter: 2,740
B.R.
Better pay more attention on differences between SagemDD V8.3 and SagemEG V8.5!!!!
For exam. start reading carefully our user manuals and main support thread.
http://forum.gsmhosting.com/vbb/show...96&postcount=1
Old 10-05-2008, 10:40   #7 (permalink)
Member: 9544
Thanks Meter: 5,533
@GodLike As
I can`t understand what you talk about for!
All explained very well here:
http:///vbb/...d.php?t=526394
Read this basic thread carefully! Read also attached pdf files.
Always read this thread when you have troubles.
So you will save your and our time!
Old 10-06-2008, 08:29   #8 (permalink)
Member: 118601
Thanks Meter: 200
for me this man just make confusion between sagdd v8.3 (calypso& Locosto) and sagdd E-gold V8.5 for E-gold phone.
so my dear friend first you must know difference between those phone before know witch soft of sagdd to use.
Old 10-09-2008, 11:56   #9 (permalink)
pugazhendhi's Avatar
Member: 141927
Thanks Meter: 27
Bsnl g 200 cf unlock error in v eg-v8.5
Bsnl g 200 cf unlock error in v eg-v8.5 please help
before eg-v8.1 working fine in same model
now eg-v8.3 version also problem
please help
Please correct account info(box s/n, user name), before post screen shots!
Old 10-09-2008, 12:04   #10 (permalink)
Member: 9544
Thanks Meter: 5,533
@pugazhendhi
You are wrong!
No difference in connection procedure between V8.1 and 8.5.
You have got Bsnl g 200 cf with new flash type.
Send e-mail to [email protected]. We will send to you new SagemEG unlocker for test
BR!
Old 10-09-2008, 13:18   #11 (permalink)
Member: 141927
Thanks Meter: 27
Ok sir thanks i will send
Old 10-13-2008, 12:27   #12 (permalink)
Member: 141927
Thanks Meter: 27
flash ic detail for bsnl G-200CF
PLEASE HELP FOR UNLOCK
Old 10-13-2008, 12:37   #13 (permalink)
Member: 12837
Thanks Meter: 2,740
PLEASE FLOW EXACTLY LATIGIDO ADVICE :
Old 10-13-2008, 18:54   #14 (permalink)
Member: 9544
Thanks Meter: 5,533
@pugazhendhi
Do you want to unlock this phone or not?
We are waiting your e-mail since 4 days!
It`s too slowly!
Old 10-14-2008, 08:39   #15 (permalink)
Member: 141927
Thanks Meter: 27
I sent now please verify if need more i will sent
thanks
B300 with new v8.5 can not unlock Ciux UST Pro II 38 04-22-2009 07:15
worried with sagem myx 5 simlock winston Phone Unlocking Codes & Maps 5 08-16-2003 12:38
Help with Sagem MYX-5 Kalidor Phone Unlocking Codes & Maps 1 07-28-2003 23:13
plz calc and help me with Sagem MYX-5 FRED21 Phone Unlocking Codes & Maps 1 07-23-2003 19:44
To all generous people - please help with Sagem MYX-5, for a reward! Lucas Phone Unlocking Codes & Maps 2 03-04-2003 12:27
Page generated in 0.25229 seconds with 11 queries
